[文档] 三菱数控系统NAVI MILL for 700/70使用说明书
dami 发表于 2023-3-10 16:33:54 | 显示全部楼层 |阅读模式
M700 70系列 简易编程功能NAVI MILL使用说明书.pdf (6.83 MB, 售价: 3 E币)
1. 概要............................................................................................................................................1
1.1 系统概要 ...................................................................................................................................1
1.2 输入步骤 ...................................................................................................................................2
1.3 画面构成 ...................................................................................................................................3
1.4 NAVI MILL 操作开始 ..................................................................................................................4
1.5 NAVI MILL 的设定.......................................................................................................................5
2. 显示区域的功能............................................................................................................................7
2.1 列表视图区 ................................................................................................................................8
2.2 操作视图区 ................................................................................................................................10
2.3 设定区.......................................................................................................................................11
2.4 信息区...................................................................................................................................... 11
2.5 菜单显示区 ...............................................................................................................................11
3. 基本操作.....................................................................................................................................12
3.1 视图活动状态切换......................................................................................................................12
3.2 画面切换 ...................................................................................................................................12
3.3 数据设定 ...................................................................................................................................14
3.4 窗口切换 ................................................................................................................................... 17
3.5 选项卡切换 .................................................................................................................................17
3.6 运算输入 ....................................................................................................................................18
4. 画面规格...................................................................................................................................... 19
4.1 NAVI MILL 启动 .......................................................................................................................... 19
4.2 程序相关画面............................................................................................................................... 20
4.2.1 程序编辑画面 ............................................................................................................................. 20
4.3 工程编辑功能相关画面.................................................................................................................. 24
4.3.1 工程列表画面 ........................................................................................................................... 24
4.3.2 多工件加工画面........................................................................................................................ 26
4.3.3 工程的操作 .............................................................................................................................. 29
4.3.4 工程模式选择画面 ....................................................................................................................35
4.3.5 初始条件设定画面 ....................................................................................................................38
4.3.6 钻孔工程.................................................................................................................................. 42
4.3.7 面铣工程...................................................................................................................................54
4.3.8 轮廓切削工程.............................................................................................................................58
4.3.9 口袋工程................................................................................................................................... 68
4.3.10 EIA 工程画面 ...........................................................................................................................77
4.4 文件编辑相关画面.........................................................................................................................78
4.4.1 刀具文件画面............................................................................................................................ 78
4.4.2 切削条件文件画面...................................................................................................................... 80
4.5 参数相关画面 ...............................................................................................................................82
4.5.1 参数画面.......................................................................................................................................82
4.5.2 环境设定画面...............................................................................................................................85
4.6 版本相关画面................................................................................................................................. 87
4.6.1 版本画面..................................................................................................................................... 87
4.7 程序校验画面.................................................................................................................................. 88
4.8 向导功能 ........................................................................................................................................ 93
4.8.1 刀具向导画面 ................................................................................................................................ 94
5. 程序规格.............................................................................................................................................95
5.1 NC 程序 .......................................................................................................................................... 96
5.1.1 NC 程序的输出形式 .......................................................................................................................96
5.1.2 限制事项........................................................................................................................................99
5.2 文件程序 .........................................................................................................................................101
5.3 参数程序 ..................................................................................................101
5.4 宏程序............................................................................................................................................ 101
6. 刀具功能............................................................................................................................................ 102
6.1 刀具交换指令(M6)及 T 指令 ...............................................................................................................102
6.2 刀具编号及创建下一个刀具编号..........................................................................................................103
7. CNC 功能的规格限制 ...........................................................................................................................104
8. 报警信息............................................................................................................................................. 105
8.1 错误信息 ........................................................................................................................................... 105
8.2 警告信息 .............................................................................................................................................109
8.3 操作信息 .............................................................................................................................................109
附录 1. NAVI MILL 中使用的变量 ................................................................................................................ 110
附录 2. 程序例 ............................................................................................................................................113
附录 2.1 加工图纸 ......................................................................................................................................113
附录 2.2 工程表............................................................................................................................................114
附录 2.3 条件设定 ....................................................................................................................................... 115
附录 2.4 创建程序 ........................................................................................................................................116
GMT+8, 2025-3-31 06:51
