[PLC编程] SIMATIC Safety Matrix V6.1 下载
zhangbing 发表于 2021-12-21 00:14:49 | 显示全部楼层 |阅读模式
安装软件下载
The following operating systems are supported:
●        Windows 2000 SP4 (Server or Professional)
●        Windows XP SP2
●        Windows Server 2003 SP1 and higher
To operate Safety Matrix V6.1, you must have installed the following software packages:
●        For Safety Matrix Engineering Tool V6.1
・        For use with PCS 7
-        PCS 7 V6.0 SP3 PF or higher, or PCS 7 V6.1 SP2, or PCS 7 V7.0 SP1
-        S7 F Systems V5.2 SP1 or higher
-        F-library Failsafe Blocks (V1_2) or S7 F Systems Lib V1_3
・        For use without PCS 7
-        STEP 7 V5.4 SP3 or higher
-        CFC V7.0 SP1 HF3 or higher
●        For Safety Matrix Viewer V6.1
・        PCS 7 V6.0 SP3 PF or higher, or PCS 7 V6.1 SP2, or PCS 7 V7.0 SP1
●        For Safety Matrix Editor V6.1
・        Windows versions as listed above
●        For Safety Matrix AS-OS-Engineering V6.1
・        S7 F Systems V5.2 SP1 or higher
・        F-library Failsafe Blocks (V1_2) or S7 F Systems Lib V1_3
Available installation units
Safety Matrix consists of the following installation units:
●        Safety Matrix Engineering Tool V6.1
Configuring, compiling, downloading, operating and monitoring Safety Matrices by means of STEP 7 SIMATIC Manager on a PCS 7 or STEP 7 Engineering System (ES)
●        Safety Matrix Viewer V6.1
Block icon and faceplate for Safety Matrix in PCS 7 OS
●        Safety Matrix Editor V6.1
Configuring of Safety Matrices on PC outside of PCS 7 or STEP 7
●        Safety Matrix AS-OS-Engineering V6.1
Compiling of PCS 7 OS with Safety Matrices in a PCS 7 project
GMT+8, 2025-4-2 00:27
