[Emerson] Installing Your DeltaV SIS Process Safety System Hardware
babo 发表于 2024-7-7 10:43:29 | 显示全部楼层 |阅读模式
内容类型
内容类型: 文档
文档下载: SIS Install.pdf (1.57 MB, 售价: 20 E币)
This manual is designed to help you install your DeltaV SIS hardware and get it started up quickly. It shows factory tested and supported wiring connections. If your system requires a different configuration, contact your Emerson Process Management representative or sales office for help with design or review. It is assumed that all installation and
maintenance procedures described in this document are performed by qualified personnel and that the equipment is used only for the purposes described.
Preface ............................................................................................................................iii
Chapter 1 Overview to the DeltaV SIS System ................................................................................... 1
DeltaV SIS hardware ...................................................................................................................................1
Communication in the DeltaV SIS system ...................................................................................................3
Chapter 2 Installing the system ........................................................................................................ 5
Agency approvals .......................................................................................................................................5
CE statement ............................................................................................................................................. 5
Tools required for installation .................................................................................................................... 6
Wiring guidelines ....................................................................................................................................... 6
Install the carriers .......................................................................................................................................6
Install the terminal blocks .......................................................................................................................... 7
Install the Logic Solver ............................................................................................................................... 8
Connecting the field wiring ........................................................................................................................ 8
Install the SISNet Repeater ......................................................................................................................... 9
Installing extender cables ...........................................................................................................................9
Install carrier extender cables ......................................................................................................... 9
Install local peer bus extender cables ............................................................................................10
Terminate the local peer bus ....................................................................................................................11
Providing power .......................................................................................................................................12
Provide power to the Logic Solvers ............................................................................................... 12
Provide power to SISNet Repeaters .............................................................................................. 13
Provide power to SISNet Distance Extenders ................................................................................ 14
Setting up the remote peer ring ............................................................................................................... 15
Connect a remote peer ring with multimode fiber ........................................................................17
Extending the remote peer ring ....................................................................................................17
Chapter 3 Checking out and troubleshooting your DeltaV SIS hardware ......................................... 23
Logic Solver LEDs ..................................................................................................................................... 23
SISNet Repeater LEDs ...............................................................................................................................24
SISNet Distance Extender LEDs .................................................................................................................27
Chapter 4 Environmental and heat dissipation specifications ......................................................... 29
Chapter 5 Logic Solver and channel specifications .......................................................................... 31
Logic Solver specifications ....................................................................................................................... 31
Simplex Logic Solver termination block ........................................................................................ 32
Redundant Logic Solver termination block ................................................................................... 33
Analog input channel specifications ......................................................................................................... 33
HART two-state output channel specifications .........................................................................................34
Discrete input channel specifications ....................................................................................................... 35
Discrete output channel specifications .................................................................................................... 37
Chapter 6 SISNet Repeater and SISNet Distance Extender specifications ......................................... 41
SISNet Repeater specifications .................................................................................................................41
SISNet Distance Extender specifications ...................................................................................................42
Calculating the fiber-optic link loss ...........................................................................................................44
Chapter 7 Extending an operational system ................................................................................... 47
Add carriers to an operational system ...................................................................................................... 47
Contents
iAdd SISNet Repeaters to an operational system ....................................................................................... 48
Using DeltaV intrinsically safe cards with DeltaV SIS hardware ................................................................. 50
Install intrinsically safe cards in a DeltaV SIS system ......................................................................51
Chapter 8 Using auxiliary equipment with DeltaV SIS hardware ..................................................... 53
Relay Modules for fire and gas applications .............................................................................................. 53
Auxiliary Relay DTA-Inverting module specifications ................................................................................ 54
Auxiliary Relay Diode module ...................................................................................................................57
Relay Module for other applications ......................................................................................................... 58
Auxiliary Relay ETA-Direct module specifications ..................................................................................... 59
SIS Relay Module ......................................................................................................................................60
SIS Relay module specifications ....................................................................................................60
Proof testing the SIS Relay Module ............................................................................................... 62
Voltage Monitor specifications .....................................................................................................63
SIS Current Limiter specifications ................................................................................................. 66
Index ................................................................................................................................................. 69
GMT+8, 2025-4-20 13:42
