[PLC编程] SIMATIC S7 F Systems V6.0 下载
zhangbing 发表于 2021-12-20 19:24:34 | 显示全部楼层 |阅读模式
安装文件下载:
Software Requirements
Supported operating systems:
●        Windows 2000 SP4 (Server or Professional)
●        Windows XP SP2
●        Windows Server 2003 SP1 or SP2
You must install the following software packages in order to work with S7 F Systems V6.0:
●        On the ES
        STEP 7 V5.3 HF4 or later
        CFC V6.0 SP2 HF3 or later
        When using PCS 7: PCS 7 V6.0 SP3 PF or later with the STEP 7 and CFC version included
●        On the OS (for S7 F Systems HMI)
●        For offline-testing
        S7-PLCSIM V5.3 SP1 or later
Contents of the Optional Package
The S7 F Systems contains the following components:
●        S7 F Systems V6.0
●        S7 F Systems HMI V5.2 SP3
●        S7 F Systems Lib V1_3
●        S7 F Configuration Pack V5.5 SP3
●        S7 F Configuration Pack V5.4 SP1
●        Automation License Manager V3.1 HF3
The correct version of the S7 F Configuration Pack will be installed based on whether you have installed PCS 7 and which version you have installed. For more information, read the installation notes in Chapter 3 of the "S7 ConfigurationPack - readme" file for S7 F Configuration Pack V5.5 SP3.
GMT+8, 2025-4-2 00:27
