[PLC编程] SIMATIC Safety Matrix V6.2 SP2 下载
zhangbing 发表于 2021-12-21 02:40:55 | 显示全部楼层 |阅读模式
安装文件下载:
Software requirements
The following operating systems are supported:
●        MS Windows XP SP2 or SP3
●        MS Windows Server 2003 SP1 or SP2 with or without R2
●        MS Windows Server 2008 Standard Edition as workstation computer (32-bit)
●        MS Windows 7 32-bit & 64-bit Professional, Ultimate & Enterprise with or without SP1
●        MS Windows Server 2008 R2 as workstation computer with or without SP1
You have to install the following software packages to operate Safety Matrix V6.2 SP2:
●        For Safety Matrix Engineering Tool V6.2 SP2
・        S7 F Systems V5.2 SP1 or higher
・        F-library  Fail-safe Blocks (V1_2) or S7 F Systems Lib V1_3
・        For offline testing: S7‑PLCSIM, depending on the installed S7 F System version
・        Automation License Manager (ALM) as of V5.3
For use with PCS 7 *)
・        PCS 7 as of V7.0 SP3
For use without PCS 7 *)
・        STEP 7 as of V5.4 SP3 HF7
・        CFC as of V7.0 SP1 HF8
*) Note the restrictions onCFC versions in the readme for Safety Matrix Engineering Tool section 3.1 "Notes on the add-on package"
●        For Safety Matrix Viewer V6.2 SP2
●        For Safety Matrix Editor V6.2 SP2
Windows versions as listed above
●        For Safety Matrix AS-OS-Engineering V6.2 SP2
Available installation units
Safety Matrix consists of the following installation units:
●        Safety Matrix Engineering Tool V6.2 SP2
Configuration, library, compiling, loading, operating and monitoring of safety matrices using STEP 7 SIMATIC Manager on a PCS 7 or STEP 7 engineering system (ES)
●        Safety Matrix Viewer V6.2 SP2
Block icons and faceplates for Safety Matrix in PCS 7 OS
●        Safety Matrix Editor V6.2 SP2
Configuring safety matrices on PC outside PCS 7 or STEP 7
●        Safety Matrix AS-OS-Engineering V6.2 SP2
Compiling PCS 7 OS with safety matrices in a PCS 7 project
GMT+8, 2025-4-2 00:27
