[PLC编程] SIMATIC SIMATIC S7 F-FH Systems V6.3 下载
zhangbing 发表于 2021-12-21 02:59:43 | 显示全部楼层 |阅读模式
安装文件下载:
Software requirements Operating systems
●    The following operating systems are supported on the ES and OS:
–    MS Windows 10 Enterprise 2015 LTSB (64-bit)
–    MS Windows 10 Enterprise 2019 LTSB (64-bit)
–    MS Windows Server 2012 R2 Update Standard Edition (64-bit)
–    MS Windows Server 2016 Standard Edition (64-bit)
–    MS Windows Server 2016 Datacenter Edition (64-bit)
Software packages In order to operate
SIMATIC S7 F Systems V6.3, the following software packages must be installed:
●    On the ES:
–     PCS 7 V9.0 SP2 or higher or SIS compact V9.0 SP2 or higher and STEP7 V5.6 SP1 HF5 or higher
Or
–    STEP 7 as of V5.6 SP1 HF5 and CFC as of V9.0 SP3
●    On the OS (for SIMATIC S7 F Systems HMI)
Or
–    SIS compact V9.0 SP2 or higher
–    Optional: WinCC V7.4 SP1 Upd10
●    For offline testing
–    S7-PLCSIM V5.4 or higher
Available installation units SIMATIC S7 F Systems comprises the following installation units:
●    Engineering:
–    SIMATIC S7 F Systems V6.3
–    SIMATIC S7 F Systems HMI V6.3
–    SIMATIC S7 F Systems Library V1.3 SP3
–    SIMATIC S7 F Device Integration Pack V6.3
–    SIMATIC S7 F Configuration Pack V5.5 SP13
–    Automation License Manager V5.3 SP4 Upd5
●    Runtime:
GMT+8, 2025-2-23 12:48
