[软件] FANUC CNC GUIDE V25.00 下载
seasky 发表于 2024-9-10 02:17:29 | 显示全部楼层 |阅读模式
数控品牌
数控品牌: 发那科
支持操作系统:
Windows(R) 8.1 Pro  (32bit,64bit)
Windows(R) 10   (32bit,64bit) Recommended Version 2004 or higher
注意:安装完毕主程序后,打开会提示“E0003 --Hardware key not found”(如下图所示),这是因为没有给电脑插入usb硬件授权设备,程序只有检测到电脑上插入了usb硬件授权设备后才能继续运行。解决方法请继续看下面文字。
XX方法:首先运行NC GUIDE25_0_A08B-9010-K730目录下的安装程序,安装完毕后,如果是默认安装以windows10操作系统为例一般程序被安装到C:\Program Files (x86)\路径下的FANUC文件夹里,然后用NcGuidePatch25目录里的FANUC文件夹覆盖即可,这样就能正常的启动程序了。
安装文件下载:仅提供个人在家学习用途,此程序文件来源于网络可靠性稳定性完整性皆无法验证,禁止用于其他用途,否则后果自负。
下载链接.txt (1.45 KB)
请先下载完文件后,再获取解压密码
解压密码.txt (1.35 KB, 售价: 10 E币)
[01] About CNC GUIDE DVD
[02] Environment
[03] Install
[04] About Operator's Manual
[05] FANUC PICTURE function
[06] FOCAS2 function
[07] Restrictions
[08] Notes
[09] Update history
  The following software is stored in CNC GUIDE DVD.
     - CNC GUIDE
       - CNC Simulation function
       - PMC Simulation function, Machine Simulation function
       - ManualGuide i Simulation function
       - FANUC PICTURE function
       - FOCAS2 funtion
     - Driver software of USB hardware Key
     - Network license server software
[02] Environment
- When operating the CNC GUIDE
     - Windows(R) 8.1 Pro        (32bit,64bit)
       + .NET Framework2.0/.NET Framework 3.5
     - Intel Core i3 or higher
     - Memory 4Gbytes or more
     - Vacant capacity of hard disk : 8.0Gbytes or more
     - Display : 1280*1024(SXGA) or higher resolution
                (Recommended 1920*1080(Full-HD) or higher resolution)
                Dual display is recommended for iHMI mode.
     - DVD drive
     - USB port
     * When you use the multi-user license by network, this software is necessary.
       Windows(R) 10             (32bit,64bit) Recommended Version 1803 or higher
       Windows Server 2012       (64bit)
       Windows Server 2012 R2    (64bit)
     - Memory 2GB or more
     - Vacant capacity of hard disk : 10Mbytes or more
     - Display : 1024*768 or higher resolution
     - DVD drive
     - USB port
- Notes
1. In some cases, fully performance of this application can not be achieved
    owing to the kind, performance and using condition of personal computer.
2. FANUC CNC GUIDE is under restriction of Windows as well as other
    applications for Windows. So CNC GUIDE influences the performance of other
    applications and also it is under the influence of other
    applications.
3. Especially, it greatly influences the operation of the CNC GUIDE when a
    real-time check with the anti virus software is effective.
4. When using FANUC LADDER-III or Machine Signal API function for PMC
    simulation function, connecting to effective network or using a Loopback
    Adapter is necessary.
    Moreover, enabling the Hyper-Threading is recommended when using the FANUC
    LADDER-III or the Machine Signal API function on the same PC that is using
    the PMC simulation function.
5. In Windows(R) 10 Windows Update to the latest version is recommended.
    In Windows(R) 10 version 1703 or older, CNC GUIDE operation may be slow.
6. Depending on the virtual environment, the hardware key may not be recognized
    or CNC GUIDE may not work properly.
    If you use CNC GUIDE in a virtual environment, use it on your own risk.
7. The hardware key may not be recognized on the remote desktop.
    If you use CNC GUIDE on a remote desktop, use it on your own risk.
8. The UDP packet is transmitted when CNC GUIDE is used by the network license
    and the network is communicated.
    The UDP6001 port is used for the transmission.
    When these communications cannot be done by the firewall software and
    Switching hub, etc. , the function concerning the network license cannot
    be used.
    In that case, please set the firewall and Switching hub, etc. to
    communicate.
9. Please don't install CNC GUIDE in PC for which other software that uses
    the hardware key (protect key) has already been used.
    When you install it, the hardware key might not be able to be recognized
    correctly.
[03] Install
1. Procedure of install
    (1) Set DVD in DVD drive.
    (2) The installation is automatically begun.
    (3) When the installation is not automatically begun,
        "AutoRun.exe" that exists in the root folder of DVD is
        double-clicked
        from the Explorer and it starts.
    (4) When NET Framework is not installed, .NET Framework installation is
        begun. Please operate it according to the instruction of the screen.
    (5) Select the installed software.
    (6) The installation of the FANUC CNC GUIDE is begun.
2. Attention for install
    - Do not specify the root folder(\) for install folder.
      Moreover, please do not use two byte character (Chinese character,
      katakana, and Hangul, etc.) for the folder name.
    - When CNC GUIDE in the PCs in which the CNC GUIDE that authorize
      the license with the software license has been installed, it replaces
      CNC GUIDE (Hardware key).
    - Please do not install CNC GUIDE in the PC that the following software
      installed.
      + CNC Simulator           (A08B-9010-J720#ZZ11)
      + PMC Simulator           (A08B-9210-J530#ZZ11)
      + ManualGuide i Simulator (A08B-9010-J540#ZZ11)
      Please do the following work before installing the CNC GUIDE when these
      software is installed.
      (a)The CNC Simulator, the PMC Simulator, and ManuGuide i Simulator are
         uninstalled.
      (b)SSDCleanup11.exe is executed.(in \Setup\driver\Cleanup of DVD)
      (c)The CNC GUIDE is installed.
  The manual is included in the \doc folder of DVD as PDF file.
  The following system is necessary to use FANUC PICTURE function on CNC GUIDE.
  (1) For FS30i-A series
    - FANUC PICTURE Disk (Japanese / English)(A08B-9010-J518#ZZ11)
                                                     (Edition 2.5 or later)
  (2) For FS0i-D
                                                     (Edition 3.1 or later)
  The FP driver and the screen data for the sample of FANUC PICTURE are
  included in CNC GUIDE DVD.
  Please refer to the "Samples\FANUC PICTURE\Readme1.txt" for the use of the
  sample.
  The following system is necessary to use FOCAS2 function on CNC GUIDE.
    - FOCAS1/2 Library disk(A02B-0207-K737) (Edition 3.2 or later)
  (2) For FS0i-D
    - FOCAS1/2 Library disk(A02B-0207-K737) (Edition 3.3 or later)
  The libraries for test are included in CNC GUIDE DVD.
  Please refer to the "Samples\FOCAS2\Readme2.txt" for the use of the libraries
  for test.
[07] Restrictions
There are some restrictions in CNC GUIDE as follows.
  (1) Two FANUC CNC GUIDE or more cannot be started at the same time.
  (2) Display in monochrome mode is impossible.
  (3) The boot screen and IPL menu screen cannot be displayed.
  (4) The following size of the display is needed for the display without the
      scroll of the whole of the FANUC CNC GUIDE for the size of the
      CNC screen.
       CNC screen size
       10.4 inches: 1280*1024
       15 inches: 2048*1536
      The size of the display scrolls and uses the screen of the FANUC
      CNC GUIDE less than this.
  (5) The system construction that can be set is as follows.
       [FS31i-A, FS31i-B]
       Number of maximum machine groups: 3
       Number of maximum path: 4
       Number of maximum axes: 20
       Number of maximum spindles: 6
       [FS30i-B]
       Number of maximum machine groups: 2
  (6) About the parameter setting(ManualGuide i Simulation function)
      Please do not change setting to the following parameters.
        - Parameter No.14791#0=0
[08] Notes
  (1) About the full screen display at the window mode
      Full screen might not be able to be executed according to the kind of the
      LCD display of the PC. These are hardware limitations.
      The full screen correspondence can be confirmed on the BIOS screen when
      the PC starts.
  (2) About the file Delete by anti virus software false recognition
      A case where "NCGuide.exe" included in this software is deleted
      by anti virus software false recognition is confirmed.
      In this case, file is deleted accidentally.
      If the file is deleted, please follow the procedure below:
      (a) Add the following folder to the scan exception settings for
          antivirus software.
            C:\Program Files (x86)\FANUC\NCGuide
      (b) If "NCGuide.exe" is deleted, please carry out
          the repair installation of CNC GUIDE after procedure (a).
[09] Update history
   Ver 1.00(2006.9.11)
        - First edition
   Ver 2.00(2006.11.01)
        - C language executor simulation function added
        - Macro executor simulation function added
        - The following problems are corrected.
