[CNC] FANUC CNC GUIDE V25.0 安装文件下载
mihaa 发表于 2022-10-5 01:00:26 | 显示全部楼层 |阅读模式
支持的操作系统:Windows 8.1 Pro (32bit,64bit) 和 Windows 10 (32bit,64bit) Recommended Version 2004 or higher + .NET Framework2.0/.NET Framework 3.5
安装文件下载:
FANUC CNC GUIDE V25.00 下载
https://www.eleok.com/thread-123684-1-1.html
Update history
   Ver 20.20 (2021.4.20)
        - The CNC GUIDE that authorize the license with the software license,
          the first edition.
   Ver 22.00 (2021.8.4乯
        - Academic package has been added.
        - Multi-user license by network has been supported.
        - The following CNC System has been added.
          + FS35i-B Line     : G641 / 27
        - The following improvements have been applied:
          [FS32i-B Line]
          + Start from machine composition setting data has become available.
          [FS30i/31i/32i-B Plus, FS30i-B Plus 72AX]
          + In the machine composition setting data,
            parameters that option can be set enable or disable set '0'.
          [FS30i-B, FS30i-B Plus]
          + In the case of the machine composition setting data that uses iHMI,
            the following option set enable by default.
            iHMI MACHINING CYCLE(FOR 1 PATH SYSTEM)(R911)
            iHMI MACHINING CYCLE(FOR 2 PATH SYSTEM)(R912)
            iHMI MACHINING CYCLE(FOR 3 PATH SYSTEM)(R913)
            iHMI MACHINING CYCLE(FOR 4 PATH SYSTEM)(R914)
          [FS0i-F, FS0i-F Plus]
          + The following options were able to be used with MANUAL GUIDE i enabled.
            Loader control function(R417)
            Addition of loader control path(R418)
   Ver 22.20 (2021.10.5)
        - The following problem is corrected.
          + When Information Center of iHMI is displayed,
            the contents of Display Details may not correct.  (FS30i/31i/32i-B Plus)
          + The comments of parameter screen may not correct.  (FS35i-B Line)
          + In iHMI, 4-digit G-code cycle may not be executed.  (FS30i/31i/32i-B, FS30i/31i/32i-B Plus, FS0i-F Plus)
          + In machining simulation of MANUAL GUIDE i, tool rotary axis
            during the polar coordinate interpolation with inch input is not drawn correctly.
            (FS30i-A, FS0i-D, FS30i/31i/32i-B, FS30i/31i/32i-B Plus, FS0i-F, FS0i-F Plus)
   Ver 23.10 (2021.11.26)
        - The error message in case there is no valid license has been changed.
   Ver 24.00 (2021.12.24)
        - MOP Simulator has been supported.
        - CNC System has been updated to following series / version.
          + FS0i-F           : D4G2/D6G2 / 47
          + FS0i-F Plus      : D4G3/D6G3 / 28
          + FS30i-B          : G313 / 54
          + FS30i-B 32AX     : G323 / 54
          + FS30i-B 48AX     : G333 / 54
          + FS31i-B          : G413 / 54
          + FS31i-B5         : G433 / 54
          + FS32i-B          : G503 / 54
          + FS35i-B 16AX     : G613 / 54
          + FS30i-B Plus     : G317 / 18
          + FS31i-B Plus     : G417 / 18
          + FS31i-B5 Plus    : G437 / 18
          + FS32i-B Plus     : G507 / 18
          + FS30i-B Plus 72AX : G3GD / 11
        - iHMI System has been updated to following series / version.
          + FS0i-F Plus      : K779 / 12
   Ver 24.20 (2022.4.8)
          + FS30i-LB Plus     : G3D7 / 5
   Ver 25.00 (2022.5.31)
          + FS0i-LF Plus      : DCG3 / 09
          + FS30i-LB          : G3D5 / 21
        - iHMI System has been supported to following series / version.
          + FS0i-LF Plus      : K787 / 14
          + FS30i-LB Plus     : K789 / 09
          + FS30i-LB          : K778 / 16
          + FS0i-F            : D4G2/D6G2 / 49
          + FS0i-F Plus       : D4G3/D6G3 / 30
          + FS30i-B           : G313 / 55
          + FS30i-B 32AX      : G323 / 55
          + FS30i-B 48AX      : G333 / 55
          + FS31i-B           : G413 / 55
          + FS31i-B5          : G433 / 55
          + FS32i-B           : G503 / 55
          + FS35i-B 16AX      : G613 / 55
          + FS30i-B Plus      : G317 / 19
          + FS31i-B Plus      : G417 / 19
          + FS31i-B5 Plus     : G437 / 19
          + FS32i-B Plus      : G507 / 19
          + FS32i-B Plus Line : G547 / 19
          + FS30i-B Plus 72AX : G3GD / 12
          + FS0i-F Plus          : K797 / 03
          + FS30i/31i/32i-B      : K795 / 06
          + FS30i/31i/32i-B Plus : K796 / 08
        - The following options have been added.
          [FS30i/31i/32i-B, FS30i-B 32AX/48AX, FS30i/31i/32i-B Plus,
           FS30i-B Plus 72AX, FS0i-TF, FS0i-TF Plus]
          + 4th/5th axis offset(R517)
          + Tool posture turning(R338)
          + Speed control with acceleration in circular interpolation(J809)
          + Optimum torque acceleration/deceleration(S675)
          [FS30i/31i/32i-B Plus]
          + High-speed processing(S809)
          [FS0i-F Plus]
          + CNC Screen size 15/19 inch has become available.
            (19 inch display is only Window Mode)
          + Some Reading Diagnosis Data (High-speed Response) functions that terminates abnormally with PMC Window are changed to return completion code 3. (The specified diagnosis data number is invalid)
          + If CNC GUIDE is forcibly terminated while rewriting the parameter, the parameter may become incorrect after the next launch.
          + If Italian, Russian, Bulgarian, or Hindi is selected as the input language for Windows, warning dialog will be displayed when CNC GUIDE is launched.
          [FS0i-D]
          + If you restart immediately after creating new program on the O list screen of MANUAL GUIDE i, and press new soft key on the O list screen, the screen will be frozen.
GMT+8, 2026-9-28 19:22
