[软件] FANUC Program Transfer Tool V19.0 程序传输工具安装文件下载
tubage 发表于 2024-10-22 17:10:35 | 显示全部楼层 |阅读模式
数控品牌
数控品牌: 发那科
FANUC程序传输工具,CNC<->PC程序互传非常方便
附件解压密码是123
FANUC Program Transfer Tool V19.0解压密码123.zip (8.41 MB, 售价: 2 E币)
FANUC Program Transfer Tool 其他版本下载
https://doc.eleok.com/2322.html
解压的目录里找到
打开 会话设定 在 序列号--管理  输入序列号。
[1] Environment
1.1. Supported OS
    Program Transfer Tool supports the following OS.
      - Windows 11 Pro
      - Windows 10 Pro  (32/64bit OS)
    Display : 1024x768 or higher resolution
    Vacant capacity of hard disk : 30Mbytes or more
1.2. Program Transfer Tool can be used with the following CNC:
      - Series 30i/31i/32i-MODEL A/B/B Plus
      - Series 35i-MODEL B
      - Power Motion i-A
      - Series 0i-MODEL B/C/D/F/F Plus
      - Series 16i/18i/21i-MODEL A/B
      - Series 20i-MODEL B
      - Power Mate i-MODEL D/H
   The Ethernet or Data Server function is required to CNC.
   The PCMCIA LAN card is not supported.
[2] Installation
2.1. Procedure of installation
     - The administrator privilege is required to installing.
     - Silent installation is not supported.
    (1) Set CD-ROM in CD-ROM drive.
    (2) The installer will be started automatically.
    Follow the instructions which are displayed in PC.
2.2 Serial No.
    After the installing, the serial number is required on the setting dialog.
    The serial number paper is included in the CD-ROM case.
2.3 Procedure of update
    - It is possible to update from old specification, A08B-9510-J513 or
      A08B-9510-J514, to the new specification, A08B-9510-J515.
    - The following updating procedure is different:
        (a) Version 1.0 -> Version 2.0
        (b) Version 2.0 -> Version 3.0 or later
      Please refer to the manual for the detail.
[3] Update history
   Version 19.0 (October, 2023)
        - A digital signature has been added. There are no changes in
          functionality.
   Version 18.0 (November, 2022)
        - The extended program memory (PC) has been supported.
        - The progress display of downloading and uploading programs has been
          supported.
        - LSCi-A has been supported with the setting of 31i.
   Version 17.0 (September, 2020)
        - The security function of FOCAS2 library has been supported.
   Version 16.0 (June, 2019)
        - The download speed to the program storage file (FANUCPRG.BIN) stored
          in the memory card of CNC is improved.
        - Even if the Program Folder Screen is displayed on the CNC while
          downloading or uploading multiple text files to or from the CNC
          memory card, the transfer have been supported.
   Version 15.0 (Nov.,2018)
        - Program storage file (named "FANUCPRG.BIN") in the memory card of CNC
          has been supported.
        - The number of path(head) supported by the tool has been expanded to
          15.
   Version 14.0 It is a missing number.
   Version 13.0 (May,2018)
        - Communication may be terminated when operation is not performed for
          a certain period of time after connecting this tool and CNC.
          This phenomenon may occur in Windows Vista or later OS.
          It has improved so that this phenomenon does not occur.
   Version 12.0 (Mar.,2017)
        - Memory card of CNC is supported.
   Version 11.0 It is a missing number.
   Version 10.0 (Nov.,2014)
        - Series 0i-MODEL F has been supported.
        - Windows 10 Pro(32bit/64bit OS) has been supported.
   Version 9.0 (June,2014)
        - License and specification has been changed.
          License
            The single computer license has been changed to the site license.
            Please refer to the "LICENSE AGREEMENT" for details.
          New specification
            A08B-9510-J515
          Old specifications are abolished.
            A08B-9510-J513
            A08B-9510-J514
   Version 8.0 (Aug.,2011)
        - Power Motion i-A has been supported.
        - Windows 8 Pro(32bit/64bit OS) has been supported.
   Version 7.0 (Feb.,2011)
        - Windows 7 Professional(64bit OS) has been supported.
   Version 6.0 (Oct.,2010)
        - Series 30i/31i/32i-MODEL B, Series 35i-MODEL B has been supported.
   Version 5.1 (May,2010)
        - The following error may be occurred at downloading.
            "Retry because the buffer is full."
          This problem is corrected.
   Version 5.0 (Apr.,2010)
        - Windows 7 Professional(32bit OS) has been supported.
   Version 4.0 (Sep.,2008)
        - Transferring tool management data of Series 30i/31i/32i-MODEL A has
          been supported.
   Version 3.0 (May.,2008)
        - Series 0i-MODEL D has been supported.
        - Simplified Chinese has been supported.
   Version 2.0 (Dec.26,2007)
        - Windows Vista Business(32bit OS) has been supported.
        - Upgrade CD is added.
   Version 1.0 (Oct.03,2007)
        - New creation
**  Microsoft, Windows, Windows XP, Windows Vista, Windows 7, Windows 8, and Windows 10 are trademarks or registered trademarks of Microsoft Corporation.
**  Other product names mentioned are trademarks or registered trademarks of their respective companies.
赵金钢 发表于 2024-11-30 17:23:17 | 显示全部楼层
没序列号,非破解版,没意义,
mopi 发表于 2024-12-2 16:30:26 | 显示全部楼层
没序列号,非破解版,没意义,
有的,解压后里面有个key.txt文件
hl382351243 发表于 2025-6-6 12:33:30 | 显示全部楼层
所有IP设置均正确,就是连接不上?提示“不能ping到选定目标,请检查目标的地址,线缆和电源”。求解什么原因
icefire 发表于 2025-6-7 01:58:32 | 显示全部楼层
所有IP设置均正确,就是连接不上?提示“不能ping到选定目标,请检查目标的地址,线缆和电源”。求解什么原 ...
现在电脑的cmd里ping一下看看能不能ping通目标机床。如果不能ping通,先检查两边设备、网线、网络设备问题。如果能ping通,而传输工具提示这个错误,继续检查一下是不是电脑防火墙拦截了连接,可以暂时关闭防火墙试试。
追雪2002 发表于 2025-6-7 19:27:53 | 显示全部楼层
谢谢楼主分享
追雪2002 发表于 2025-6-7 21:01:02 | 显示全部楼层
除了ip,有个端口设置很重要
lmg3 发表于 2025-11-10 02:05:27 | 显示全部楼层
谢谢楼主分享!!
GMT+8, 2026-9-21 01:32
