DataDesigner Configuration Software Version 5.2.0
babo 发表于 2024-8-26 10:24:48 | 显示全部楼层 |阅读模式
支持操作系统Windows 95, 98, 2000,  NT, or ME
DataDesigner_5_20.zip (4.99 MB, 售价: 30 E币)
IC752DDZ000-BC        IC200DDZ000-BC        DAT-DSN-BC
IC752SKT008-EG         IC752SKT009-EF        IC752SKT011-DG        IC752SKT012-BD
IC752SKT013-BD        IC752SKT014-CD        IC752SKT015-BD        IC752SKT016-BD
IC752DEM003-CE        IC752DEM004-CE        IC200TBX110-BG        IC200TBX114-BG
IC200TBX123-CH        IC200TBX128-BG
DataDesigner 5.2.0 supports configuration of the Datapanel models 30/35, 50/55, 40/45, 60/65, 85, 150, 160, and 240E. Support for new hardware versions of the 160 and 240E has been added in this release.
The 5.2.0 release of the System Software runs in the same collection of Datapanels and is included with DataDesigner.DataDesigner 5.2.0 replaces all versions of DataDesigner 5.1.0.
Compatibility :
Any database made with a 3.0.x, 3.1.x, 3.2.x, or 3.3.x version of WinCfg or version 5.0.0 or 5.1.0 of DataDesigner will be compatible with DataDesigner version 5.2.0. The System Software is compatible with any database that is compatible with those versions of WinCfg or DataDesigner.
Note:The functionality of displaying text tags has changed from v5.1 for models 4x, 6x and 85.
See description of CR76505 below for full details.
Update Strategy :
DataDesigner v5.2.0 must be used to configure the new hardware versions of the 160 and 240E.
Users of other models may upgrade at their option to take advantage of any problem fixes affecting those models.
Documents :
GFK-2028        Datapanel Models 150, 160, and 240E Operator's Manual
GFK-1657        Datapanel Models 30/35 and 50/55 Operator's Manual
GFK-1658        DataDesigner Software User's Guide
GFK-1806        Datapanel 40/45, 60/65, and 85 User's Manual
Special Operational Notes :
System Requirements
1. The DataDesigner v5.2.0 software occupies about 15 Mbytes of disk space. Please make sure you have adequate
    space on your disk before attempting to install the software.
2. 80486 or higher computer.
3. 16 Mbytes memory, minimum. 32 Mbytes memory is recommended.
4. Windows 95, 98, 2000,  NT, or ME
Installation Notes :
1. Close all open applications prior to installing DataDesigner.  It is also possible that the installation will fail due to a
    required file being in use, even though all applications are closed.  If this occurs, it will be necessary to reboot the
    system and then install DataDesigner as the first task as soon as the system completes the bootstrap process.
2. Insert the DataDesigner compact disk (CD) into the CD drive of the computer.
3. Install DataDesigner by running SETUP.EXE from the root of the installation CD. This may be accomplished by
    selecting SETUPEXE directly from the CD or by selecting RUN from the Start Menu. In the RUN dialog box,
    type D:\SETUP where D: is the CD drive. Click OK.
4. Follow the instructions displayed by the installation procedure.
5. The GE Fanuc software license agreement for DataDesigner v5.2.0 is the first window shown once installation
    begins. This agreement must be read and agreed to before installation can proceed. If the license agreement is
    declined, DataDesigner will not be installed.
6. After installation is complete, a DataDesigner information screen may be displayed. Viewing this important
    product information screen is optional, but recommended.
7. The DataDesigner and Datapanel manuals are now provided on the CD and are copied to the designated folder
    during installation. The manuals are encoded in Adobe Portable Document Format (.PDF). The Adobe Reader is
    required to view the manuals and is also provided on the CD. The Reader is not copied during the installation
    process. To install the reader from the CD, select the Reader installation file RP500ENU.EXE in the \Acroread
    folder of the CD.
    Note that the Adobe Reader is subject to its own software licensing agreement. Please view additional information
    available on the CD in \Acroread\ReadMe.txt. Also see www.adobe.com.
Features Introduced in Release 5.2.0 :
1. DataDesigner supports new hardware for the 160 and 240E, which has been significantly redesigned. These
   changes are transparent to the user. The functionality of the new and previous hardware is identical, configuration
   is the same and databases from the previous models can be loaded to the new models. However, the new models
   require the newer versions of the command and protocol files. These are included in DataDesigner v5.2.0. The new
   command files are unique to the new hardware, but the protocol files support both version of the hardware for 160
   and 240E.
2. Support for on-screen tag editing has been added to models 150, 160 and 240E.
3. Models 160 and 240E now support printing of tag objects based on the dynamic attribute Show/Hide. If the tag
    object is not displayed on the screen due to the actual value of the tag driving the Show/Hide attribute, the object
    will not be printed. If the tag object is shown on the screen, it will be printed.
Problems Fixed in Release 5.2.0
Subject                                ID Code                Description
GPF cutting & pasting                CR1271A                lengthy succession of cutting and pasting text pages occasionally
                                                caused DataDesigner to stop responding.
Datapanel screen blanks                CR75469                After some period of time, the screen would go blank and the unit
                                                would be unresponsive. A power cycle was necessary to recover.
                                                Affected DP3x and 5x.
