[Emerson] DeltaV SIS CHARMs Smart Logic Solver Hardware Reference
babo 发表于 2024-7-7 10:39:01 | 显示全部楼层 |阅读模式
内容类型
内容类型: 文档
文档下载: SIS CHARMs Hardware Reference.pdf (20.23 MB, 售价: 20 E币)
This manual contains installation notes, specifications, wiring diagrams, dimensions, and other reference information for DeltaV CHARMs Smart Logic Solver (CSLS) SIS hardware.
Preface ............................................................................................................................iii
Chapter 1 CHARMs Smart Logic Solver hardware specifications ........................................................1
CHARMs Smart Logic Solver (CSLS) SIS hardware overview ........................................................................ 1
Power requirements for LS CHARMs I/O ..................................................................................................... 2
Inject field power to LS CHARMs ..................................................................................................... 3
CHARMs Smart Logic Solver ....................................................................................................................... 5
Manually decommission and unassign a CHARMs Smart Logic Solver ............................................ 8
CHARMs Smart Logic Solver Power Module ................................................................................................8
Local Safety Network Bridge .................................................................................................................... 11
SZ Controller ............................................................................................................................................13
Manually decommission a SZ Controller ....................................................................................... 16
CHARMs Smart Logic Solver Carrier ..........................................................................................................16
Dual Universal Safety Carrier .................................................................................................................... 21
SZ Controller Carrier ................................................................................................................................ 26
Safety Network Ports ............................................................................................................................... 30
Ethernet Isolation Ports ............................................................................................................................31
CHARM Baseplate .................................................................................................................................... 32
I.S. CHARM Baseplate ...............................................................................................................................36
Address Plug ............................................................................................................................................ 39
LS CHARM Protection Cover .....................................................................................................................40
LS I.S. CHARM Protection Cover ............................................................................................................... 40
CHARM Column Terminator specifications .............................................................................................. 41
CHARM Column Extenders and cable ....................................................................................................... 42
Chapter 2 Logic Solver CHARMs Terminal Block specifications ........................................................ 45
CHARM Terminal Block ............................................................................................................................ 45
CHARM Fused Injected Power Terminal Block .......................................................................................... 47
CHARM 3-Wire AI Fused Injected Power Terminal Block ........................................................................... 48
CHARM 3-Wire DI Fused Injected Power Terminal Block ...........................................................................50
CHARM Thermocouple / mV Terminal Block ............................................................................................ 52
LS DVC Terminal Block specifications ....................................................................................................... 53
CHARM Address Terminal ........................................................................................................................ 54
LS Redundant Terminal Block specifications .............................................................................................55
LS Redundant DTA Fused Injected Power Relay Terminal Block ................................................................56
LS Redundant DTA Relay Terminal Block .................................................................................................. 59
LS Redundant ETA Relay Terminal Block ................................................................................................... 61
LS Redundant DVC Terminal Block ........................................................................................................... 62
I.S. CHARM Terminal Block .......................................................................................................................63
I.S. CHARM Thermocouple mV Terminal Block .........................................................................................65
I.S. CHARM Address Terminal ...................................................................................................................66
Chapter 3 Logic Solver CHARMs specifications ................................................................................67
LS input CHARMs specifications ............................................................................................................... 67
LS AI 0-10 VDC isolated CHARM ................................................................................................... 67
LS AI 4-20 mA HART CHARM .........................................................................................................69
LS DI 24 VDC isolated CHARM ...................................................................................................... 72
LS DI 120 VAC isolated CHARM .....................................................................................................75
iLS DI 120 VAC isolated Plus CHARM specifications ....................................................................... 77
LS DI 230 VAC isolated CHARM .....................................................................................................80
LS DI 24 VDC low-side (dry contact) CHARM .................................................................................83
LS DI NAMUR CHARM ................................................................................................................... 85
LS RTD / Resistance input CHARM ................................................................................................ 86
LS Thermocouple / mV input CHARM ........................................................................................... 88
LS Output CHARMs specifications ............................................................................................................ 90
LS DO 24 VDC CHARMs ................................................................................................................ 90
LS DVC HART DTA CHARMs .......................................................................................................... 97
LS 24 VDC Power CHARM ........................................................................................................... 100
LS Intrinsically Safe input CHARMs specifications ................................................................................... 104
LS AI 4-20 mA HART (Intrinsically Safe) CHARM .......................................................................... 104
LS DI NAMUR (Intrinsically Safe) CHARM .....................................................................................105
LS RTD / Resistance input (Intrinsically Safe) CHARM .................................................................. 107
LS Thermocouple / mV input (Intrinsically Safe) CHARM .............................................................109
Chapter 4 CHARMs Smart Logic Solver Migration Panels ...............................................................113
About CHARMs Smart Logic Solver Migration Panels ..............................................................................113
CHARMs Smart Logic Solver (CSLS) Migration Panel ...............................................................................113
LS CHARM Baseplate Migration Panels ................................................................................................... 114
Chapter 5 LED descriptions for CHARMs Smart Logic Solver hardware .......................................... 117
Analog LS CHARMs LED ..........................................................................................................................117
Discrete LS CHARMs LEDs ...................................................................................................................... 119
CHARMs Smart Logic Solver LEDs ...........................................................................................................121
Local Safety Network Bridge LEDs .......................................................................................................... 122
Safety Network Port LEDs .......................................................................................................................123
SZ controller LEDs .................................................................................................................................. 125
Ethernet Isolation Port LEDs ................................................................................................................... 125
Chapter 6 Networks in a CHARMs Smart Logic Solver SIS system ...................................................129
Communication in a CHARMs Smart Logic Solver SIS system ................................................................. 129
DeltaV LSN20 Safety Switches ................................................................................................................130
DeltaV SRM100 Safety Switch ................................................................................................................ 131
Twisted pair and fiber-optic star network with DeltaV safety switches ................................................... 133
Twisted pair network with DeltaV safety switches ..................................................................................135
Twisted pair network with DeltaV safety switches and firewalls ..............................................................137
Example twisted pair and fiber-optic Global Safety Network ..................................................................139
Example control room for a Global Safety Network ................................................................................ 140
Example Global Safety Network field installation ....................................................................................142
Chapter 7 Environmental specifications for CHARMs Smart Logic Solver hardware ....................... 145
Temperature and humidity specifications for CSLS SIS hardware ............................................................145
Contaminants, vibration, and shock specifications for CSLS SIS hardware .............................................. 146
Chapter 8 Product type numbers for CHARMs Smart Logic Solver SIS hardware ............................ 147
Product type numbers for CHARMs Smart Logic Solver SIS hardware ..................................................... 147
Index ................................................................................................................................................149
GMT+8, 2025-4-20 13:45
