用户名  找回密码
帖子
Sim_EKB_Install_2024_12_08
litong1 发表于 2021-10-25 15:58:06 | 显示全部楼层 |阅读模式
使用需要鼠标右键--”管理员权限运行“,另外注意有些杀毒软件可能误杀,可以在解压前暂时退出杀毒软件进行测试。
仅提供个人在家学习用途,此程序文件来源于网络可靠性稳定性完整性皆无法验证,禁止用于其他用途,否则后果自负。
解压密码是123
121395_Sim_EKB_Install_2024_12_08_Run_As_Admin_password_123.zip (访问密码: 6206)
4744 keys
v2024.06.04 add CloudConnector key 779f02809813e34bcd621a9b97683be6bc5a96c93be2e0c67358713ee8405a0d *Sim_EKB_Install_2024_06_04_Run_as_Admin.exe
v2023.11.24 add some info for TIA Portal v19 f190c58516ea4bf4e0ee4cd28ff5501e3d0444834d8c818e23ab7f1884f14ee7 *Sim_EKB_Install_2023_11_24_Run_as_Admin.exe
I removed the "Select All" checkbox due to its incorrect use.
"Select ALL" will now only be available for Optimal and Minimum keyset folders.
You never need to install all the keys, because a weak key for 1 tag blocks a large key for 1,000,000 tags.
v2023.09.09 add some info 39d9f5f70db56f90007480481534b2498fdd66a0cdeabdff1079b4bb38879986 *Sim_EKB_Install_2023_09_09_Run_as_Admin.exe
v2023.04.04 add some info for WinCC v8.0 dd34a7d864a41e42f441bd1703af65b527f0ec183a2c25d08c6c391d8c37bf16 *Sim_EKB_Install_2023_04_04_Run_as_Admin.exe.exe
v2022.11.27 add some info for TIA Portal v18 b59248759b1633c4e8bbbbdb05e4ebe9f38c7ef84fdf73de558bda1d7f3ea645 *Sim_EKB_Install_2022_11_27_Run_as_Admin.exe
v2022.09.27 add some info for internal testing Sentron 1c34f372b65435dc362fa32adc25e905a69a26b4281452451a9f02f893fc3b7b *Sim_EKB_Install_2022_09_27_Run_as_Admin.exe
v2022.09.26 add some info for internal testing Sentron 2cf956c0e7cfb3ff876754672da7636588291c07770361ce386d0bd1f2565330 *Sim_EKB_Install_2022_09_26_Run_as_Admin.exe
v2022.07.26 add some info for Energy Manager v7.3 074c20d47e1b0bcb60fe53b62f19622a5171be410c1ec2a49a4dcc8815d8b3fb *Sim_EKB_Install_2022_07_26_Run_as_Admin.exe
v2022.04.04 add some info for Sinumerik v4.95-v4.99 7ccc39a03c080d0d072c716079760a74f88da5877c0431f6503d358cafd6f60d *Sim_EKB_Install_2022_04_04.exe
v2021.08.20 add some info for Simotion Scout v5.4 ae1a88dba321cf1c4201d7bcb9f5710bf6ea393a8067f73c89ae821e7533ebd7 *Sim_EKB_Install_2021_08_20.exe
v2021.08.15 add some info for Target fot Simulink 682eb91690789c537160d90f979551d36b5341e065371865abb05aceef4af5c2 *Sim_EKB_Install_2021_08_15.exe
v2021.08.14 add some info for TIA Portal CFC v17 926590c9d8ab46ed0d01fcb3240ec59d6eb45aa458ff6bbdcd6c53afdf49de60 *Sim_EKB_Install_2021_08_14.exe
v2021.06.22 add some info for Step7 v5.7 2be3a8a8bbeab5744cc167082b7049ec85dfe8f5ef37d59bdb0862f09c618839 *Sim_EKB_Install_2021_06_22.exe
v2021.06.02 add some info for TIA Portal v17 1f22cc93d7ce43ff580b844deb347f1245624274db66b5fb14fd18538fa68c44 *Sim_EKB_Install_2021_06_02.exe
v2021.06.01 add some info for TIA Portal v17 8751ac942e6768cc655e393d7ea1ab1e *Sim_EKB_Install_2021_06_01.exe