          +Warning is displayed at the return from the full-screen display
           in the window mode
          +Parameter NO.11412 or more cannot be punch and read.
          +The path change cannot be executed by the operation from the PC key.
        - Setting the memory card folder becomes possible.
          The path is written in "< MEMCARD></MEMCARD >" of SimBaseSetting.xml.
          Example) <MEMCARD>c:\ncguide_memcard</MEMCARD>
        - The item was able to be displayed sorting and search in the option
          setting tool.
        - Update to CNC System Version 23.1
   Ver 2.10(2006.12.25)
      [NCGuide/NCGuidePro]
          +The display of version information is not correct.
      [ManualGuide i]
        - The customizing data can be arranged in the \user folder.
          Arrangement in the '.\from' folder under the machine composition
          folder was enabled.
          (It is assumed that .\user folder is priority when there is a file
           in both folders. )
        - The speed of drawing on the screen has been improved.
          + It hangs up when operating it when multi WIN is displayed.
      [C language executor]
          + If the putchar function is called, it becomes an error.
          + When the application is compiled, Warning of a double definition
            of the O_RDONLY symbol is generated.
        - The prototype declaration of the following function is added
          to the header file.
           os_get_chngappstr, crt_reguserchar_col, gr_dispfstr_col
   Ver 2.20(2007.1.26)
        - It corresponds to save the variable of sramver.c.
          Please refer to
          "\doc\C language executor-About save the variables in sramver.c.pdf"
          for details.
        - It is corrected that the following function was returned because of
          the error.
           aux_file_mount, aux_file_unmount
   Ver 2.30(2007.2.23)
          + When English has been selected, Japanese message is displayed
            in the key arrangement tool.
          + When 101/102 keyboards are used, cannot key input correctly.
          + When the split program list screen is displayed, SHIFT+Up/Down
            cannot be operated.
          + It corresponds to operate the softkey by the click on the screen
            at the picture mode.
        - The full screen at the window mode might not be displayed according
          to the PC, and the note is added to README.
        - When "/MULTI_DISP" is specified for the argument of Simbase.exe
          when the multi monitor is used, the NC guide is displayed in the
          second monitor.
          This function is effective only the picture mode.
        - When the network license server is used, it is enabled that it is
          environment variable NSP_HOST setting with PC that uses the NCGuide.
          IP address of the license server is specified for environment
          variable NSP_HOST.
          The packet is sended only to the license server by this setting.
        - "M30" is added at the program end of the machine configuration
          setting "1path-3axis-M" of the sample.
      [ManualGuide i]
          + When the format of the memory card is executed, an illegal message
            is displayed.
          + If the chdir function is used, the application error might be
            occurred.
          + The current drive is not correctly changed by the chdrive function.
        - Added mgi_jmp.h file.
      [MACRO executor]
        - Using key operation (SHIFT+1-5) for debugging function became
          possible. (NGGuidePro Only)
   Ver 2.40 (2007.3.27)
          + When the machine composition setting is copied with the machine
            composition setting tool, the folder for the machine composition
            setting is not copied.
          + When the NC guide is executed after the machine composition
            setting of the sample is deleted, installation CD is demanded.
          + When "/MULTI_DISP" displayed secondarily in the multi monitor is
            started, it is not likely to be able to display it correctly.
          + It is likely not to operate correctly about environment variable
            NSP_HOST correspondence.
          + The alarm history screen and the Maintenance information screen
            were displayed.
            It was corrected that it was not displayed.
        - It corresponds to the memory card folder for each machine composition.
          If "MEMCARD" folder is made for the folder for each machine
          composition, the folder becomes the memory card folder of the machine
          composition.
        - The machine composition setting data protection function is added.
          This function is used according to the function of the C language
          executor.
        - Option setting tool
          When the function name name was searcheded, neither the capital letter
          nor the small letter of the alphabet were distinguished.
        - The following option was not registered.
          Control axis detach, Tool geometry size data 100-pairs, 300-pairs
          + A mkdir and chdir function operate correctly.
          + The start argument for debugging "/CEXE_PAUSE" was able to be used
            by the NCGuide.
            It is possible to use it only by the NCGuidePro.
        - It was corrected that kind setting of run time in the setting of
          the Release build of the sample project was improper.
          (Originally unnecessary DLL was needed. )
           Before: RuntimeLibrary="2"
           After: RuntimeLibrary="0"
      [MANUAL GUIDE i]
        - The following improvements are added.
          + The function of MANUAL GUIDE i BY70/23D version can be used.
          + The screen switch speed from NC screen to MANUAL GUIDE i screen
            has been improved.
          + You can select execution mode of the machining simulation with
            rotation tool.
            No.27311#5=0 : Speed priority mode
            No.27311#5=1 : Accuracy priority mode
          + When NCGuide is reactivated, the color setting of tool path drawing
            for the machining simulation is initialized.
          + In the memory card I/O function, it has been corrected not to
            display the [FORMAT] soft key which did not work by the NC guide
          + The display of tool path falls into disorder when "Expansion,
            Reduction or Rotation" of tool path drawing is operated.
          + NCGuide is not activated when the parameter No.14791#0 is set to 1.
          + Machining simulation is stopped at the waiting M code for each path
            machining simulation (P27309).
   Ver 2.50 (2007.6.29)
      [PMC]
          + The function of PMC system software 40A0/18 version can be used.
          + The setting to hide the [PMC] menu is added on the Machine
            composition setting window.
        - The following problem is corrected.
          + The 1st ladder of Machine signal simulator did not work,
            when the number of PMC path of PMC simulation function is one,
            "PMC Memory-C" is selected, and 2nd and 3rd ladder of Machine
            signal simulator are empty.
   Ver 2.60 (2007.8.6)
      [MANUAL GUIDE i]
          + When X coordinate of start point is equal to X coordinate of end
            point in the drawing during machining simulation, the small arc
            segment is drawn as the round circular arc.
          + When one of basic three axes is set to the fourth axis and up,
            machining simulation of MANUAL GUIDE i might not work correctly
            after execution of cutter compensation.
   Ver 2.70 (2007.10.29)
          + The following option was able to be assumed to be effective.
            SPINDLE ANALOG OUTPUT FUNCTION, SPINDLE ANALOG OUTPUT FUNCTION
          + It corresponded to the license key making tool Ver2.0 for the
            machine composition setting data protection function.
          + The file list of the memory card is not displayed on the program
            list and the ALL/IO screen.
          + The space character could not be input with PC keyboard.
          + When the focus exists in the MDI key window at the window mode,
            the some keys("<>/*-+.()[]") could not be input.
      [MANUAL GUIDE i]
        - The following improvement is added.
          + The macro software of MANUAL GUIDE i is updated to the following
            version.
              BJ11/19
              BH11/19
          + When unit of data is inch, if the axis command of tilting tool is
            executed in animated drawing in MANUAL GUIDE i, a tool is drawn by
            the tilt of only 1/10 of the command.
          + In case of setting the C axis an axis parallel to the Y axis, when
            an arc was made by the contour programming in ZC plane at MANUAL
            GUIDE i, the circular command with reverse rotation was outputted
            to program memory.
          + In the realloc function of C Language Executor, if the specified
            DRAM memory size is larger than the one actually allocated by the
            application, the specified size of DRAM memory is allocated.
          + In the following functions of C Language Executor, even if the
            value is read/write specifying the memory address of the PMC data
            directly, the value cannot read/write correctly.
              pmc_rdpmcchar
              pmc_wrpmcchar
      [MACRO executor]
          + The position of the screen click to operate a soft key was not
            correct at the 15inch screen mode.
          + The loading was not able to be done correctly when the MEM file
            of MACRO executor was a specific size occasionally.
   Ver 2.80 (2007.11.22)
      [MACRO executor]
          + When the LCD size is selected 15 inches, right five softkeys can't
            be operated.
      [MANUAL GUIDE i]
          + MANUAL GUIDE i function has been updated to the function equivalent
            to system software BY70/26A.
          + The following functions can be changed to active or inactive by
            a parameter.
            Milling cycle, Turning cycle, Animation
   Ver 2.90 (2008.04.07)
          + It was corrected to the following option number.
            SERIAL SPINDLE INTERFACE       : J850
            SPINDLE ANALOG OUTPUT FUNCTION : J860
          + Tool offset function might not work correctly.
          + The following functions are added.
            cnc_rdtlgeomsize_ext (read Tool geometry size data)
            cnc_wrtlgeomsize_ext (write Tool geometry size data)
   Ver 2.92 (2008.07.17)
          + Parameter No.1815#5(APC) was invalidated.
   Ver 3.00 (2008.08.04)
        - Update to CNC System Version G111/49.0,G113/32.0
        - It corresponded to the following G code.
