[Honeywell] 霍尼韦尔 PC R5XX 系统安装及配置手册
bluesky1 发表于 2023-8-9 16:57:23 | 显示全部楼层 |阅读模式
内容类型
内容类型: 文档
GSB-LSS24501 PC R5XX 系统安装及配置手册.pdf (7.79 MB, 售价: 3 E币)
1. 安装要求............................................................................................ 7
1.1 硬件要求.......................................................................................... 7
1.2 软件要求.......................................................................................... 8
2. 安装并配置操作系统 .......................................................................... 9
2.1 安装操作系统................................................................................... 9
2.2 配置操作系统................................................................................... 9
2.2.1 新建账户..................................................................................... 9
2.2.2 设置Network and Internet..................................................... 10
2.2.3 设置Power Option.................................................................. 11
2.2.4 添加SNMP Service (仅限于Server 2016) ............................... 13
2.2.5 添加WMI SNMP Provider (仅限于window 10) ..................... 13
2.2.6 添加Web Server (IIS) (仅限于eServer) ............................... 14
2.2.7 设置电脑为最佳性能模式 ......................................................... 15
2.2.8 关闭Windows Denfender ...................................................... 16
2.2.9 关闭fast user switching option ............................................. 16
2.2.10 关闭automatic disk defragmentation ................................ 17
2.2.11 关闭Windows automatic updates ...................................... 17
2.2.12 重命名电脑............................................................................. 18
2.2.13 关闭antivirus services and applications(仅限安装了防病毒软件的
系统) ................................................................................................ 18
2.2.14 设置网卡 ................................................................................ 19
2.2.15 激活操作系统 ......................................................................... 20
2.2.16 安装硬件狗............................................................................. 23
3. 安装PlantCruise系统...................................................................... 24
3.1 两种安装方式................................................................................. 24
3.2 制作PSIS的方法............................................................................. 24
3.3 使用PSIS安装................................................................................. 27
4. PlantCruise安装完成后的检查及配置............................................. 36
4.1 添加Product Administrators操作组............................................. 36
4.2 设置网卡名字及IP地址................................................................... 36
4.2.1 分别打开两个网卡的Detail选项,然后查看Physical Address。 36
4.2.2 设置FTE Adapter的IP地址....................................................... 37
4.3 设置Device index ......................................................................... 37
4.4 修改并更新Hosts文件.................................................................... 38
4.5 新建Server .................................................................................... 40
4.6 同步冗余服务器 ............................................................................. 42
4.6.1 EMDB同步(只能在B服务器上做) ......................................... 42
4.6.2 ERDB同步(只能在B服务器上做) .......................................... 44
4.6.3 RTDB同步(在station上做) ................................................... 45
4.7 Microsoft Hotfix & PKS Patch安装检查...................................... 47
4.7.1 微软Hotfix安装及检查 ............................................................. 47
4.7.2 PlantCruise Patch安装及检查................................................. 50
4.8 Server的配置................................................................................. 51
4.8.1 Event Archive ......................................................................... 51
4.8.2 History Archive....................................................................... 53
4.9 中文环境的设置 ............................................................................. 54
4.9.1 解锁mngr账户 ......................................................................... 54
4.9.2 修改mngr账户语言.................................................................. 55
4.9.3 修改experionadmin账户语言 ................................................. 57
4.9.4 修改注册表(此步骤只针对服务器) ........................................ 57
4.9.5 SQL Memory Configuration.................................................. 58
4.10 操作员安全性的配置(一般情况只针对操作站) ......................... 59
4.10.1 需要新建一个批处理文件(.bat格式) ................................... 59
4.10.2 新建操作员账户(此步骤在服务器和操作站上都要做) ......... 60
4.10.3 更改explore文件属性,如图: .............................................. 62
4.10.4 更改iexplore属性(方法同上).................................................. 63
4.10.5 更改Taskmgr属性(方法同上)................................................. 63
4.10.6 重启电脑检查安全配置是否成功............................................. 63
GMT+8, 2025-3-31 06:47
