施耐德ATV71变频器详细说明书 简体中文版
yanbingding 发表于 2014-3-19 10:17:51 | 显示全部楼层 |阅读模式
施耐德变频ATV71说明书.pdf (2.26 MB, 售价: 3 E币)
开始之前___________________________________________________________________________________________________________________ 4
文档结构 __________________________________________________________________________________________________________________ 5
软件升级 __________________________________________________________________________________________________________________ 6
制动单元安装步骤 __________________________________________________________________________________________________________ 8
出厂设置 __________________________________________________________________________________________________________________ 9
应用功能__________________________________________________________________________________________________________________ 10
设置 –初步建议 ___________________________________________________________________________________________________________ 14
图形显示终端 _____________________________________________________________________________________________________________ 16
终端描述 ___________________________________________________________________________________________________________ 16
图形显示屏描述 ______________________________________________________________________________________________________ 17
第一次通电- [5. LANGUAGE(语言)]菜单 _________________________________________________________________________________ 20
随后通电____________________________________________________________________________________________________________ 21
编程:参数访问示例___________________________________________________________________________________________________ 22
快速导航 ____________________________________________________________________________________________________________ 23
集成显示终端 _____________________________________________________________________________________________________________ 26
显示屏与按键的功能___________________________________________________________________________________________________ 26
访问菜单 ____________________________________________________________________________________________________________ 27
访问菜单参数_________________________________________________________________________________________________________ 28
[2. ACCESS LEVEL(访问等级)](LAC-)______________________________________________________________________________________ 29
参数表结构________________________________________________________________________________________________________________ 32
参数值之间的相互关系 _____________________________________________________________________________________________________ 33
在此文档中查找一个参数 ___________________________________________________________________________________________________ 34
[1.1 SIMPLY START(简单起动)](SIM-)______________________________________________________________________________________ 35
[1.2 MONITORING(监视)](SUP-) __________________________________________________________________________________________ 43
[1.3 SETTINGS(设置)](SEt-) ______________________________________________________________________________________________ 52
[1.4 MOTOR CONTROL(电机控制)](drC-) __________________________________________________________________________________ 66
[1.5 INPUTS / OUTPUTS CFG(输入/输出设置)](I-O-)__________________________________________________________________________ 86
[1.6 COMMAND(命令)](CtL-)__________________________________________________________________________________________ 114
[1.7 APPLICATION FUNCT.(应用功能)(] FUn-) ______________________________________________________________________________ 127
[1.8 FAULT MANAGEMENT(故障管理)](FLt-) _____________________________________________________________________________ 212
[1.9 COMMUNICATION(通信)](COM-) ___________________________________________________________________________________ 236
[1.10 DIAGNOSTICS(诊断)]_______________________________________________ _______________________________________________ 240
[1.11 IDENTIFICATION(软硬件识别)]_______________________________________________________________________________________ 242
[1.12 FACTORY SETTINGS(出厂设置)(] FCS-) _______________________________________________________________________________ 243
[1.13 USER MENU(用户菜单)](USr-) ___________________________________________________________________________________ 246
[1.14 PROGRAMMABLE CARD(编程卡)](PLC-) ___________________________________________________________________________ 247
[3. OPEN / SAVE AS(打开/保存为)]________________________________________________________________________________________ 248
[4. PASSWORD(密码)](COd-)______________________________________________________________________________________ 250
[6 MONITORING CONFIG.(监视设置)]___________________________________________________________________________________ 252
[7 DISPLAY CONFIG.(显示设置)]_______________________________________________________________________________________ 256
[MULTIPOINT SCREEN(多点屏幕)]______________________________________________________________________________________ 261
维护 ____________________________________________________________________________________________________________________ 262
故障-原因- 修复措施 ______________________________________________________________________________________________________ 263
用户设置表 ______________________________________________________________________________________________________________ 269
功能索引_________________________________________________________________________________________________________________ 271
参数代码索引_____________________________________________________________________________________________________________ 272
GMT+8, 2025-4-21 19:23