          G77 (turning cycle)
          G78 (screw cycle)
        - Apply to FANUC PICTURE for NCGuidePro.
        - Apply to FOCAS2 for NCGuidePro.
        - The following options were able to be used.
            TURKISH DISPLAY
            RUSSIAN DISPLAY
            SELECTION OF FIVE OPTIONAL LANGUAGE
            TOOL MANAGEMENT EXPANSION B
            TOOL ATTACHMENT /DETACHMENT MANAGEMENT FUNCTION
      [MANUAL GUIDE i]
            to system software BY70/30.
          + In the machining simulation of MANUAL GUIDE i, a hole on
            cylindrical surface was not cut correctly when the animated
            drawing by a milling tool was performed in giving priority to
            cutting off (Parameter No.27311#5=1).
          + The size of DRAM memory that can be used in C Executor has been
            expanded up to 8MB.
          + Displaying and reading Turkish message is available.
          + Displaying and reading Russian message is available.
            cnc_chglang   (Switches the display language on the CNC screen)
            cnc_rdmag_property  (Read the magazine property data)
            cnc_wrmag_property  (Write the magazine property data)
            cnc_delmag_property (Delete the magazine property data)
            cnc_rdpot_property  (Read the pot property data)
            cnc_wrpot_property  (Write the pot property data)
            cnc_delpot_property (Delete the pot property data)
            cnc_rdparainfo      (Read parameter data information)
            cnc_machine3        (Read machine position of controlled axis (3))
            cnc_rdjogdrun       (Read jogging speed or dry run speed)
            cnc_confirm_restart
                          (Confirmation for restarting after program editing)
            cnc_prot_pswinp     (Sets/changes the operation level)
            cnc_prot_pswcan
                          (Changes the operation level to a level from 0 to 3)
            cnc_prot_pswchg     (Changes the operation level password)
            cnc_prot_pswinit    (Initializes the operation level password)
            cnc_wrprt_lvl
                          (Changes the change protection level/output
                           protection level of each data item)
            os_getmemstatus     (Read the heap memory information)
   Ver 4.00 (2008.09.12)
        - The FS0i-D version was added.
          It is possible to use this with the hardware key since the Ver4.0.
      [PMC]
          + The function of PMC system software 40A0/22 version can be used,
            including "Function Block function".
   Ver 4.10 (2009.01.16)
        - The option list of FS31i version that existed in the manual was
          corrected.
          + Hang up might occur at the step execute when the application is
            debugged.
      [MANUAL GUIDE i]
            to system software BY70/35.
   Ver 4.20 (2009.04.16)
        - The package for the update was added.
          1)NCGuide(Upgrade for addition of CNC model:1-30Users)
                                                  A08B-9010-J740 - J743#ZZ11
          2)NCGuidePro(Upgrade for addition of CNC model:1-30Users)
                                                  A08B-9010-J745 - J748#ZZ11
          3)NCGuide/NCGuidePro(Upgrade for CNC software)
                                                  A08B-9010-J750#ZZ11
        - The hardware key upgrade tool was added.
          + It was corrected that real feed speed had not been correctly
            displayed. (FS31i version )
          + It was corrected might the generation of the application
            exception in the during starting.
        - The following options have been available.
          NONVOLATILE MEMORY EXPANSION 64K
          NONVOLATILE MEMORY EXPANSION 256K
      [PMC]
          + In FS0i-D, Ladder step option included in "Package 1" or
            "Package 2" could not be enabled correctly.
          + SET/RST instructions in Common Line Control area (COM - COME) could
            not be correctly controlled by ACT signal of COM instruction.
          + In FS31i-A or FS0i-D,if only PMC Simulation Function is
            enabled, options could not be changed.
   Ver 4.30 (2009.12.01)
        - Update to CNC System Version G114/16.0
        - NCGuide/NCGuidePro might not start or run very slowly by the
          influence of other applications like the anti virus software etc.
          In that case, the level of the timer is set to SimBaseSetting.xml
          as follows.
          Example) <TIMER_LEVEL>3</TIMER_LEVEL>
          The value from 3 to 10 can be set to this setting.
          This value is 2 when the unset.
          The influence can be evaded by setting 3 or 4 usually.
            TILTED WORKING PLANE COMMAND WITH GUIDANCE
            FLEXIBLE PATH AXIS ASSIGNMENT
        - The application error might generate NCGuide/NCGuidePro in the during
          starting. (The problem of WindowsOS is a cause. )
          In that case, the following error is output to log file(log\SIM.LOG).
             at System.Diagnostics.NtProcessManager.GetProcessInfos
                                                (PerformanceCounterLib library)
          It was corrected that this error did not occur.
      [PMC]
          + In FS31i-A, the function of PMC system software 40A0/25
          + In FS0i-D, the function of PMC system software 40B0/02
          + In FS31i-A, the following functions are added.
            crt_chgvskpage   (Change a page of one-touch menu)
            gr_dispvskmenu   (Get the screen number and draw the vertical
                              soft key character string)
            cnc_pdf_rdmainpt (Read executing block number of main program)
          + In FS31i-A, when accessing the memory card by specifying
            drive C, the following functions have been available.
            fseek, lseek, ftell, tell, feof, eof, fgetpos, fsetpos, rename,
            rewind, getcwd, _chdrive, _getdrive, _dos_getdiskfree
          + In FS31i-A, the following functions have been available.
            mkdir, rmdir, chdir
          + In FS31i-A, when the _dos_getdiskfree function is executed,
            - When "1" is specified for the argument, information on not SRAM
              disk but drive A of the personal computer is acquired.
            - When "2" is specified for the argument, information on not
              memory card but drive B of the personal computer is acquired.
            - When "3" is specified for the argument, information on not
              memory card but drive C of the personal computer is acquired.
   Ver 4.40 (2010.04.01)
        - It works and support for following Windows Operating system.
          Windows(R) Vista Business, Windows(R) 7 Professional
        - G code skip function was added.  (FS31i version )
          + It was corrected that feedrate command value and real feed speed was
            defferent. (FS31i version )
          + It was corrected that when NCGuide or NCGuidepro started with mode
            of selecting machine composition, the machine composition selection
            was canceled and application error occurred.
      [MANUAL GUIDE i]
          + When a groove for turning cycle has step figure and is machined
            by dividing in some layers, residual part might be left.
   Ver 4.50 (2010.07.01)
      [NCGuide]
        - Academic package was added.
          1)for Classroom       A08B-9010-J751#ZZ11
          2)for Homework        A08B-9010-J752#ZZ11
        - Apply to conversational macro screen for 8.4 inch display.
          (for FS31iA version)
      [MANUAL GUIDE i]
          + The value of the tool data base is not saved.
   Ver 5.00 (2010.11.01)
        - The FS31i-B and FS35i-B version was added.
          It is possible to use this with the hardware key since the Ver5.0.
        - Machine Operator's Panel was added. (NGGuidePro Only)
          + The diagnosis operation of the license authentication setting tool
            might fail.
          + A hardware key cannot be updated.
        - "C-language Executor Library (for conversion from PMC C-language)"
          for NCGuide/NCGuidePro was added in the sample.
      [MANUAL GUIDE i]
          + In FS31i-B, the function of MANUAL GUIDE i system software
            BX71/02version can be used.
          + In FS31i-A, MANUAL GUIDE i function has been updated to the
            function equivalent to system software BY70/44.
          + In FS0i-D, MANUAL GUIDE i function has been updated to the
            function equivalent to system software BX32/10.
   Ver 5.10 (2011.04.15)
          Windows(R) 7 Professional 64bit
            CONSTANT SURFACE SPEED CONTROL
            INTERRUPTION TYPE CUSTOM MACRO (FS31i-B)
          + At program list screen or all I/O screen, even if all files in
            MEMCARD are deleted, the last file cannot be deleted.
          + When the display language of invalid option is selected,
            NCGuide/NCGuidePro doesn't start.
   Ver 5.20 (2011.06.08)
          + When the customizing function of MANUAL GUIDE i is used,
            NCGuide/NCGuidePro doesn't sometimes start.
          + The installation of the NCGuide Academic package fails.
   Ver 5.30 (2011.06.30)
            MULTI-STEP SKIP FUNCTION (FS31i-B)
            INTERRUPTION TYPE CUSTOM MACRO (FS0i-D)
          + The coordinate of a rotary axis is illegal during cylindrical.
          + NCGuide/NCGuidePro might fail to start up in the environment with
            plural network adaptors.
          + The dialog displayed when selecting it to install SB7 might be
            hidden to the back side of the installer.
   Ver 6.00 (2011.10.31)
        - The FS31i-LB and FS35i-PB version was added.
          It is possible to use this with the hardware key since the Ver6.0.
