[Honeywell] 霍尼韦尔 EXPERION PKS R430安装指南手册
bluesky1 发表于 2023-8-9 12:32:13 | 显示全部楼层 |阅读模式
内容类型
内容类型: 文档
GSB-SNC 23004 System R430 Installation Guide.pdf (2.88 MB, 售价: 5 E币)
1 安装介绍..................................................................................5
1.1 安装光盘...............................................................................5
1.2 安装方式...............................................................................5
1.2.1 光盘安装.............................................................................5
1.2.2 ESIS (Experion Software Installation Server).........................5
2 安装之前................................................................................6
2.1 将 dongle(软件狗)插入主机的 USB 接口 ............................6
2.2 确认 BIOS 版本是否兼容.......................................................6
2.3 升级 Raid Controller 驱动 .....................................................6
2.4 确认 Initialization media 支持安装的系统................................6
3 光盘安装.................................................................................7
3.1 配置安装文件.......................................................................7
3.1.1 插入初始化光盘 ................................................................7
3.1.2 欢迎界面, Utilities 功能....................................................7
3.1.3 选择安装配置文件类型.......................................................8
3.1.4 选择操作系统,安装服务器还是操作站................................8
3.1.5 配置计算机名,账户,密码 ...............................................10
3.1.6 FTE 设置...........................................................................11
3.1.7 Initialization 盘配置完毕,换 installation 盘继续配置 ...........12
3.1.8 插入 Installation 光盘 .......................................................12
3.1.9 声明和协议无配置,下一步 ...............................................13
3.1.10 选择安装 PKS 产品..........................................................13
3.1.11 输入 license ...................................................................14
3.1.12 安装路径默认..................................................................15
3.1.13 节点网络配置..................................................................15
3.1.14 Base IP 地址配置.............................................................16
3.1.15 安装功能选择..................................................................16
3.1.16 账户密码设置..................................................................17
3.1.17 账户密码严正................................................................17
3.1.18 配置信息显示.................................................................18
3.1.19 保存配置文件................................................................18
3.1.20 配置结束........................................................................19
3.2 系统安装............................................................................20
3.2.1 光盘启动.........................................................................20
3.2.2 选择配置文件..................................................................20
3.2.3 选择安装方式,安装路径,磁盘分区 .................................21
3.2.4 接受授权信息,开始安装..........................................................21
3.2.5 根据提示,更换光盘,进行安装,直到结束 .............................21
4 ESIS 安装.........................................................................................22
4.1 安装 Experion software installation server.....................................22
4.1.1 插入 Installation 光盘 ................................................................22
4.1.2 创建 ESIS 存储 .........................................................................22
4.1.3 选择存储路径............................................................................23
4.1.4 共享存储路径............................................................................23
4.1.5 ESIS 存储的内容.......................................................................24
4.1.6 按照提示,安装 ESIS ...............................................................24
4.2 配置文件........................................................................................25
4.3 系统安装........................................................................................25
4.3.1 光盘启动...................................................................................25
4.3.2 选择配置文件............................................................................25
4.3.3 选择安装方式,安装路径,磁盘分区 ........................................25
选择 ESIS 安装, 其他操作同光盘安装...............................................25
4.3.4 接受授权信息,开始安装..........................................................25
4.3.5 根据提示,更换光盘,进行安装,直到结束 .............................25
5 系统配置...........................................................................................25
5.1 添加 PKS 管理员与工程师权限 ......................................................25
5.1.1 选择账户...................................................................................25
5.1.2 添加权限...................................................................................25
5.2 节点与 IP 地址映射 ........................................................................26
5.3 补丁安装........................................................................................27
5.3.1 微软补丁安装(Hot fix) ...............................................................27
5.3.2 PKS 补丁安装 ...........................................................................27
5.4 Event 归档及历史归档 ...................................................................28
5.5 SCE 安装配置................................................................................28
5.5.1 配置 SCE 安装信息...................................................................28
5.5.2 安装 SCE..................................................................................28
5.6 配置冗余信息.................................................................................29
5.6.1 将冗余服务器 A,B 切换到 stop 状态 ..........................................29
5.6.2 打开命令提示符 ........................................................................29
5.6.3 输入命令...................................................................................29
5.6.4 执行完毕...................................................................................29
5.7 组态工具........................................................................................29
5.7.1 时钟同步...................................................................................29
5.7.2 更改密码...................................................................................29
5.7.3 节点重新命名............................................................................30
GMT+8, 2025-3-31 06:50
