SIRIUS Safety ES V19 (TIA Portal) 下载
boke 发表于 2025-1-18 21:51:09 | 显示全部楼层 |阅读模式
SIRIUS_Safety_ES_V19.exe (访问密码: 6206)
System requirements
Windows 10 64-bit Pro/Enterprise Version 22H2 (OS build 19045)
Windows 10 64-bit Enterprise Version 21H2 (OS build 19044), 22H2 (OS build 19045)
Windows 10 64-bit Enterprise 2016 LTSC (OS build 14393) / 2019 LTSC (OS build 17763)/2021 LTSC (OS build 19044)
Windows 11 Home Version 22H2 (OS build 22621)
Windows 11 Pro Version 22H2 (OS build 22621)
Windows 11 Enterprise 22H2 (OS build 22621)
Windows 11 Home Version 21H2 (OS build 22000)
Windows 11 Pro Version 21H2 (OS build 22000)
Windows 11 Enterprise 21H2 (OS build 22000)
Windows Server 2016 / 2019 / 2022 64-bit Standard
The central software for configuring, commissioning, operation, and diagnostics of 3RW5 and 3RW44 soft starters.
SIRIUS Soft Starter ES V19 is the central software for commissioning, operation, and diagnostics of the SIRIUS 3RW5 and 3RW44 soft starter series.
Soft Starter ES V14, V15, V15.1, V16, V17, and V18 licenses can also be used for Soft Starter ES V19.
Soft Starter ES V19 is integrated seamlessly if other TIA Portal V19-based software such as STEP 7 or WinCC is already installed, thus enabling users to achieve a consistent, efficient, and intuitive solution for all automation tasks.
However, those who use Soft Starter ES V19 as standalone software will also benefit from its features.
What's new in SIRIUS Soft Starter ES V19?
You can compare three different configurations to each other in the Commissioning > Work area > Soft starter > Actual configuration menu. (Actual configuration/Set configuration/Project)
When a new spare part is ordered, you can assign a new article number to it in the "Online access" menu under "Commissioning > Work area > Soft starter > Functions > Spare parts management".
Improved parameter assignment of the analog outputs
Go online, support for different configurations -> Easy to change parameters in case of incorrect device configuration
Improvements and bug fixes in user account management
Stability when working in the TIA Portal has been improved, among other things on the basis of feedback from returned crash reports.
GMT+8, 2025-4-15 13:41