v2021.04.20 add some info for SICAM 46f820ad8962612114541677243eee49 *Sim_EKB_Install_2021_04_20.exe
v2021.04.12 add some info for PCS 7 v9.1 //MD5:  ac74ff3ddbfcbac6c405f5e1d71d9b9c *Sim_EKB_Install_2021_04_12.exe
v2020.10.10 add some info for Proneta, SinuTrain 4.93 //MD5:  362cf5eb28e0798ce5839c5d13a349b3 *Sim_EKB_Install_2020_10_10.exe
v2020.04.17 add some info for TIA Portal v16, Energy 7.2 //MD5:  d6261438101be0571287bdb01796d1d7 *Sim_EKB_Install_2020_04_17.exe
v2020.02.29 add some info for TIA Portal v16, Braumat v8 //MD5:  e837987fd7aef87f42b0b28ddda9d305 *Sim_EKB_Install_2020_02_29.exe
v2019.12.13 add some info for TIA Portal v16 //MD5:  96b9bdac1535744b5cfba3c036861c86
v2019.12.08 add some info for TIA Portal v16 //MD5:  88d59829be38be5a71711ca3e649047b
v2019.07.07 add info for D7-SYS, Enegy Manadger Web Clients, Sinetplan, Simotion Scout 0bde7df516c91947379e6ac577c16521 *Sim_EKB_Install_2019_07_07.exe
v2019.06.25d internal for testing Enegy Manadger Web Clients 24c4fee0588f2364d14b35e4fdf5eb9c *Sim_EKB_Install_2019_06_25d.exe
v2019.06.25c internal for testing Enegy Manadger Web Clients a3be54d909c287e90985281d3b3a85e8 *Sim_EKB_Install_2018_06_25c.exe
v2019.06.25b internal for testing Enegy Manadger Web Clients cb0c09e13219372b50b267a08ef391ae *Sim_EKB_Install_2019_06_25b.exe
v2019.06.25 internal for testing Enegy Manadger, Sinetplan, Simotion Scout a7d664c3b2402c80c8944365c3f4f5f8 *Sim_EKB_Install_2019_06_25.exe
v2018.11.14 add info for WinCC v7.5 4df665e01dc195c8c7457646507d3dc1 *Sim_EKB_Install_2018_11_14.exe
v2018.10.30  fixed bug '"15_1" is not valid integer' after installation Portal 15_1 181542fe08ac4f2268a51dab8b5f2f9d *Sim_EKB_Install_2018_10_30.exe
v2018.09.11  add info for Simatic IT v7.1 29b75bc486935b95fc495960f1470b9b *Sim_EKB_Install_2018_09_11.exe
v2018.09.07  add info for Simatic IT v7.1 5a48f6d82f1765e172c9915f25e6b5ee *Sim_EKB_Install_2018_09_07.exe
v2018.08.19  add info for Sinumeric v4.8, Sinamics StartDrive v15 8b18c85790ed809c7ca863fada244cfd *Sim_EKB_Install_2018_08_19.exe
v2018.07.31  internal for testing 9cc5d99394ebbfbc93415f36c97981be *Sim_EKB_Install_2018_07_31.exe
v2018.07.25  add info for Simatic IT v7.1 d9caae5e99e08590e7acef87166c1c08 *Sim_EKB_Install_2018_07_25.exe
v2018.06.08  add info for Simatic IT v7.1 d9caae5e99e08590e7acef87166c1c08 *Sim_EKB_Install_2018_07_25.exe
v2018.06.08  add info for Simatic Automation Tool, Braumat 7.5 8843d2b9e8ae03679b4ea8695dd2fb73 *Sim_EKB_Install_2018_06_08.exe
v2018.06.06  internal for testing
v2018.05.20  add info for Simotion Scout for v5.2 93af98bb4905252eccb24381391bb034 *Sim_EKB_Install_2018_05_20.exe
v2018.05.16  add info for Simotion Scout ... ups... v5.2 8adc0a674e6fe16c4732a855f92202d1 *Sim_EKB_Install_2018_05.exe
