[Emerson] DeltaV P-series Hardware Reference Standalone Installations
babo 发表于 2024-7-7 10:12:12 | 显示全部楼层 |阅读模式
内容类型
内容类型: 文档
文档下载 P-series_Hardware_Reference.pdf (3.78 MB, 售价: 20 E币)
Preface .............................................................................................................................v
Chapter 1 Overview ......................................................................................................................... 1
The DeltaV System .....................................................................................................................................1
DeltaV System Equipment for the P-Series Controller ................................................................................ 1
Chapter 2 Installing Your DeltaV System .......................................................................................... 3
CE Statement .............................................................................................................................................4
China RoHS ................................................................................................................................................ 4
Important Information about Hazardous Live Voltages in P-series systems ................................................ 5
Installation Planning for P-Series Hardware ................................................................................................ 5
Tools Required for Installation ........................................................................................................ 5
Site Preparation ..............................................................................................................................6
Wiring Guidelines ...........................................................................................................................6
Power Guidelines ............................................................................................................................6
Torque Limits ................................................................................................................................. 6
Getting Started with DeltaV Hardware ........................................................................................... 7
Installing the System ..................................................................................................................................8
Installing the DIN Rails and Carriers for P-Series Controllers ............................................................ 8
DIN Rail Recommendations ............................................................................................................9
Installing the PK Carrier ................................................................................................................ 10
Installing the I/O Interface Carrier .................................................................................................11
Connecting Bussed Field Power for P-Series Controllers ............................................................... 12
Extending Bussed Field Power for P-Series Controllers .................................................................. 12
Installing Extender Cables for P-Series Hardware .......................................................................... 16
Installing the DeltaV I/O Interface .................................................................................................16
Installing an I/O Terminal Block .........................................................................................16
Installing an I/O Card ........................................................................................................ 18
Installing a Redundant Terminal Block .............................................................................. 18
Installing a Redundant I/O Card ........................................................................................ 19
Installing the DeltaV P-Series Power Module .................................................................................19
Installing the DeltaV P-Series Controller ....................................................................................... 20
Installing the DeltaV Workstation .................................................................................................21
DeltaV hardware ready for transportation .................................................................................... 22
Connecting Power to the System for P-series ............................................................................... 22
Setting Up a Network Time Server ................................................................................................22
IP Addresses ..................................................................................................................... 22
Subnet Mask .....................................................................................................................23
Broadcast Mode ................................................................................................................23
Chapter 3 Checking Out and Troubleshooting Your DeltaV System ................................................. 25
Checking Out Your System ...................................................................................................................... 25
Step 1. Checking the Cable Connections ...................................................................................... 26
Step 2. Checking the Power Supply Voltages ................................................................................26
Step 3. Checking the LED Indicators on Each Device ..................................................................... 26
PK controller LEDs .............................................................................................................27
DeltaV Fiber Switches LEDs ...............................................................................................28
DeltaV Controller Firewall LEDs .........................................................................................29
Contents
iAI 8-Channel Card LEDs .....................................................................................................29
AI 16-Channel Card LEDs ...................................................................................................31
AO 8-Channel Card LEDs ...................................................................................................32
AS-Interface Card LEDs ..................................................................................................... 34
DeviceNet Card LEDs ........................................................................................................ 35
DI 8-Channel Card LEDs .................................................................................................... 36
DI Mass Connection Board LEDs ........................................................................................37
DO 8-Channel Card LEDs ...................................................................................................38
DO 32-Channel Card LEDs .................................................................................................38
DO Mass Connection Board LEDs ...................................................................................... 39
Fieldbus H1 Card LEDs ...................................................................................................... 39
Isolated Input Card LEDs ................................................................................................... 41
Multifunction Card LEDs ................................................................................................... 41
Profibus DP Card LEDs .......................................................................................................42