Omron protocol bytes swapped        CR75660                Data bytes were incorrectly swapped in the Omron protocol for
                                                DP3x, and 5x.. Fixed in protocol version 1.2
Too many analog tags caused        CR75995                If the number of analog tags was near the maximum and tags were failure
                                                being added, deleted or edited, DataDesigner would stop
                                                responding if the length of a tag was changed.
Can't remove protocol  from         CR76022                DataDesigner would not let the channel be changed for a tag using COM2
                                                Channel B if an attempt was first made to remove the protocol on
                                                that channel.
Tag lost on message table        CR76069                A message table would lose its assigned tag when configured on a
                                                page if the tag was digital.
Comms block frequency lost        CR76077                A comms block with a frequency of Inactive in a list of other
                                                comms blocks with frequencies other than Inactive would have its
                                                frequency changed to the other comms block's frequency when
                                                scrolling through the list in DataDesigner
Editable tags disabled                CR76079                If Page Change (via arrow keys) was disabled in DataDesigner,
                                                editable tags could not be edited in Datapanel 150, 160 and 240E.
Could not change text length        CR76123                Once configured, DataDesigner would not save the length field
                                                when the field was modified. This affected text tags only.
Root installation                CR76140                If DataDesigner was installed in the root directory of a drive, the
                                                transfer utility would not start.
Could not cut and paste F-keys        CR76142                Function keys programmed on a page could be cut but not pasted
                                                into a new, blank page.
Problem while deleting F-keys        CR76271                DataDesigner would stop responding if programmed, system wide
                                                function keys were deleted.
Slow page change                CR76272                Changing pages on the Datapanel was inordinately slow when
                                                using the Genius protocol.
Page jumps to alarm or blank        CR76273                Pressing two programmed function keys rapidly caused the
                                                Datapanel to display the wrong page.
Truncated Messages                CR76308                DataDesigner allowed more than 40 characters of text for a
                                                message in a message table. Datapanel 150, 160, 240E screens are
                                                only 40 characters wide, effectively cropping the message. Also
                                                affected formatted text.
Alarm log print F-key                CR76309                DataDesigner allowed a function key to be configured on a system
                                                page (Alarm Log) for a print operation.
Win 95 download fails                CR76392                DataDesigner running on Windows 95 was unable to download to
                                                Sattbus controllers with a node ID greater than nine.
Wrong tag values with                 CR76407                Under certain conditions, Datapanels configured with two protocols multiple protocols
                                                would incorrectly update one protocol's tags with data from the
                                                second protocol. Affected DP160, 240E only.
Could not change protocol        CR76409                DataDesigner would prevent a protocol on a channel from being
                                                changed and would display a message that a tag was assigned to the
                                                channel even though no tags were actually assigned.
Text overwriting next tag        CR76423                Text longer than 4 characters was overwriting adjacent tags on a
                                                page. Affected DP85 only.
Function keys did not work        CR76443                Function keys would not operate on a DP160 using the GE Fanuc
                                                SNP protocol and a baud rate of 9600.
Could not add bitmap                CR76458                DataDesigner would not load a bitmap file from a location with a
                                                pathname longer than 33 characters. Affected databases for DP160
                                                and 240E.
Incorrect tag type for trend        CR76487                DataDesigner would incorrectly save the type of the tag associated
                                                with a trend record as Word if the tag was actually of type Floating
                                                Point.
Incorrect tag frequency                CR76504                Depending on the navigation in the tag dialog, DataDesigner would
                                                incorrectly save the tag frequency as 0.1second instead of 1 second.
Byte order in text tags                CR76505                Text is displayed differently on various Datapanel models. DP150,
                                                160 and 240E would display text from a controller as "ABCDEF"
                                                while the DP4x,6x and 85 would display the same text as
                                                "BADCFE." Fixed in GE Fanuc SNP protocol v3.2.
Editable grouped objects        CR76535                Datapanel 150, 160 and 240E would stop responding when
                                                displaying grouped objects when the editable attribute was set for
                                                one or more of the objects.
                                                Note: In DataDesigner v5.2.0, editable objects should not be
                                                grouped. DataDesigner disables the editable attribute for any
                                                grouped objects.
Printed analog tags wrong        CR76536                DataDesigner would print analog tag objects incorrectly when
                                                printing a display page.
Printing pages                        CR76539                DataDesigner would stop responding while printing display pages
                                                for DP85 databases.
Editing locks panel                CR76546                The DP240E would stop responding to keys if a system function
                                                key was pressed while on-screen edit was active.
Signed double word scaling        CR76547                Certain large values were scaled incorrectly when using tags of
                                                type signed double word. Affected all Datapanel models.
Printing objects incomplete        CR76550                DataDesigner was not printing complete details on display page
                                                objects.
Displaying non-displayable         CR76583                Datapanel models 4x, 6x and 85 were displaying carriage return characters
                                                and line feed characters on the screen. These characters would
                                                show up as black boxes.
A/B Micrologix slow                CR76598                Communications with the Micrologix controller would
                                                intermittently get very slow. Fixed in protocol v1.1. Affected
                                                DP150, 160 & 240E.
Restrictions and Open Problems :
Checksum Error on bootup         CR-1255                Models 160 and 240E show this error message on start up with no
                                                application (command) software loaded.
相关帖子
GMT+8, 2025-4-21 03:54