v2018.03.10  add info for Target 1500S 475066a87c98affb50148d7d186efc7f *Sim_EKB_Install_2018_03_10.exe
v2017.12.24  add info for TIA Portal v15.0 d1d09c87175629bdff20de1394912256 *Sim_EKB_Install_2017_12_24_TIA15.exe
v2017.12.23  internal for testing
v2017.12.04  add info for CMS X-Tools, Sicam, CPU1500 v3221ceb78e767c2c47beaa84a8a813cf *Sim_EKB_Install_2017_12_04.exe
v2017.11.06  add info for Telecontrol v7.4 bd4d0c64bc42fa6575df4362a8987077 *Sim_EKB_Install_2017_11_06_TC.exe
v2017.10.02  internal for testing 4507c2cbdde48203f7c5db6360337187 *Sim_EKB_Install_2017_10_02_internal_test.exe
v2017.09.01  internal for testing 340881e71bdda777fc0b48b1c2018d35 *Sim_EKB_Install_2017_09_01_Flex.exe
v2017.08.28  add info for DIGSI 07d12e1cf18dd211b3ff35fe5c0d65d2 *Sim_EKB_Install_2017_08_29_DIGSI.exe
v2017.08.25  add info for Sinema Server v14, Simotion Scout v5.1 6a3276e48041a9fb1ead510e94246245 *Sim_EKB_Install_2017_08_25.exe
v2017.08.11  internal for testing Sinema Server
v2017.08.10  add info for Braumat, PCS7 v9.0 9df5c73893fa0ee7c5c0c7c4df07f0f5 *Sim_EKB_Install_2017_08_10.exe
v2017.08.09  internal for testing Braumat, PCS7 v9.0 9518ba050d1c52f3b89746b952881aac *Sim_EKB_Install_2017_08_09.exe
v2017.08.05  internal for testing Braumat, PCS7 v9.0 9d0080d82d02ea9dbde0322db65ba09d *Sim_EKB_Install_2017_08_05.exe
2017.07.**  fake from CIA fakers !!! plc.myforum.ro distribute dangerous fakes !!!
v2017.06.23  add info for WinCC PerformanceMonitor, Sinumerik 961e886a4d0a7f1f99dc80582b12ab4a *Sim_EKB_Install_2017_06_23.exe
v2017.06.03  add info for Step7 v5.6 d94894697bcba56949fcf47590b8746f *Sim_EKB_Install_2017_06_03.exe
v2017.04.13  internal for testing
2017.04.03 - fake from CIA fakers
v2017.04.01 add some info for TIA, 80K RT Flexible 2008, Sinaut and optimized some keyset 75c14222a978ec85be055decd8fbee6d *Sim_EKB_Install_2017_04_01.exe
v2017.01.17 add some info for Panel 8d672a831dce6250d8feafe04f361557 *Sim_EKB_Install_2017_01_17.exe
v2017.01.14 add some info for IS PCS7 949ea884cc9b4f41a234c7e4e2883556 *Sim_EKB_Install_2017_01_14.exe
v2016.11.28  add some info for D7-SYS v8.1 4431eee03720697c1ada83beb19e200e *Sim_EKB_Install_2016_12_05.exe
v2016.11.28  add some info for SoftStarter and Simocode 14 3af2df6969bd421718a2be9be3cb14cf *Sim_EKB_Install_2016_11_28.exe
v2016.11.25  add some info for TIA Portal 57b9f7b47daf28f6f0caf1caa5e8cebc *Sim_EKB_Install_2016_11_25.exe
v2016.11.11  add some info for SICAM 2f596982e0857a6addc0fce8ad5354d2 *Sim_EKB_Install_2016_11_11.exe
v2016.10.26  add some info for TIA Portal v14 191d03600f175d7697c9dabafc1925b6 *Sim_EKB_Install_2016_10_26.exe
v2016.10.11  add some info for TIA Portal v14 58d7b14c9dc7af6c7515296d9baac1c3 *Sim_EKB_2016_10_11_TIA14.exe
