SIMATIC STEP 7 Professional 2021 SR1英文版 Step 7 V5.7 SP1 HF2+模拟器下载
winds 发表于 2023-8-2 23:36:03 | 显示全部楼层 |阅读模式
安装文件下载地址:注意:安装完毕后必须重启计算机。
百度网盘下载链接.txt (754 Bytes, 售价: 1 E币)
如果运行安装文件反复提示重启可以参考:
西门子系列工控软件安装提示反复重启解决方法
https://www.eleok.com/thread-117549-1-1.html
兼容操作系统:
STEP 7 Professional 2021 SR1 can be used with the following operating systems:
MS Windows 10 Pro and Enterprise (64-bit)
MS Windows 11 Pro and Enterprise (64-bit)
(注)Windows 11系统不支持以下模块的在线连接:CP 5611 A2、CP 5621、CP 1612 A2
MS Windows Server 2016 (64-bit) (Standard Edition as work station computer)
MS Windows Server 2019 (64-bit) (Standard Edition as work station computer)
MS Windows Server 2022 (64-bit) (Standard Edition as work station computer)
包含内容
-        STEP 7 V5.7 SP1
-        Automation License Manager V6.0 SP9 incl. Upd3
-        S7-GRAPH V5.7 SP1
-        S7-SCL V5.7 HF1
-        S7-PLCSIM V5.4 SP8 incl. Upd1
-        S7 Web2PLC V1.0 SP4
Application for creation and setup of user-defined Web pages for the Web server of the CPU.
-        S7 Block Privacy V1.0 SP5
Application for encoding of blocks.
Notes:
A block protected with Block Privacy can only be loaded to the following CPUs:
- S7-300 and ET 200 CPUs as of firmware V3.2
- S7-400 CPUs as of firmware V 6.0
- A block protected with "Block Privacy" will not be considered in the reference data lists! Keep this in mind when creating protected blocks. All global variables used in creating protected blocks cannot be entered in the reference data list. This means you should not use global variables in the protected blocks.
GMT+8, 2025-3-31 06:58
