[文档] 森精机床 ESPRIT程序示例手册 中英文双语版
dami 发表于 2024-12-24 23:42:20 | 显示全部楼层 |阅读模式
文档下载: ESPRIT程序实例.pdf (9.62 MB, 售价: 3 E币)
适用机型 Applicable Model
NH 系列、NH Series、NMH 系列、NMH Series、NMV 系列、NMV Series、NT 系列、NT Series、NVD 系列、NVD Series、NZ 系列、NZ Series、NZL 系列、NZL Series、NV7000
适用数控装置 Applicable NC Unit
MSX-501IV MSX-701IV MSX-711IV MSX-853IV
目录 CONTENTS
1 章 加工中心实例
CHAPTER 1 MACHINING CENTER EXAMPLE
1 2.5 轴加工定义 (NMV/NMH/NH/NV/NVD 系列 ) ................................................................3
2.5 AXIS MACHINING DEFINITION (NMV/NMH/NH/NV/NVD Series)
1-1 创建加工操作的准备 ........................................................................3
Preparing for Creating Operation
创建新的文件...........................................................................3
Creating New File
选择系统单位...........................................................................3
Selecting System Units
选择加工模式...........................................................................4
Select Machining Mode
配置工件零点...........................................................................4
Configuring the Workpiece Zero Point
1-2 创建三维几何形状 ..........................................................................4
Creating 3D Wire Geometry
绘制外框...............................................................................4
Drawing the outer frame
绘制内框...............................................................................5
Drawing the inner frame
删除不必要的要素.......................................................................6
Deleting Unnecessary Elements
创建孔的几何形状.......................................................................6
Creating Hole Geometry
切换视图...............................................................................7
Changing View
拖动复制...............................................................................7
Lifting Copy
创建线段...............................................................................9
Creating Segments
保存文件..............................................................................10
Saving Files
1-3 创建加工操作 .............................................................................10
Creating Operations
配置刀具..............................................................................10
Configuring Tools
创建图层..............................................................................12
Creating Layers
创建轮廓..............................................................................13
Create Feature
加工定义..............................................................................14
Machining Definition
1-4 模拟 .....................................................................................16
Simulation
1-5 NC 代码转换 ..............................................................................17
NC Code Conversionii
2 章 多轴加工案例
CHAPTER 2 MULTI-AXIS MACHINE EXAMPLE
1 多轴加工定义 (NT 系列 ).................................................................................................. 21
MULTI-AXIS MACHINING DEFINITION (NT SERIES)
1-1 创建实体模型 .............................................................................22
Creating solid model
创建图层..............................................................................22
Creating layer
创建六角形............................................................................22
Creating hexagon
创建六角柱实体........................................................................24
Creating hexagonal column solid
实体切削..............................................................................25
Solid Cutting
倒角..................................................................................26
Chamfering
型腔..................................................................................27
Pocket
创建端面孔............................................................................34
Creating End Face Holes
在斜面上创建孔........................................................................38
Creating Holes on Slant Face
1-2 创建加工操作 .............................................................................41
Creating Machining Operations
选择加工模式..........................................................................41
Selecting machining mode
加工设置..............................................................................41
Machine setup
配置工件坐标系 (主轴侧)..............................................................42
Configure workpiece coordinate system (main spindle side)
配置加工面............................................................................43
Configuring working surface
配置刀具..............................................................................43
Configuring tools
创建图层..............................................................................44
Creating layers
各加工配置 (主轴侧)..................................................................45
Configuring each machining (main spindle side)
配置工件坐标系 (副轴侧)..............................................................79
Configuring workpiece coordinate system (sub spindle side)
配置加工 (副轴)......................................................................80
Configuring machining (sub spindle)
1-3 模拟 .....................................................................................84
Simulation
1-4 NC 代码转换 ..............................................................................84
NC code conversion
GMT+8, 2025-4-20 21:57