v2016.10.10  add some info for TIA Portal v14 bed8861d03f384e411e53b05cb999f48 *Sim_EKB_Install_2016_10_10_TIA14.exe
v2016.09.06  add some info for WinCC TeleControl 0317bb0bf48251acab72dab273411860 *Sim_EKB_Install_2016_09_06_TC.exe
v2016.08.16  internal for testing
v2016.07.16  add some info for WinCC WebNavigator v7.4 e190b1c240fe0908c2fc6085bbec413c *Sim_EKB_Install_2016_07_16.exe
v2016.05.30  add some info for PCS7 v8.2 950187a0303ab55fb99d30eb46f006f3 *Sim_EKB_Install_2016_05_30_DM.exe
v2016.05.06  add some info for PCS7 v8.2 35e7872a5adf9e769ad06ec4151f1947 *Sim_EKB_Install_2016_05_06.exe
v2016.04.25  add some info for WinCC v7.4, PCS7 v8.2, TIA Portal v14 89e4224d5710ee2f1d656e5d3ea2c5c5 *Sim_EKB_2016_04_25_WinCC.exe
v2016.04.12  internal for testing
v2016.03.12  add some info for Sinutrain v4.7 bbda2902d765225085a378d0d3b78632 *Sim_EKB_Install_2016_03_12_Sinutrain.exe private for testing
v2015.11.24  add some info for Braumat v7.0, PDM v9.0 b34930d7d8f0dabf8f8e269aa89aa422 *Sim_EKB_Install_2015_11_14_Bramaut.exe private for testing
v2015.10.22 add some info for PCS7 8.1 SMART station 96440b85e6646e1722ac0387a17f37e3 *Sim_EKB_Install_2015_10_22.exe
v2015.10.21 add some info for SinuTrain v4.7 eee5018351d5d99606c00b41a9df2f0c *Sim_EKB_Install_2015_10_21.exe
v2015.10.14 add some info for Audit v7.3 d767bea8610dc49141f57730853c7743 *Sim_EKB_Install_2015_10_14.exe
v2015.09.04 add some info for Software CPU 1507S //MD5: 589b2b79d3f67007e2ef613b81e411f6 *Sim_EKB_Install_2015_09_04.exe
v2015.08.31 add some info for Safety ES v1.0, Software CPU 1500S //MD5: 7938f4a9c3976c12566ebad1ea7da9bf *Sim_EKB_2015_08_31.exe
04.08 is romanian gypsy fake !!! plc.myforum.ro distribute dangerous fakes !!!
v2015.03.29 add some info for NET v13  //MD5: 542e0e7697460598cec371f5160b62be
v2015.02.10 add some info for Simocode v13 //MD5: 7d5f0a35915f39e0009635f750630adb
v2015.02.01 add some info for Cemat v8.0 //MD5: f4bea40978b125de557fa43845e8377e
v2014.12.27 add some info for Cemat v8.0 //MD5: c3d7b48a5c0c86a8cdcf4f8d64e29bab
v2014.11.11 add some info for PCS7 v8.1 //MD5:  e8ad4a811d8a76ca39ff0ef12248e12f
v2014.11.09 add some info for PCS7 v8.1 //MD5: 50923874052344ddcf031a6a036a224f
v2014.10.02 add some info for PCS7 v8.1 //MD5:  858cbee929bec0a41eb7f94391ce13f7
09.19 is romanian gypsy fake !!! plc.myforum.ro distribute dangerous fakes !!!
v2014.09.13 add some info for SinuTrain v4.5 //MD5:  8a788f25118e84f9f5a6cef6de486fff
v2014.09.13 add some info for Simatic WinCC v7.3/v13, Scout v4.4 //MD5:  91079d468dd72fa0e5a47f556e750539
v2014.08.05 test for Scout v4.4 //MD5: 029d67e86ba859f2cc584c0076420a68
08.01 is romanian gypsy fake !!! plc.myforum.ro distribute dangerous fakes !!!