RTD, ohms and Thermocouple, mV Cards LEDs ................................................................ 43
Sequence of Events Card LEDs .......................................................................................... 44
Serial Card, 2 Ports, RS232/RS485 LEDs ............................................................................ 45
VIM 2 card LEDs ................................................................................................................ 46
MD20 and MD30 Smart Switch LEDs .................................................................................48
RM100 and FP20 Smart Switch LEDs ................................................................................. 50
Step 4. Testing the Field Wiring Connections ............................................................................... 51
Troubleshooting Your System ..................................................................................................................52
Using the DeltaV Explorer .............................................................................................................52
Status Indicators ...............................................................................................................52
Using the Workstation Diagnostics ...............................................................................................53
Using DeltaV Diagnostics ............................................................................................................. 53
Troubleshooting Guide ................................................................................................................ 54
Getting Help ............................................................................................................................................ 57
Hazardous Area Installation Manuals, NAMUR Installation Manuals, and ATEX Instruction Sheets ............ 57
Technical Service ..................................................................................................................................... 58
Chapter 4 Environmental Specifications ......................................................................................... 59
Environmental Specifications for P-series controller .................................................................................59
Chapter 5 I/O Carrier Specifications for P-Series Compatible Carriers .............................................. 61
2-Wide Horizontal Power Carrier ..............................................................................................................61
4-Wide Horizontal I/O Interface Carrier .................................................................................................... 62
8-Wide Horizontal I/O Interface Carrier .................................................................................................... 66
1-Wide Horizontal Carrier Extenders and Cables ...................................................................................... 66
Add External Power at the Left Carrier Extender ............................................................................68
Cabling Examples ......................................................................................................................... 68
Chapter 6 Interface Specifications for P-series Controllers .............................................................. 73
I/O Cards for P-Series Controllers .............................................................................................................73
Terminal Blocks for I/O on a P-Series Controller ........................................................................................73
Chapter 7 P-series Controllers ....................................................................................................... 75
PK controller and carrier specifications .....................................................................................................75
PK controller LEDs .................................................................................................................................... 78
DeltaV PK controller Unlock Inhibit and Unlock Allow ...............................................................................80
Chapter 8 Power Module Specifications for P-Series Controller .......................................................83
P-Series Power Module .............................................................................................................................83
Chapter 9 Control Network Specifications ...................................................................................... 87
Contents
iiEthernet Cable Specifications and Installation Rules .................................................................................87
Fiber-Optic Cable Specifications ................................................................................................... 88
Cable Accessory Specifications ..................................................................................................... 88
Building Twisted Pair Cable Assemblies ........................................................................................ 89
Straight-Through Cable Pin Outs .................................................................................................. 90
Crossover Cable Pin Outs ..............................................................................................................91
Managing Switches and the DeltaV Firewall IPD ....................................................................................... 91
Reserved DeltaV IP Addresses .................................................................................................................. 92
Chapter 10 Enclosure and Power Dissipation Guidelines ................................................................... 95
Selecting an Enclosure for your P-Series System .......................................................................................95
Power Dissipation Considerations ............................................................................................................ 96
Example Enclosure Selection Calculations ................................................................................................ 98
Chapter 11 Powering LocalBus ....................................................................................................... 101
Chapter 12 Bussed Field Power Guidelines ......................................................................................103
Implementing Bussed Field Power for Applications using DI and DO Cards .............................................103
Sizing R-C Snubbers ............................................................................................................................... 106
Chapter 13 Controller Redundancy .................................................................................................109
Installing a Redundant Controller ...........................................................................................................109
Chapter 14 Product Type Numbers for P-Series Hardware .............................................................. 111
Glossary .............................................................................................................................................................113
Units Used in This Manual ...................................................................................................................... 113
Acronyms Used in This Manual ...............................................................................................................114
Terms Used in This Manual .....................................................................................................................115
Index ................................................................................................................................................117
GMT+8, 2025-4-20 13:39