        - Update to CNC System of FS31i-B Version G411/15.0
            FANUC PICTURE EXECUTOR (FS31i-B)
        - In FS35i-B, 15 inch display was able to be used.
          + The address written by real-time custom macro is illegal.  (FS31i
            -B)
          + When Max. number of simultaneously displayed axes is 10 or more,
            offset screen is displayed and application error occurred.
   Ver 6.10 (2011.12.09)
            Extended conversational macro function (FS31i-B)
              Extended conversational macro function (option) is a function
              that makes FS20i-B macro program an acutuate way with
              FS30i/31i/32i-B.
              The following instructions become available by this option.
              + Window display (G270, G271)
              + Display of external characters at any position (G281)
              + Shift and scale in the graphic coordinate system (G208)
              This option is available in 8.4" display unit only.
              (Refer to "Macro Executor for Series20i" of the appendix of
               Programming Manual (B-61803E-1) for details. )
          + When files in memorycard are displayed at PMC data I/O screen,
            NCGuide/NCGuidePro is turned off illegally.  (FS31i-B)
      [MANUAL GUIDE i]
          + In FS31i-B, MANUAL GUIDE i function has been updated to the
            function equivalent to system software BX71/06.
            function equivalent to system software BY70/47.
            function equivalent to system software BX32/13.
        - The following function were able to be used.
            Set-up guidance functions
   Ver 6.11 (2012.03.01)
        - Update to CNC System of FS31i-B Version G411/23.0
        - The following options are added.
            Optional block skip (FS31i-B)
          + In Lathe/Machining center G code system switching function, the
            parameter No.25595 that changes the order of the display of the
            axis on position display screens has been added. (FS31i-B)
          + When lathe/machining center G code system is switched, the
            parameter No.13000#4 which cancels command for maximum spindle
            speed clamping has been added. (FS31i-B)
        - In the screen of tool offset for milling and turning function,
          the following improvement has been added.
          + Tool number display
          + Guidance display for imaginary tool nose
          + Switching protection of geometry/wear offset by soft key operation
          + Prohibition against cursor movement to protected item
        - In the tool geometry size data setting screen,
          + Coordinate axis display in guidance
   Ver 6.20 (2012.06.01)
        - Update to CNC System of FS31i-LB Version G4C1/13.0
        - Update to CNC System of FS31i-PB Version G4E1/12.0
        - The movement of the window has been enabled at the picture mode.
      [MANUAL GUIDE i]
        - The following screens are able to be used.
          + Setting Window of offset number and tool number
          + Tool Management Data Window
          + Tool Life Data Screen
          + Tool Life Data List Screen
          + When MANUAL GUIDE i is effective,
            the application exception might occur in rare cases.
   Ver 6.30 (2012.06.22)
      [PMC]
        - In FS31i/35i-B and FS31i-LB/PB, Machine Signal simulator
          function has become available.
        - In FS31i/35i-B and FS31i-LB/PB, PMC Simulation function has
          been updated to correspond to 40A5/09.
          (except Ladder dividing management function)
   Ver 6.32 (2012.09.07)
          + The message of macro alarm is illegal displayed on the alarm
            history screen. (FS31i-B)
          + In the program word editing function, the word which first
            character is '[' can not be input. (FS31i-A)
          + The wrong value is returned by cnc_statinfo2() with Ethernet
            connection. (FS31i-A, FS0i-D)
      [MANUAL GUIDE i]
            function equivalent to system software BX71/08.
            function equivalent to system software BY70/49.
            function equivalent to system software BX32/15.
          + Hang up might occur at cycle input screen.
   Ver 7.00 (2012.10.01)
        - FS32i-B Function for transfer line was added.
          It is possible to use this with the hardware key since the Ver7.0.
          The installer is different from other CNC model.
          Please use the following installer.
            (DVD):\Setup\NCGuide_Line\en\setup.exe
          Operator's manual is the following file.
            (DVD):\doc\NCGuide,NCGuidePro Function for transfer line.pdf
        - Update to CNC System of FS31i-B Version G411/32.0
          + If the move command of chopping axis is specified after chopping
            cancel (G80), the movement of the chopping axis might not start.
            (FS31i-A/B)
      [PMC]
        - In FS31i-B, FS31i-LB/PB, and FS32i-B Function for transfer line,
          Ladder dividing management function has been supported.
   Ver 7.01 (2012.12.14)
            PERIPHERAL AXIS CONTROL (FS31i-B)
            EMBEDDED MACRO (FS31i-B)
   Ver 8.00 (2013.04.15)
        - The FS30i-B G311/35.0 version was added.
          It is possible to use this with the hardware key since the Ver8.0.
        - Update to CNC System of FS31i-B Version G411/35.0
        - In FS31i-A/-B, the build environment of C Language Executor
          application has been updated to the function equivalent to Series
          30i C Language Libraly for C Language Executor GZ0I/5.9.
        - The maximum number of servo axis and spindles has been enhanced.
          (FS0i-D)
            SMOOTH INTERPOLATION (FS31i-B)
            NURBS INTERPOLATION (FS31i-B)
            SMOOTH TCP (FS31i-B)
            TOOL CENTER POINT CONTROL (FS31i-MOD B)
            MACHINE CONFIGURATION SELECTING FUNCTION (FS31i-B)
            3 DIMENSIONAL CIRCULAR INTERPOLATION (FS31i-B)
            MACHINING QUALITY LEVEL ADJUSTMENT (FS31i-B)
            3-DIMENSIONAL MANUAL FEED (FS31i-B)
            MACHINING CONDITION SELECTING FUNCTION (FS31i-B)
            3-DIMENSIONAL CUTTER COMPENSATION (FS31i-B)
            INCLINED ROTARY AXIS CONTROL (FS31i-B)
            PROGRAMMABLE RAPID TRAVERSE OVERLAP (FS31i-B)
            NANO SMOOTHING (FS31i-B)
            WORKPIECE SETTING ERROR COMPENSATION (FS31i-B)
          + Only low-order 1 byte of signal is written by word-by-word or
            double word-by-double word in real-time custom macro function.
   Ver 8.01 (2013.04.23)
          + When Peripheral Axis Control is enabled, the offset does not work
            even if the tool offset instruction in lathe systems.
   Ver 8.02 (2013.08.05)
        - Update to CNC System of FS0i-D Version 30.0.
        - The option diagnose was enabled.
            MANUAL HANDLE FEED 1-UNIT (FS0i-D, FS30i-B, FS31i-B)
            MANUAL HANDLE FEED 2/3-UNITS (FS0i-D, FS30i-B, FS31i-B)
      [MANUAL GUIDE i]
            function equivalent to system software BX71/11.
            function equivalent to system software BY70/52.
            function equivalent to system software BX32/18.
          + A part of message defined with the user customizing file might be
            lacked and it be displayed.
   Ver 8.10 (2013.08.30)
        - Update to CNC System of FS35i-B Version G601/12.0.
          + The parameter TZ1, TZ2, TZ3(No.11851#2, No.11852#2, No.11853#2) has
            been added.
            It changes the number of tool offset value in Peripheral axis
            control to zero. (FS31i-B)
            ADDITION OF CUSTOM MACRO COMMON VARIABLES 1000 (FS30i-B, FS31i-B)
          + In FS0i-D, the following functions have been available.
            mkdir, rmdir, chdir
          + In FS0i-D, when the _dos_getdiskfree function is executed,
   Ver 8.11 (2014.02.03)
          + In Milling's Tool length compensation of Tool offset for milling
            and turning function, the parameter bit 7 (ZBO) of No.25581 that
            selects the setting of always using the compensation value of
            Z-axis/length has been added. (FS30i-B, FS31i-B, FS32i-B)
      [MANUAL GUIDE i]
          + High speed of the display of the life management data list screen
            is done.
          + Measurement cycle used with 18i-TB can be enabled in FS31i-B.
          + The problems related to manual measurement and measurement cycle.
   Ver 9.00 (2014.06.30)
        - The NCGuidePro was integrated into the NCGuide.
          (NCGuidePro were removed after this.)
        - Update to CNC System of FS30i-B Version G311/56.0.
        - Update to CNC System of FS31i-B Version G411/56.0.
          [FS30i-B, FS31i-B]
          + Custom macro variable name 31 characters(R583)
          + Nozzle compensation(R567)
          + Virtual MDI key(S883)
          + Machine State Monitoring Function(R717)
          [FS30i-B, FS31i-B, FS0i-D]
          + Software operator's panel(J960)
          + Software operator's panel general purpose switch(J961)
          + The display of feedrate is improved when
            acceleration/deceleration before interpolation was enabled.
          + After the old version is uninstalled when the old version is
            installed, the installation is done.
          + When the file extension is a small letter, the file cannot be read.
          + The switch to an illegal screen is occurred by RESET key input on
            the program screen when the program restart option is effective.