v2014.07.28 add some info //MD5: 50659cf2c2f972460692ca7ce9461d1d
v2014.03.08 add some info //MD5: f40d1b432f529f53002d9514e7a3bf1b
v2013.12.25 add some info for Simatic Net v12 //MD5:  0ade8808e789e6e704e66b0877c1c04f *Sim_EKB_Install_2013_12_25.exe
v2013.12.10 add some info for Simocode v12 // MD5: 10a0c74548ba89b80e98f2664289ba79
v2013.12.02 add some info for PDM v8.1
v2013.12.01 add some info for Softnet Security Client v4.0
v2013.05.26 add some info for WinCC v7.2
v2013.03.08 fix 1 key for TIA Portal v12
v2013.03.03 add TIA Portal v12, S7-Technology, fix Unicode bug for some new keys folder
v2013.03.01_test add TIA Portal v12 with some bug for all Unicode version from v2012.10.12
v2013.01.21 fix bug with PID v11.0 keys, add some info for D7-SYS v8.0
v2012.10.12 add Chinese language (possible Cyryllic chars in the European interfaces :) ASCII > Unicode
v2012.09.29 add some info for Easy Motion v11.0, SinuTrain 4.4
v2012.07.29 add some info for  PID v11.0 *but with error :(
v2012.07.23 add some info for Simotion Scout v4.3
v2012.07.19 add some info for Telecontrol Server Basic v2.0 and fix comment bug
v2012.07.18 add some info for PDM v6.1.
v2012.03.08 add some info for PCS7 v8.0.
v2012.02.26 add some info forWinCC Flexible 2008 SP3, Simatic Net v8.1. Fixed bug of euristic engine.
v2012.01.26 add some info for Simatic Net v8.1
14/05/2011 add some info for TIA Portal V11
15/02/2011 This internal version for testing add some keys
11/10/2010 add some info for....
10/10/2010 add one info for "SIK/ SIMATIC S5 PMC IE V7.0" ("A9S5IE70")
09/09/2010 add some info for WinCC DowntimeMonitor, WinAC, fix bug for comp and Virtual Machine with 1 HardDisk partition
09/05/2010 add keys for WinCC Flexible 2008 SP2 options v1.3, Sinaut, fixed one ALM v5 bug
20/04/2010 add some keys Safety Matrix, PCS7 powerrate, PCS7 CFC AS RT SIFPZASRPX9999A
20/03/2010 add some keys, "option Recommended" and info about closed PLC.NET.RU and reopened http://plcforum.uz.ua
26/08/2009 add keys for TIA Portal v10.5, Braumat,  Maintenance Station 2009
04/04/2009 add keys for WinAC MP 2008, PCS7 v7.1
22/12/2008 add keys for WinAC 2008, Simatic Net 2008, RF-Manager 2008
20/08/2008 add keys for WinCC Flexible 2008
24/07/2008 Open FastCopy v3 key option
21/07/2008 add keys for WinCC v7.0
29/06/2008 add keys for PID Tools v5.2, D7-SYS v7.0, PowerControl, RF-Manager
14/03/2008 add keys for Simatic IT and multikey description
23/02/2008 add keys for CEMAT v7.0 ,  WinCC v6.2 and PCS7 v7.0
18/02/2008 add keys for Simocode 2007
15/02/2008 add keys for DocPro 5.4, WinAC MP 2007, Soft Starter 2007  and fix error for "New" folder07/12/2007 add keys for Sinema E 2006 and fix error for Motor Starter 2007 (but add bug - not install keys from "New" folder)
30/11/2007 add keys for Motor Starter 2007, Net 2007
27/11/2007 add keys for SmartLabel v3.0 HF1, WinAC/RTX 2005 SP3
07/11/2007 Add and change some Tags keys for WinCC v6.2 and PCS7 v7.0
GMT+8, 2025-4-22 17:10
