KUKA.SIM Pro 3.1.2安装文件下载
tubage 发表于 2024-3-10 16:07:19 | 显示全部楼层 |阅读模式
机器人品牌
厂商: KUKA
安装文件下载:只有安装文件,没有授权破解,仅提供个人在家学习用途,此程序文件来源于网络可靠性稳定性完整性皆无法验证,禁止用于其他用途,否则后果自负。
百度网盘下载链接.txt (1.44 KB, 售价: 1 E币)
System Requirements (minimum):
- NVIDIA Graphic adapter with PhysX support and minimum 1GB RAM | recommendation 2GB RAM
- Minimum 8GB RAM | recommendation 16GB RAM or higher
- Dual-Core CPU | recommendation Quad-Core CPU
- DirectX 9.0 support
- WIN 10 64Bit
KUKA.SIM Pro 3.1.2 (March 25, 2020)
New Functionalities:
- Quick and easy trial licensing via KUKA website
- Support KSS 8.5 and 8.6
- Motion Mode statements
- New robot models and equipment in library
- French User Interface
- Exchange load data of robots
- Define line thickness for tracing robot motions
- Optimized simulation engine to support larger layouts
- Support for latest version of CAD files, e.g. Creo 6.0
- Improvements for importing and generating mathematical surfaces
- API and examples for working with geometry, motion paths, motion modes, images
- Export to STEP AP242, JT and other file formats:
      - Exported geometry is tessellated data
      - Some file formats do not support export of materials or textures
Fixed Bugs:
- Material import, rendering, and export issues
- File saving, loading and indexing issues
- Translations for user interface, tooltips and documentation
- Decimal precision when detecting joint limit errors in robots
- Issues with axes in robot models, e.g. LBR IIWA 7 and 14
- Machine data issues with robots and external axes, e.g. DKP and KL 4000
- Acceleration and velocity issues of motions when using RCS
- Issues related to physics engine and behaviors, e.g. conveyor paths and cables
- Handling of locked components in 3D world
- Sweeping the geometry of robots in library
- Handling the exchange of actions between old and new versions of robot models
- Issues with component properties using Metric, US and SI units.
KUKA.SIM Pro 3.1.1 (July 22, 2019)
- none
Fixed Bugs:
- Connection of sensors after closing the cell corrupt
- PROGRAM - CFP calculation broken, resulting in unhandled exceptions
- PROGRAM - Exchange robot fails, saved position overwritten and wrong
- PROGRAM - Unhandled exception when RunSimulation
- PROGRAM - IO-Control Wizard is bugged
- PROGRAM - Wait for False seems not to work
- PROGRAM - Name of called subroutine is missing in CALL SUB in jobmap
- PROGRAM - Wait for IN=False does not work for RCS Robots
- PROGRAM - Signal editor leads to unhandled exception + IO not connected after exchange robot
- PROGRAM - Export Job - WAIT FOR IN[] CONT
- MODELING - Unhandled exception when Copy&Paste of feature
- HOME - Wrong open/close state - Tool-Wizard
- RCS - Cycle time offset with linear units and positioners (DKP)
- Transformation of ceiling linear track in machine data is wrong
- PROGRAM - Waif for $IN: robot keeps waiting
- PROGRAM - Cycle time for Tool[0] is wrong when using RCS
- PROGRAM - the simulation always starts from its saved state instead of current position
- Robot exchange button ges disabled after selecting
- RCS - The RCS-Module cannot be loaded and vcmx data gets damaged / ruined after a robot change
- GENERAL - Program crashes after windows went into sleep mode
- API - after creating one collistion detector, there are multiple collision detectors in the layout
- API - IText2DSet.Delete() does not work in user geometry
- PROGRAM - Export Job does not save tool mass, cog, inertia and import job does not load mass, cog, inertia
KUKA.SIM Pro 3.1.0 (April 26, 2019)
- RCS Module integrated (KSS 8.5) - classic motion only
- Cycletime prediction without KUKA.OfficeLite
- New signal and interface editor
- Surface/curve import from CAD
- View animation editor
GMT+8, 2025-4-19 01:19