      [PMC]
        - PMC simulation function of FS0i-D has been updated to be equivalent
          to 40B0/11.
        - The following options have been available:
          [FS0i-D]
          + Ladder step Max.64,000 steps (Package 1 / R006#64K)
          + Ladder step Max.24,000 steps (Package 2 / R002#24K)
          [FS32i-B Function for transfer line]
          + Step sequence function (S982)
        - The following improvements have been applied:
          + Main and sub panel windows of Standard Machine Operator's Panel can
            be minimized also in picture mode.
        - The following problems have been corrected.
          + The size of I/O operation panel might change at start up.
   Ver 9.01 (2014.09.30)
          + Cycle Time Estimate Function is not correctly installed.
   Ver 9.10 (2014.11.17)
        - The following kind was added to the Academic Package.
          + for Classroom(32 Users)   A08B-9010-J761#ZZ12
          + for Homework(3 Years)      A08B-9010-J762#ZZ12
        - The following options were able to be used at the Academic Package.
          [FS30i-B, FS31i-B, FS31i-A, FS0i-D]
          + Macro Executor
          + C-language Executor
          + FANUC picture
   Ver 10.00 (2015.02.05)
        - The FS0i-F/4.0 version was added.
          [FS31i-A, FS30i-B, FS31i-B, FS35i-B]
          + FANUC AUTO HMI-NC (R572)
          + FANUC AUTO HMI-NC screen enhancement 1 (R653)
      [PMC]
        - PMC simulation function of FS30i-B has been updated to be equivalent
          to 40A5/19.
      [MANUAL GUIDE i]
            function equivalent to system software BX71/14.
            function equivalent to system software BY70/55.
          + In FS0i-F, MANUAL GUIDE i function (equivalent to system
            software BX33/02) was added.
            function equivalent to system software BX32/21.
          + Hang up might occur when arbitrary free figure of cycle is
            drawn in base screen.
   Ver 11.00 (2015.10.19)
        - C language executor application protection function was added.
        - Update to CNC System of FS30i-B Version G311/74.0.
        - Update to CNC System of FS31i-B Version G411/74.0.
          [FS30i-B]
          + 5-Axis Machining Condition Setting Function(R721)
          [FS30i-B, FS31i-B]
          + CNC Screen Display for 19"LCD(R624)
          [FS0i-F]
          + Function for Loader Control(R417)
          + Addition of Loader Control Path(R418)
        - The FS31i-WB/14.0 version was added.
      [PMC]
          to 40A5/21.
   Ver 12.00 (2016.04.28)
        - The FS30i-B which supports iHMI function was added.
          However, only 15-inch of picture mode is supported.
          Therefore, depending on the resolution of the display, NCGuide may not
          fit in the display.
          If the entire of NCGuide is displayed, it is recommended to set the
          folloing resolution of the display.
             Resolution: 2048 * 1536 (QXGA)
        - Update to CNC System of FS31i-WB Version G4A1/15.0.
          [FS30i-B, FS31i-B]
          + Spindle Orientation (J853)
          + Spindle Output Switching Function (J854)
          + Extended Spindle Orientation (J861)
          + Extended Spindle Output Switching Function (J862)
          The above function supports the signal only.
          [FS31i-LB]
          + T-axis and C-axis Simultaneous Control (S907)
          + Addition Of Cutting Condition Data (S912)
          [FS31i-PB]
          + Operation history was supported. (FS30i-B, FS31i-B)
          + C language executor function for reading and writing of PMC parameter was
          + Hindi language was supported. (8.4 inch display of FS0i-F)
          + Spindle speed and motor speed in consideration of the S command and
            the gear ratio is displayed on the spindle monitor screen.
            (FS30i-B, FS31i-B)
          + Blank is displayed on each spindle information of the spindle
            information screen.(FS30i-B, FS31i-B)
          + The wire option can not be set on FS31i-WB.
      [PMC]
        - The function of save/restore X signal state was added.
        - The signal operation replay function is improved.
          (According to each machine configuration, the folder path for
           the signal operation file is changed.)
        - The function of key top customization of main panel was added.
        - The display of only main panel for the standard machine operator's
          panel is applied.
   Ver 12.10 (2016.07.29)
        - CNC System of FS30i-B was updated to version G311/84.0.
        - CNC System of FS31i-B was updated to version G411/84.0.
        - CNC System of FS30i-B iHMI was updated to version G311/84.0.
        - iHMI application of FS30i-B iHMI was updated to version 3.0.
          [FS30i-B, FS30i-B iHMI, FS31i-B]
          + Gentle normal direction control (J986)
          + Window mode was added to display mode. (FS30i-B iHMI)
          + 10.4 inch and 19 inch were added to CNC display size. (FS30i-B iHMI)
          + Protection key signal was able to be used. (FS30i-B, FS31i-B)
          + Several options can be set in a single file at option setting tool.
            (FS30i-B, FS30i-B iHMI, FS31i-B)
          + Operator's panel was added at window mode.
      [PMC]
          to 40A5/24.
        - PMC simulation function of FS0i-F has been updated to be equivalent
          to 40B2/05.
   Ver 12.11 (2016.09.13)
        - Touch panel operation became provisional possible. in C language executor
          function.
   Ver 13.00 (2016.11.30)
        - FS31i-B5 was added.
        - CNC System of FS30i-B was updated to version G311/86.0.
        - CNC System of FS31i-B was updated to version G411/86.0.
        - iHMI application of FS30i-B iHMI was updated to version 6.0.
          + 3D interference check with personal computer function (R542)
        - The following problem was corrected.
          + The Option Setting dose not start without Excel 2010 installed.
   Ver 14.00 (2017.02.22)
        - Power Motion i-A(PMi-A) was added.
        - CNC System of FS30i-B and FS30i-B iHMI were updated to version G311/90.0.
        - CNC System of FS31i-B was updated to version G411/90.0.
        - CNC System of FS0i-F was updated to version 28.0.
        - iHMI application of FS30i-B iHMI was updated to version 9.2.
        - Floating point functions of PMC was able to be used.(FS0i-F)
          + Smooth tolerance control(R696)
          + Multi-path editing function(R615)
   Ver 15.00 (2017.05.28)
        - FS32i-B was added.
        - CNC System of FS30i-B and FS30i-B iHMI were updated to version G311/93.0.
        - CNC System of FS31i-B was updated to version G411/93.0.
        - CNC System of FS0i-F was updated to version 32.0.
        - iHMI application of FS30i-B iHMI was updated to version 11.0.
        - Manual Guide i System of FS31i-A was updated to version BY70 / 62.
        - Manual Guide i System of FS30i/31i-B and FS30i-B iHMI was updated to version BX72 / 04.
        - Manual Guide i System of FS0i-D was updated to version BY32 / 29.
        - Manual Guide i System of FS0i-F was updated to version BY33 / 11.
          + 3-dimensional tool compensation(J727)
          + Tool offset conversion function(R691)
          + Quick program restart(R630)
          + The number of custom macro variable name 1000(R323)
          + The number of custom macro variable name 4000(R324)
          + "Picture Mode - Horizontal" was display mode.
   Ver 15.10 (2017.07.31)
        - CNC System of FS30i-B and FS30i-B iHMI were updated to version G311/97.0.
        - CNC System of FS31i-B was updated to version G411/97.0.
        - CNC System of FS31i-B5 was updated to version G431/97.0.
        - CNC System of FS32i-B was updated to version G501/97.0.
        - CNC System of FS0i-F was updated to version 35.0.
        - iHMI application of FS30i-B iHMI was updated to version 12.1.
          + Groove cutting function by continuous circle movement(S854)
          [FS30i-B, FS30i-B iHMI, FS31i-B, FS32i-B]
          + High speed program check(S880)
          + High precision oscillation function(R662)
          + Tool management function for multi-edge tools(R681)
   Ver 15.20 (2017.10.31)
        - CNC System of FS30i-B and FS30i-B iHMI were updated to version G311/99.0.
        - CNC System of FS31i-B was updated to version G411/99.0.
        - CNC System of FS31i-B5 was updated to version G431/99.0.
        - CNC System of FS32i-B was updated to version G501/99.0.
        - CNC System of FS0i-F was updated to version 37.0.
        - CNC System of FS31i-LB was updated to version G4C3/14.0.
        - CNC System of FS31i-PB was updated to version G4E1/36.0.
        - iHMI application of FS30i-B iHMI was updated to version 14.3.
          [FS31i-B]
          + High-speed Smooth TCP(R677)
          [FS31i-LB]
          + 2 LASERS CONTROL FUNCTION(S911)
   Ver 15.30 (2018.01.15)
          + Switching from C language executor screen or Manual Guide i screen
            to CNC screen is not possible. (FS0i-F)
   Ver 15.40 (2018.06.22)
        - CNC System of FS30i-B and FS30i-B iHMI were updated to version G31A/07.0.
