iFIX IGS驱动介绍
山海致远 发表于 2014-8-1 14:41:39 | 显示全部楼层 |阅读模式
iFIX5 1及其之前的版本IGS驱动是需要另外购买授权。从IFIX5 5开始,购买IFIX正版iFIX授权,里面就集成IGS基本版使用授权。
从IFIX5.5开始,购买IFIX正版iFIX授权,里面就集成IGS基本版使用授权。
IGS 全称是Industrial Gateway Server,其实质是Kepware的OEM。
IGS支持的操作系统如下:
Windows 2000, Server 2003, XP, Vista, Windows 7, Server 2008 (32-bit and WoW64)
IGS基本版支持如下设备:
Advanced Simulator Driver
Memory Based Driver
Allen-Bradley ControlLogix
Allen-Bradley DH+
Allen-Bradley DF1
Allen-Bradley Ethernet
Allen-Bradley Unsolicited Ethernet
Allen-Bradley Bulletin 900
Analog Devices
Aromat Serial
Aromat Ethernet
AutomationDirect EBC
AutomationDirect ECOM
AutomationDirect Direct Net
AutomationDirect K Sequence
Automation Direct Productivity 3000 Ethernet
Beckhoff TwinCAT
Busware Ethernet I/O
CID (Custom Interface)
Contrex Serial
Contrex M-Series
Cutler Hammer
Cutler Hammer ELC
Dataforth isoLynx
DDE Client Driver
DeviceNet (Hilscher Universal)
Fuji Flex
GE CCM
GE Ethernet Global Data (EGD)
GE Ethernet
GE SNP
GE SNPX
GE Focas1
Hilscher Universal Driver
Honeywell HC Ethernet
Honeywell UDC
Honeywell UDC Ethernet
Intelligent Actuator Super
Idec
InTouch Client Driver
IOTech PointScan 100
Krauss Maffei Ethernet
Mettler Toledo Serial
Micro-DCI
Mitsubishi Ethernet
Mitsubishi Serial
Mitsubishi FX
Mitsubishi FX Net
Mitsubishi CNC Ethernet
Modbus ASCII
Modbus Ethernet
Modbus Plus
Modbus RTU Unsolicited
Modbus Serial
MTConnectClient
ODBC Client Driver
Omron FINS Ethernet
Omron FINS Serial
Omron Host Link
Omron Process Suite
Omron Toolbus
OPC DA Client Driver
OPC UA Client Driver
Optimation OptiLogic
Partlow ASCII
Philips P8/PC20
Profibus (Hilscher Universal)
SattBus Ethernet
SattBus Serial
Scanivalve Ethernet
Siemens S5
Siemens S5 3964R
Siemens S7 200
Siemens TCP/IP Ethernet
Siemens TCP/IP Unsolicited
Siemens S7 MPI
Simatic 505 Ethernet
Simatic 505 Serial
SIXNET EtherTRAK I/O
SIXNET UDR
SquareD Serial
System Monitor
Telemecanique Uni-Telway
Thermo Westronics Ethernet
Thermo Westronics Serial
Tiway Host Adapter
Torque Tool Ethernet
Toshiba Ethernet
Toshiba Serial
Toyopuc PC3/PC2 Ethernet
Toyopuc PC2 Serial
User-Configurable (U-CON) Driver
WAGO Ethernet
Yaskawa Memobus Plus
Yaskawa MP Ethernet
Yaskawa MP Serial
Yokogawa Controller Serial
Yokogawa CX
Yokogawa Darwin
Yokogawa Darwin
Yokogawa DX
Yokogawa DX
Yokogawa DXP
Yokogawa HR
Yokogawa MW100
Yokogawa MX100
Yokogawa YS100
IGS需另外授权的协议1(这些协议是一个授权包):
BACnet I/P
DNP3 Ethernet and serial
Fisher ROC serial
Fisher ROC Plus serial
IGS需另外授权的协议2:
SNMP (SNMP and Ping)
IGS支持的数据类型如下:
Boolean、Byte、Char 、Word、Short、DWord、Long、BCD、LBCD、Float 、String
下载地址
Industrial Gateway OPC Server 7.615.132 安装文件下载 IGS软件
https://www.eleok.com/thread-123605-1-1.html
yzbwwj 发表于 2015-3-26 15:59:46 | 显示全部楼层
这款驱动里面包含90-30系列的PLC,我注意到其中有CPU360,却没有CPU364,是不是360包含着364这款CPU呢
thomas_top 发表于 2015-3-31 17:03:09 | 显示全部楼层
有IGS7.58最新版的,你可以找下看
诺诚电气 发表于 2016-5-18 16:53:34 | 显示全部楼层
11111111111111111
ifix 发表于 2017-8-18 11:06:13 | 显示全部楼层
连接打不开
huyan41500 发表于 2019-12-12 10:41:45 来自手机 | 显示全部楼层
讲的很仔细
GMT+8, 2025-12-14 22:00
