[Honeywell] DeltaV SIS CHARMs Smart Logic Solver Hardware Installation
babo 发表于 2024-7-7 10:26:15 | 显示全部楼层 |阅读模式
内容类型
内容类型: 文档
文档下载: SIS CHARMs Hardware Installation.pdf (13.05 MB, 售价: 20 E币)
This manual contains step-by-step instructions for installing DeltaV CHARMs Smart Logic Solver (CSLS) SIS hardware.
Preface ............................................................................................................................iii
Chapter 1 Planning the installation .................................................................................................. 1
Tools required to install DeltaV hardware ...................................................................................................1
Torque limits for mounting screws .............................................................................................................2
Wiring guidelines ....................................................................................................................................... 2
Chapter 2 Installing CHARMs Smart Logic Solver SIS hardware ......................................................... 3
CHARMs Smart Logic Solver (CSLS) SIS hardware overview ........................................................................ 4
Recommended sequence for installing CHARMs Smart Logic Solver SIS hardware ..................................... 5
Recommendations for installing vertical DIN rails ...................................................................................... 5
Install an SZ Controller Carrier on the DIN rail .............................................................................................6
Install a CHARMs Smart Logic Solver Carrier on the DIN rail ........................................................................ 7
Install a Dual Universal Safety Carrier on the DIN rail .................................................................................. 8
Remove a Dual Universal Safety Carrier from the DIN rail ........................................................................... 9
Install the first CHARM Baseplate on the DIN rail ........................................................................................ 9
Install the other CHARM Baseplates onto the DIN rail ............................................................................... 11
Install a Separation Wall for Intrinsically Safe applications ........................................................................ 13
Install I.S. Baseplates ................................................................................................................................ 14
Remove a CHARMs Smart Logic Solver Carrier or Baseplate from the DIN rail ........................................... 18
Install the Column Terminator onto the DIN rail ....................................................................................... 18
Install a DIN Rail Stop ............................................................................................................................... 20
Connect power to SZ Controllers ............................................................................................................. 21
Connect power to Local Safety Network Bridges or SZ Controllers ........................................................... 22
Connect power to LS CHARM I/O ............................................................................................................. 24
Connect power to LS I.S. CHARM I/O ........................................................................................................ 26
Extend CHARM power to other baseplates ............................................................................................... 28
Install SZ Controllers onto the carrier ....................................................................................................... 29
Install CHARMs Smart Logic Solvers onto the carrier ................................................................................ 30
Install Power Modules onto the carrier ..................................................................................................... 31
Install Local Safety Network Bridges or SZ Controllers on the Dual Universal Safety Carrier ...................... 32
Install LS CHARMs .................................................................................................................................... 33
Install LS I.S. CHARMs ...............................................................................................................................35
Reset the keying mechanism on a CHARM Terminal Block ....................................................................... 36
Reset the keying mechanism on an I.S. CHARM Terminal Block ................................................................37
Label the CHARMs installed on each baseplate ........................................................................................ 39
DeltaV hardware ready for transportation ................................................................................................40
Chapter 3 Making network connections ......................................................................................... 41
Communication in a CHARMs Smart Logic Solver SIS system ................................................................... 41
Connect the CHARMs Smart Logic Solver to the Local Safety Network ..................................................... 42
Connect the SZ Controller to the Area Control Network and the Local Safety Network .............................42
Connect an SZ Controller's Modbus TCP port to a third party safety system ............................................. 43
Index ................................................................................................................................................. 45
GMT+8, 2025-4-20 13:37