        - CNC System of FS31i-B was updated to version G41A/07.0.
        - CNC System of FS31i-B5 was updated to version G43A/07.0.
        - CNC System of FS32i-B was updated to version G50A/07.0.
        - CNC System of FS0i-F was updated to version 44.0.
        - The sample ladder program of PMi-A was applied to the standard machine operator's panel.
          [FS30i-B iHMI]
          + iHMI set-up guidance (R910)
          + iHMI machining cycle (for 1 path system) (R911)
          + iHMI machining cycle (for 2 path system) (R912)
          + iHMI machining cycle (for 3 path system) (R913)
          + iHMI machining cycle (for 4 path system) (R914)
   Ver 15.50 (2018.12.26)
        - CNC System of FS30i-B and FS30i-B iHMI were updated to version G313/12.0.
        - CNC System of FS31i-B was updated to version G413/12.0.
        - CNC System of FS31i-B5 was updated to version G433/12.0.
        - CNC System of FS32i-B was updated to version G503/12.0.
        - CNC System of FS0i-F was updated to version D4G2(D6G2)/13.0.
        - iHMI application of FS30i-B iHMI was updated to version 23.0.
        - Added Machine Composition Creation Tool for FS30i/31i/32i-B.(Excluding Academic package)
        - Added the function to launch NCGuide by double-clicking the Machine composition setting data.
          [FS30i-B, FS30i-B iHMI, FS31i-B, FS31i-B5]
          + HIGH-SPEED CYCLE MACHINING
          + High-speed cycle machining(J833)
          + High-speed cycle machining retract function(J663)
          + High-speed cycle machining skip function(S662)
          + High-speed cycle machining operation information(R609)
          + Spindle control switching function for high-speed cycle machining(R608)
          + High-speed cycle cutting additional variables A(J745)
          + High-speed cycle cutting additional variables B(J746)
          + High-speed cycle cutting additional variables C(S640)
          + High-speed cycle cutting additional variables D(R513)
          [FS31i-B]
          + Cutting point command(S996)
          [FS32i-B]
          + High-speed processing(S809)
          + Addition of workpiece coordinate system 300-pairs(J919)
       [FS30i-B, FS30i-B iHMI, FS31i-B, FS31i-B5, FS32i-B, FS0i-F, FS31i-LB, FS31i-PB, FS31i-WB, FS32i-B LINE]
        - Running speed of CNC simulation function was closer to the actual CNC.
        - Fixed an issue that may work slowly or may not work under Windows(R) 10 version 1703 or older.
   Ver 15.51 (2019.1.12)
        - The connectivity with FANUC LADDER-III and FOCAS2 on PC with two or more networks has been improved.
       [FS0i-D, FS30i-A, FS35i-B, PMi-A]
       [PMC]
        - PMC simulation function of FS30i-B has been updated to be equivalent to 40A7/01.
        - PMC simulation function of FS0i-F has been updated to be equivalent to 40B4/02.
   Ver 16.00 (2019.4.23)
        - FS0i-F Plus was added.
          CNC System is version D4G3(D6G3) / 01.
          Manual Guide i System is version BY34 / 11.
        - CNC System was updated to following series / version.
          + FS30i-B iHMI  : G313 / 22
          + FS30i-B       : G313 / 22
          + FS31i-B       : G413 / 22
          + FS31i-B5      : G433 / 22
          + FS32i-B       : G503 / 22
        - iHMI application of FS30i-B iHMI was updated to version 29.0.
        - Manual Guide i System was updated to following series / version.
          + FS30i-B       : BX72 / 14
          + FS31i-B       : BX72 / 14
          + FS31i-B5      : BX72 / 14
          + FS31i-A       : BY70 / 70
          + FS0i-F        : BX33 / 21
          + FS0i-D        : BX32 / 36
        - Flat design and dark gray display ware supported in FS0i-F.
          [FS30i-B, FS30i-B iHMI, FS31i-B, FS31i-B5, FS32i-B, FS0i-F]
          + Multi-language display Slovenian(R320)
          + Multi-language display Bulgarian(R686)
          + Multi-language display Rumanian(R694)
          + Multi-language display Slovak(R693)
          + Multi-language display Finnish(R726)
          + Multi-language display Vietnamese(R410)
          + Multi-language display Indonesian(R411)
          + Manual Guide i Extended axis name function(S789)
          + Manual Guide i advanced guidance function(S774)
          + C-language executor additional SRAM 512KB(S827)
          [FS30i-B, FS30i-B iHMI, FS31i-B, FS31i-B5, FS32i-B, FS31i-WB]
          + Manual handle feed multiple 10 million(R600)
          [FS0i-F]
          + Set-up guidance function(S771)
   Ver 16.01 (2019.5.24)
       [PMC]
        - PMC simulation function of FS30i-B has been updated to be equivalent to 40A7/03.
   Ver 16.02 (2019.5.30)
        - CNC System of FS31i-WB was updated to version G4A1/25.0.
   Ver 17.00 (2019.10.1)
        - FS0i-F Plus iHMI has been added.
          CNC System is version D4G3(D6G3) / 06.
        - Machine Composition Creation Tool for FS0i-F/FS0i-F Plus has been added.
        - CNC System has been updated to following series / version.
          + FS30i-B iHMI  : G313 / 29
          + FS30i-B       : G313 / 29
          + FS31i-B       : G413 / 29
          + FS31i-B5      : G433 / 29
          + FS32i-B       : G503 / 29
          + FS0i-F        : D4G3(D6G3) / 26
          + FS0i-F Plus   : D4G3(D6G3) / 06
        - iHMI software of FS30i-B iHMI was updated to version 33.0.
        - The following options have been added.(Excluding Academic package)
          [FS0i-F]
          + TURN MATE i (with touch panel)(S792)
          + TURN MATE i MDI key operation function(S794)
          + TURN MATE i NC program conversion function(S795)
          + TURN MATE i Expansion of Machining Cycle(S796)
          [FS0i-F, FS0i-F Plus]
          + MANUAL GUIDE 0i(S772)
       [PMC]
        - PMC System of FS0i-F and FS0i-F Plus has been updated to 40B4/03.
   Ver 17.10 (2019.10.11)
       [FS0i-F]
        - The machine composition setting data of TURN MATE i has been updated.
        - The machine composition setting data of MANUAL GUIDE 0i has been updated.
   Ver 18.00 (2020.1.29)
          + FS30i-B iHMI  : G313 / 32
          + FS30i-B       : G313 / 32
          + FS31i-B       : G413 / 32
          + FS31i-B5      : G433 / 32
          + FS32i-B       : G503 / 32
          + FS0i-F        : D4G3(D6G3) / 28
          + FS0i-F Plus   : D4G3(D6G3) / 08
          + FS30i-B       : BX72 / 16
          + FS31i-B       : BX72 / 16
          + FS31i-B5      : BX72 / 16
          + FS31i-A       : BY70 / 72
          + FS0i-F        : BX33 / 23
          + FS0i-F Plus   : BX33 / 23
          + FS0i-D        : BX32 / 38
       [FANUC CNC GUIDE](Excluding Academic package)
        - FS30i-B 32AX has been added.
          CNC System is version G323 / 32.
          Machine Composition Creation Tool does not support FS30i-B 32AX.
        - FS30i-B 48AX has been added.
          CNC System is version G333 / 32.
          For FOCAS2 function, please refer to the "Samples\FOCAS2\Readme2.txt".
          Machine Composition Creation Tool does not support FS30i-B 48AX.
       [FANUC CNC GUIDE Academic package]
          [FS0i-F]
   Ver 19.00 (2020.4.27)
        - The following CNC Systems have been added.
          + FS30i-B Plus  : G317 / 03
          + FS31i-B Plus  : G417 / 03
          + FS31i-B5 Plus : G437 / 03
          + FS32i-B Plus  : G507 / 03
          Machine Composition Creation Tool does not support.
          + FS31i-A       : G11D / 24
          + FS30i-B iHMI  : G313 / 36
          + FS30i-B       : G313 / 36
          + FS30i-B 32AX  : G323 / 36
          + FS30i-B 48AX  : G333 / 36
          + FS31i-B       : G413 / 36
          + FS31i-B5      : G433 / 36
          + FS32i-B       : G503 / 36
          + FS31i-WB      : G4A1 / 27
          + FS0i-F        : D4G2(D6G2)/31
          + FS0i-F Plus   : D4G3(D6G3)/11
          + FS30i-B       : BX72 / 19
          + FS31i-B       : BX72 / 19
          + FS31i-B5      : BX72 / 19
          + FS32i-B       : BX72 / 19
          + FS31i-A       : BY70 / 73
          + FS0i-F        : BX34 / 15
          + FS0i-F Plus   : BX34 / 15
          + FS0i-D        : BX32 / 39
        - Series / version number display of the CNC function was changed thoroughly to
          actual CNC.
