[其他] NI-VISA 5.4.1 for Windows
山海致远 发表于 2014-11-19 13:30:10 | 显示全部楼层 |阅读模式
Using NI-VISA 5.4.1Supported Platforms
NI-VISA for Windows supports the following platforms:
  • Windows Server 2003 R2 (32-bit version only)1,2
  • Windows Server 2008 R2 (64-bit version only)1
  • Windows 8 x64 Edition (64-bit version)
  • Windows 8 (32-bit version)
  • Windows 7 x64 Edition (64-bit version)
  • Windows 7 (32-bit version)
  • Windows Vista x64 Edition (64-bit version)
  • Windows Vista (32-bit version)
  • Windows XP Service Pack 3
  • LabVIEW Real-Time (Phar Lap ETS and VxWorks) 2013/2012/2011/2010
  • NI Linux® Real-Time
  • LabWindows/CVI Real-Time (Phar Lap ETS) 2013/2012/2010/9.0
  • LabVIEW Mobile Module 2013/2012/2011/2010
  • LabVIEW Touch Panel Module 2013/2012/2011/2010
While this distribution targets all these platforms, you can run setup.exe only on the Windows variants.
1 NI-VISA does not support the Windows Server non-R2 editions.
2 Support for Windows Server 2003 R2 may require disabling physical address extensions (PAE). To learn how this might affect your use of Windows Server 2003 and what actions you might need to take。
Supported Development Environments
NI-VISA for Windows supports the following development environments. If you are not using NI application software, refer to Microsoft Visual Studio Support.
NI Application SoftwareVersions Supported by NI-VISA
LabVIEW2013/2012/2011/2010
LabWindows/CVI2013/2012/2010/9.0
Measurement Studio2013/2012/2010/2009
Measurement Studio Examples
The directories that the Measurement Studio examples install to depends on which component is installed, the version of Visual Studio or the .NET Framework the example supports, the version of Measurement Studio installed, and the operating system. For detailed information on examples for Measurement Studio, refer to Where to Find Examples in the NI Measurement Studio Help.
The following table lists the programming languages and Microsoft Visual Studio versions supported by this version of NI-VISA. Earlier versions of NI-VISA support other application software and language versions. For more information on Visual Studio compatibility with earlier versions of VISA, refer to ni.com/info and enter the info code . To find and download an earlier version of a driver。
Programming LanguageVisual Studio Versions Support by NI-VISA
Visual C++ MFC120082
.NET Framework 3.5 Languages
(Visual C# and Visual Basic .NET)
2008
.NET Framework 4.0 Languages
20103
.NET Framework 4.5 Languages
20124
1 NI-VISA includes limited support for Visual Studio C++ MFC. For more information,3.
2 Requires Measurement Studio 8.6 — Measurement Studio 2009.
3 With Windows XP, Service Pack 3 or later is required.
4 Windows 8, Windows 7, Windows Vista SP2, or Windows Server 2008 R2 is required.
If you are using the NI-VISA .NET Library, the .NET 3.5 Framework, .NET 4.0 Framework, or .NET 4.5 Framework is required.
Support for 64-bit applications is available in NI-VISA 4.5.1 and later for Visual Studio 2008 support, NI-VISA 5.0.3 and later for Visual Studio 2010 support, and NI-VISA 5.4 and later for Visual Studio 2012 support.
Installing and Uninstalling NI-VISA 5.4.1
NI-VISA 5.4.1 does not support Windows 9x/NT/2000. To run your VISA application on Windows 95, you must install NI-VISA 2.6.1 or lower. To run your VISA application on Windows 98/Me, you must install NI-VISA 3.0.1 or lower. To run your VISA application on Windows NT, you must install NI-VISA 3.3.1 or lower. To run your VISA application on Windows 2000, you must install NI-VISA 4.6.2 or lower.
Before you install NI-VISA 5.4.1, National Instruments recommends that you uninstall any versions of VISA prior to NI-VISA 2.0.1.
After uninstalling NI-VISA, some DLLs and executables may remain in the NI-VISA directories. To complete the uninstall process, you must restart your machine.
Note: The uninstaller application does not notify you when rebooting is necessary. If you plan to reinstall NI-VISA, you always should reboot the machine after running the uninstaller.
You can programmatically install NI-VISA. You also can programmatically control which features of NI-VISA are enabled for installation, allowing you to install a subset of the NI-VISA feature list. Refer to the spec.ini file in the same directory as this readme for more information about installing NI-VISA programmatically and selecting which features to install.
Agilent/HP Controller Support
NI-VISA now works with Agilent/HP GPIB and VXI controller cards. To use this feature, go into MAX, select Tools»NI-VISA»VISA Options, choose the Passports tab, and enable the NiVisaTulip.dll Passport. NI-VISA automatically finds and accesses any GPIB or VXI devices. However, NI-VISA does not configure the Agilent/HP hardware; you still must do that with the Agilent/HP I/O Config utility.
If you have both National Instruments and Agilent/HP controllers in the same system, you must configure the cards at different system addresses, such as GPIB0 and GPIB1. If both vendors try to use the same interface address, NI-VISA reports an error from viFindRsrc or VISA Find Resources.
WHQL Signing USB Hardware
To WHQL (Windows Hardware Quality Labs) sign your USB hardware using the NI-VISA driver for Windows XP/2000, as part of this process you need a PDB (Program DataBase) file for the underlying driver (NiViUsbK.sys).
NiViUsbK.pdb is provided for this purpose. It is in <NI-VISA Installation Directory>\WinNT\NIvisa\USB.
Creating and Digitally Signing Catalog Files
On Windows Vista and Windows 7, if you generate an INF file using the NI-VISA Driver Wizard, the INF file installs correctly by itself. However, a warning dialog notifies you that Windows cannot verify the publisher of this driver software. To avoid this dialog, you must create and digitally sign a Windows Catalog (.cat) file.
下载地址
zrsheng 发表于 2014-11-24 22:24:24 | 显示全部楼层
谢谢分享,看看是什么
zhl90107 发表于 2014-12-1 11:37:30 | 显示全部楼层
学习中……
t-98 发表于 2015-1-13 15:27:19 | 显示全部楼层
感谢楼主分享
cyxcpyzc 发表于 2015-1-18 20:50:00 | 显示全部楼层
:)看看,谢谢!
xiaoya.he 发表于 2015-1-26 22:11:55 | 显示全部楼层
谢谢分享,看看是什么
烽火花心 发表于 2015-2-1 09:01:01 | 显示全部楼层
visa5.4能用在2012上吗
charley 发表于 2015-3-7 20:30:07 | 显示全部楼层
需要试试,在64位机中。
charley 发表于 2015-3-7 20:35:47 | 显示全部楼层
下不了啊。
wmdragon 发表于 2015-3-10 21:12:44 | 显示全部楼层
正好需要,看看能不能用
GMT+8, 2026-9-21 06:27
