[Honeywell] 霍尼韦尔 PKS R5XX 装机及配置手册
bluesky1 发表于 2023-8-9 14:01:01 | 显示全部楼层 |阅读模式
内容类型
内容类型: 文档
PKS R5XX装机及配置手册_R05.pdf (6.46 MB, 售价: 3 E币)
1 装机准备...................................................................................4
1.1 CHECK LIST............................................................................4
1.2 总体安装步骤 .........................................................................6
1.3 Check BIOS setting & Version & RAID ......................................7
1.3.1 Check T5810 BIOS Version....................................................7
1.3.2 T5810XL RAID Setting..........................................................9
2 配置文件 .................................................................................10
3 安装 dongle..............................................................................24
4 配置文档引导装机......................................................................24
4.1 安装 PKS 软件 ..........................................................................24
4.2 添加 Product Administrator ........................................................29
4.3 更改 host 文件 ..........................................................................30
4.4 查看 FTE 网的配置.....................................................................31
4.5 添加 server................................................................................34
4.6 冗余服务器的同步 .....................................................................36
5 Hotfix Patch 安装检查....................................................................41
5.1 微软 Hotfix 安装及检查 ..............................................................41
5.2 PKS Patch 安装及检查 ................................................................43
6 Server 配置...................................................................................44
6.1 Event Archive.............................................................................44
6.2 History Archive ..........................................................................47
6.3 中文环境的设置 .........................................................................48
6.4 SQL Memory Configuration..........................................................51
7 操作员安全性的配置......................................................................52
8 AUDIT...........................................................................................58
8.1 Check R330 RAID CONTROLLER WRITE POLICY ..........................58
8.2 Server IDRAC setting..................................................................58
9. 其它说明.....................................................................................59
10. 注意..........................................................................................60
GMT+8, 2025-3-31 06:51