          It influences the following functions.
          It is possible to return it to the past display with Setting Management Tool.
          + CNC screen display
          + FOCAS2 (cnc_sysinfo)
          + C language executor function (cnc_sysinfo)
          + FANUC PICTURE (sysinfo)
          + Macro Executor (window function)
          + PMC Ladder (window function)
       [PMC]
        - PMC System of FS31i-A has been updated to 40A0/32.
        - PMC System of FS30i/31i/32i-B has been updated to 40B7/07.
   Ver 19.10 (2020.8.20)
        - No longer necessary to set the environment variable NSP_HOST.
          + FS30i-B iHMI     : G313 / 40
          + FS30i-B          : G313 / 40
          + FS30i-B 32AX     : G323 / 40
          + FS30i-B 48AX     : G333 / 40
          + FS31i-B          : G413 / 40
          + FS31i-B5         : G433 / 40
          + FS32i-B          : G503 / 40
          + FS30i-B Plus     : G317 / 05
          + FS31i-B Plus     : G417 / 05
          + FS31i-B5 Plus    : G437 / 05
          + FS32i-B Plus     : G507 / 05
          + FS0i-F           : D4G2(D6G2)/33
          + FS0i-F Plus iHMI : D4G2(D6G2)/14
          + FS0i-F Plus      : D4G3(D6G3)/14
          + FS30i-B iHMI     : BX72 / 21
          + FS30i-B          : BX72 / 21
          + FS31i-B          : BX72 / 21
          + FS31i-B5         : BX72 / 21
          + FS32i-B          : BX72 / 21
          + FS30i-B Plus     : BX72 / 21
          + FS31i-B Plus     : BX72 / 21
          + FS31i-B5 Plus    : BX72 / 21
          + FS32i-B Plus     : BX72 / 21
          + FS31i-A          : BY70 / 74
          + FS0i-F           : BX34 / 17
          + FS0i-F Plus      : BX34 / 17
          + FS0i-D           : BX32 / 40
        - iHMI System has been updated to following series / version.
          + FS30i/31i/32i-B         : K777 / 40
          + FS30i/31i/32i-B Plus    : K779 / 05
          [FS30i/31i/32i-B, FS30i-B iHMI FS30i/31i/32i-B Plus, FS35i-B, PMi-A]
          + MIDDLE-LEVEL TASK OF C LANGUAGE EXECUTOR(R550)
          [FS30i/31i/32i, FS30i-B 32AX/48AX, FS30i-B iHMI, FS30i/31i/32i-B Plus]
          + NONVOLATILE MEMORY EXPANSION 64K(J993#64K)
          + NONVOLATILE MEMORY EXPANSION 256K(J993#256K)
          [FS31i-LB]
          + INTERFERENCE CHECK FOR ROTARY AREA(S643)
       [iHMI]
        - iHMI software was updated to following series / version.
          + FS30i-B iHMI     : K777 / 40
          + FS0i-F Plus iHMI : K779 / 5
        - The display of iHMI has been improved.
          + iHMI mode has been added in FS30i-B iHMI and FS0i-F Plus iHMI.
            Picture mode and window mode have been removed.
          + The following is supported.
            + Display multiple windows.
            + Display in any position of the windows.
          + Dual display is recommended.
   Ver 19.20 (2020.11.18)
        - iHMI has been enabled on the following models.
          Optional setting of "iHMI basic function(R901)" is required to use iHMI.
          + FS30i/31i/32i-B
          + FS30i-B AX32/AX48
          + FS31i-B5
          + FS31i-B5 Plus
          + FS0i-F Plus
        - The following integrated models have been removed.
          + FS30i-B iHMI
          + FS0i-F Plus iHMI
          + FS30i-B          : G313 / 43
          + FS30i-B 32AX     : G323 / 43
          + FS30i-B 48AX     : G333 / 43
          + FS31i-B          : G413 / 43
          + FS31i-B5         : G433 / 43
          + FS32i-B          : G503 / 43
          + FS30i-B Plus     : G317 / 08
          + FS31i-B Plus     : G417 / 08
          + FS31i-B5 Plus    : G437 / 08
          + FS32i-B Plus     : G507 / 08
          + FS0i-F           : D4G2(D6G2)/36
          + FS0i-F Plus      : D4G3(D6G3)/17
        - TURN MATE i System has been updated to following series / version.
          + FS0i-F           : BW02 / 04
          + FS0i-F Plus      : BW02 / 04
          TURN MATE i Expanded function(S947) is not supported.
          + FS30i/31i/32i-B         : K777 / 44
          + FS30i/31i/32i-B Plus    : K788 / 03
          [FS30i/31i/32i-B Plus, FS30i/31i/32i-B, FS30i-B 32AX/48AX, FS0i-F Plus, FS0i-F]
          + High-speed position switch(J987)
          [FS30i/31i/32i-B Plus, FS30i/31i/32i-B, FS30i-B 32AX/48AX, FS0i-F Plus]
          + iHMI basic function(R901)
          [FS30i/31i/32i-B Plus, FS30i/31i/32i-B, FS0i-F Plus]
          + iHMI set-up guidance(R910)
          + iHMI machining cycle(for 1 path system)(R911)
          + iHMI machining cycle(for 2 path system)(R912)
          [FS30i/31i-B Plus, FS30i/31i-B]
          + iHMI machining cycle(for 3 path system)(R913)
          + iHMI machining cycle(for 4 path system)(R914)
          [FS30i/31i/32i-B Plus]
          + iHMI kit(R099)
          [FS0i-F Plus]
        - OPERATOR'S MANUAL has been separated into SETUP and OPERATION,
          and added specification number to the file name.
        [FS31i-LB]
        - The function of laser cutting machine has been able to execute commands without
          setting the relevant parameters of the laser oscillator connection.
   Ver 20.10 (2021.1.18)
          + FS30i-B Plus 72AX : G3GD / 03
        [FS0i-F Plus, FS30i-B Plus, FS31i-B Plus, FS31i-B5 Plus, FS32i-B Plus]
        - The machine composition setting data has supported PMC Message file.
   Ver 20.11 (2021.1.28)
        - Cycle Time Estimate Function of CNC GUIDE have supported the following CNC Systems.
   Ver 20.13 (2021.2.5)
          + FS30i/31i/32i-B  : K777 / 45
   Ver 20.14 (2021.2.18)
        - MeasurementAPP of iHMI System has been supported the following series / version.
   Ver 21.00 (2021.4.23)
        - The following CNC System has been added.
          + FS35i-B 16AX     : G613 / 46
        - Machine Composition Creation Tool has supported the following CNC Systems.
          + FS30i-B Plus     : G317 / 10
          + FS31i-B Plus     : G417 / 10
          + FS31i-B5 Plus    : G437 / 10
          + FS32i-B Plus     : G507 / 10
          + FS30i-B 32AX     : G323 / 46
          + FS30i-B 48AX     : G333 / 46
        - Cycle Time Estimate Function of CNC GUIDE has supported the following CNC Systems.
          + FS0i-F           : D4G2/D6G2 / 38
          + FS0i-F Plus      : D4G3/D6G3 / 19
          + FS31i-A          : G11D / 28
          + FS30i-B          : G313 / 46
          + FS31i-B          : G413 / 46
          + FS31i-B5         : G433 / 46
          + FS32i-B          : G503 / 46
        - Manual Guide i System has been updated to following series / version.
          + FS31i-A          : BY70 / 76
          + FS31i-D          : BX32 / 42
          + FS0i-F           : BX34 / 21
          + FS0i-F Plus      : BX34 / 21
          + FS30i-B          : BX72 / 26
          + FS31i-B          : BX72 / 26
          + FS31i-B5         : BX72 / 26
          + FS32i-B          : BX72 / 26
          + FS30i-B Plus     : BX72 / 26
          + FS31i-B Plus     : BX72 / 26
          + FS31i-B5 Plus    : BX72 / 26
          + FS32i-B Plus     : BX72 / 26
        - FANUC PICTURE application transferring function for CNC GUIDE from FP editor has been supported.
          [FS30i/31i/32i-B, FS30i-B 32AX/48AX, FS30i/31i/32i-B Plus]
          + DUAL CHECK SAFETY(S661)
          [FS0i-F]
          + SPINDLE ORIENTATION(J853)
          [FS0i-F, FS0i-F Plus, FS30i/31i/32i-B, FS30i-B 32AX/48AX, FS30i/31i/32i-B Plus]
          + HIGH-SPEED SKIP(J848)
          [FS35i-B]
          + HIGH-SPEED POSITION SWITCH(R704)
          [FS31i-A]
          + HIGH-SPEED POSITION SWITCH(J987)
          [FS0i-F, FS0i-F Plus, FS31i-A, FS30i/31i/32i-B, FS30i-B 32AX/48AX, FS30i/31i/32i-B Plus]
          + PMC AXIS CONTROL ACCELERATION/DECELERATION SPECIFICATION FEED(R640)
          [FS0i-F, FS35i-B]
          + INTERRUPTION TYPE CUSTOM MACRO(J874)
          + TURN MATE i Expanded function(S947)
          [PMi-A]
          + Virtual MDI key
       [PMC]
        - PMC System of FS30i/31i/32i-B has been updated to 40B7/09.
        - DCSPMC function has been supported. (Machine signal simulator is not available for DCSPMC.)
   Ver 21.10 (2021.06.11)
            wrong file information is displayed.  (FS0i-F, FS0i-F Plus)
   Ver 21.20 (2021.06.30)
          + FS30i/31i/32i-B         : K777 / 50
          + FS30i/31i/32i-B Plus    : K788 / 08
          + FS0i-F Plus             : K779 / 11
          [FS30i/31i/32i-B, FS30i-B 32AX/48AX]
          + RIGID TAP(J828)
          [FS0i-F, FS0i-F Plus, FS30i/31i/32i-B, FS30i-B 32AX/48AX]
          [FS30i/31i/32i-B Plus, FS30i-B Plus 72AX]
          + CUSTOM SOFTWARE SIZE 16MB(J738#16M)
          [FS30i/31i/32i-B Plus, FS30i-B Plus 72AX, FS35i-B 16AX]
          + CUSTOM SOFTWARE SIZE 12MB(J738#12M)
       [PMC]
        - Machine signal simulator has become available for DCSPMC.
   Ver 22.00 (2021.8.4)
          + FS35i-B Line     : G641 / 27
          [FS32i-B Line]
          + Start from machine composition setting data has become available.
          + In the machine composition setting data,
            parameters that option can be set enable or disable set '0'.
          [FS30i-B, FS30i-B Plus]
          + In the case of the machine composition setting data that uses iHMI,
            the following option set enable by default.
            iHMI MACHINING CYCLE(FOR 1 PATH SYSTEM)(R911)
            iHMI MACHINING CYCLE(FOR 2 PATH SYSTEM)(R912)
            iHMI MACHINING CYCLE(FOR 3 PATH SYSTEM)(R913)
            iHMI MACHINING CYCLE(FOR 4 PATH SYSTEM)(R914)
          + The following options were able to be used with MANUAL GUIDE i enabled.
            Loader control function(R417)
            Addition of loader control path(R418)
   Ver 22.20 (2021.10.5)
          + When Information Center of iHMI is displayed,
            the contents of Display Details may not correct.  (FS30i/31i/32i-B Plus)
          + The comments of parameter screen may not correct.  (FS35i-B Line)
          + In iHMI, 4-digit G-code cycle may not be executed.  (FS30i/31i/32i-B, FS30i/31i/32i-B Plus, FS0i-F Plus)
          + In machining simulation of MANUAL GUIDE i, tool rotary axis
            during the polar coordinate interpolation with inch input is not drawn correctly.
            (FS30i-A, FS0i-D, FS30i/31i/32i-B, FS30i/31i/32i-B Plus, FS0i-F, FS0i-F Plus)
   Ver 24.10 (2022.2.10)
    NOTICE: About update of FS32i-B Line from Ver. 24.0 or earlier to Ver. 24.1,
            Please refer to "5 UPDATE OF CNC GUIDE" of "A-42148-00360EN_CNC GUIDE Function for transfer line.pdf".
        - MOP Simulator has been supported.
        - Cycle Time Estimate Function of CNC GUIDE have been supported
          that estimate the first path of multi path systems.
          + FS32i-B Plus Line : G547 / 18
        - iHMI System has been supported to following series / version.
          + FS32i-B Plus Line : K785 / 03
          + FS0i-F            : D4G2/D6G2 / 47
          + FS0i-F Plus       : D4G3/D6G3 / 28
          + FS30i-B           : G313 / 54
          + FS30i-B 32AX      : G323 / 54
          + FS30i-B 48AX      : G333 / 54
          + FS31i-B           : G413 / 54
          + FS31i-B5          : G433 / 54
          + FS32i-B           : G503 / 54
          + FS35i-B 16AX      : G613 / 54
          + FS30i-B Plus      : G317 / 18
          + FS31i-B Plus      : G417 / 18
          + FS31i-B5 Plus     : G437 / 18
          + FS32i-B Plus      : G507 / 18
          + FS30i-B Plus 72AX : G3GD / 11
          + FS32i-B Line      : G541 / 27
          + FS0i-F Plus       : K779 / 12
          [FS30i/31i/32i-B, FS30i-B 32AX/48AX, FS35i-B 16AX, FS30i/31i/32i-B Plus,
           FS30i-B Plus 72AX, FS0i-F, FS0i-F Plus]
          + Safety function by FL-net(S851)
          + Ethernet/IP Adapter Safety function(R976)
          + PMC allocation expansion of PROFINET IO Controller function(R979)
          + Ethernet/IP Scanner PORT2 function(R973)
          + Ethernet/IP Adapter PORT2 function(R974)
          + PROFINET IO Controller function(R971)
          + PROFINET IO Device function(R972)
          + Ethernet/IP Scanner function(R966)
          + Ethenret/IP Adapter function(R967)
          + PROFINET IO Device Safety function(R977)
          + FL-net PORT2 function(R964)
          + Modbus/TCP Server function(R968)
          + Ethernet function(S707)
          + FL-net function(J692)
          The above functions support the screen only.
          [PMi-A]
          [FS32i/35i-B Line]
          The above functions support the signal only.
          [FS0i-F Plus]
          + Standard MDI unit (QWERTY keys) has become available.
            (Only Window Mode)
          + The macro of Set-up guidance function has become available.
   Ver 24.20 (2022.4.8)
          + FS30i-LB Plus     : G3D7 / 5
   Ver 24.30 (2022.5.20)
          + Some Reading Diagnosis Data (High-speed Response) functions that terminates abnormally with PMC Window are changed to return completion code 3. (The specified diagnosis data number is invalid)
   Ver 24.40 (2022.5.27)
          + If CNC GUIDE is forcibly terminated while rewriting the parameter, the parameter may become incorrect after the next launch.
   Ver 25.00 (2022.5.31)
          + FS0i-LF Plus      : DCG3 / 09
          + FS30i-LB          : G3D5 / 21
          + FS0i-LF Plus      : K787 / 14
          + FS30i-LB Plus     : K789 / 09
          + FS30i-LB          : K778 / 16
          + FS0i-F            : D4G2/D6G2 / 49
          + FS0i-F Plus       : D4G3/D6G3 / 30
          + FS30i-B           : G313 / 55
          + FS30i-B 32AX      : G323 / 55
          + FS30i-B 48AX      : G333 / 55
          + FS31i-B           : G413 / 55
          + FS31i-B5          : G433 / 55
          + FS32i-B           : G503 / 55
          + FS35i-B 16AX      : G613 / 55
          + FS30i-B Plus      : G317 / 19
          + FS31i-B Plus      : G417 / 19
          + FS31i-B5 Plus     : G437 / 19
          + FS32i-B Plus      : G507 / 19
          + FS32i-B Plus Line : G547 / 19
          + FS30i-B Plus 72AX : G3GD / 12
          + FS0i-F Plus          : K797 / 03
          + FS30i/31i/32i-B      : K795 / 06
          + FS30i/31i/32i-B Plus : K796 / 08
          [FS30i/31i/32i-B, FS30i-B 32AX/48AX, FS30i/31i/32i-B Plus,
           FS30i-B Plus 72AX, FS0i-TF, FS0i-TF Plus]
          + 4th/5th axis offset(R517)
          + Tool posture turning(R338)
          + Speed control with acceleration in circular interpolation(J809)
          + Optimum torque acceleration/deceleration(S675)
          [FS0i-F Plus]
          + CNC Screen size 15/19 inch has become available.
            (19 inch display is only Window Mode)
          + If Italian, Russian, Bulgarian, or Hindi is selected as the input language for Windows, warning dialog will be displayed when CNC GUIDE is launched.
          [FS0i-D]
          + If you restart immediately after creating new program on the O list screen of MANUAL GUIDE i, and press new soft key on the O list screen, the screen will be frozen.
**  Microsoft, Windows, and .NET Framework are registered trademarks of
    Microsoft Corporation in the United States.
**  Pentium and Core are registered trademarks of Intel Corporation.
**  Other product names mentioned are trademarks or registered trademarks
    of their respective companies.
GMT+8, 2026-9-23 00:34
