51单片机RS485通信与Modbus协议
eng 发表于 2021-7-6 16:26:01 | 显示全部楼层 |阅读模式
  1. #include <reg52.h>
  2. struct sTime {  //日期时间结构体定义
  3.     unsigned int  year;
  4.     unsigned char mon;
  5.     unsigned char day;
  6.     unsigned char hour;
  7.     unsigned char min;
  8.     unsigned char sec;
  9.     unsigned char week;
  10. };
  11. bit flag200ms = 1;  //200ms定时标志
  12. bit reqRefresh = 0;  //时间刷新请求
  13. struct sTime bufTime;  //日期时间缓冲区
  14. unsigned char T0RH = 0;  //T0重载值的高字节
  15. unsigned char T0RL = 0;  //T0重载值的低字节
  16. void ConfigTimer0(unsigned int ms);
  17. void RefreshTimeShow();
  18. extern void InitDS1302();
  19. extern void GetRealTime(struct sTime *time);
  20. extern void SetRealTime(struct sTime *time);
  21. extern void UartDriver();
  22. extern void ConfigUART(unsigned int baud);
  23. extern void UartRxMonitor(unsigned char ms);
  24. extern void UartWrite(unsigned char *buf, unsigned char len);
  25. extern unsigned int GetCRC16(unsigned char *ptr,  unsigned char len);
  26. extern void InitLcd1602();
  27. extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
  28. void main()
  29. {
  30.     unsigned char psec=0xAA;  //秒备份,初值AA确保首次读取时间后会刷新显示
  31.     EA = 1;            //开总中断
  32.     ConfigTimer0(1);   //配置T0定时1ms
  33.     ConfigUART(9600);  //配置波特率为9600
  34.     InitDS1302();      //初始化实时时钟
  35.     InitLcd1602();     //初始化液晶
  36.     //初始化屏幕上固定不变的内容
  37.     LcdShowStr(3, 0, "20  -  -  ");
  38.     LcdShowStr(4, 1, "  :  :  ");
  39.     while (1)
  40.     {
  41.         UartDriver();  //调用串口驱动
  42.         if (flag200ms)
  43.         {
  44.             flag200ms = 0;
  45.             GetRealTime(&bufTime);    //获取当前时间
  46.             if (reqRefresh || (psec!=bufTime.sec))
  47.             {   //检测到时间刷新请求或时间有变化时刷新显示
  48.                 RefreshTimeShow();
  49.                 psec = bufTime.sec;   //用当前值更新上次秒数
  50.             }
  51.         }
  52.     }
  53. }
  54. /* 将一个BCD码字节显示到屏幕上,(x,y)-屏幕起始坐标,bcd-待显示BCD码 */
  55. void ShowBcdByte(unsigned char x, unsigned char y, unsigned char bcd)
  56. {
  57.     unsigned char str[4];
  58.     str[0] = (bcd >> 4) + '0';
  59.     str[1] = (bcd&0x0F) + '0';
  60.     str[2] = '\0';
  61.     LcdShowStr(x, y, str);
  62. }
  63. /* 刷新日期时间的显示 */
  64. void RefreshTimeShow()
  65. {
  66.     ShowBcdByte(5,  0, bufTime.year);
  67.     ShowBcdByte(8,  0, bufTime.mon);
  68.     ShowBcdByte(11, 0, bufTime.day);
  69.     ShowBcdByte(4,  1, bufTime.hour);
  70.     ShowBcdByte(7,  1, bufTime.min);
  71.     ShowBcdByte(10, 1, bufTime.sec);
  72. }
  73. /* 串口动作函数,根据接收到的命令帧执行响应的动作
  74.    buf-接收到的命令帧指针,len-命令帧长度 */
  75. void UartAction(unsigned char *buf, unsigned char len)
  76. {
  77.     unsigned int  crc;
  78.     unsigned char crch, crcl;
  79.     if (buf[0] != 0x01) //本例中的本机地址设定为0x01,
  80.     {                   //如数据帧中的地址字节与本机地址不符,
  81.         return;         //则直接退出,即丢弃本帧数据不做任何处理
  82.     }
  83.     //地址相符时,再对本帧数据进行校验
  84.     crc = GetCRC16(buf, len-2);  //计算CRC校验值
  85.     crch = crc >> 8;
  86.     crcl = crc & 0xFF;
  87.     if ((buf[len-2]!=crch) || (buf[len-1]!=crcl))
  88.     {
  89.         return;   //如CRC校验不符时直接退出
  90.     }
  91.     //地址和校验字均相符后,解析功能码,执行相关操作
  92.     switch (buf[1])
  93.     {
  94.         case 0x06:  //写入单个寄存器
  95.             if ((buf[2]==0x00) && (buf[3]<=0x06)) //地址0x0000~0x0006分别对应
  96.             {                                     // “年/月/日/时/分/秒/星期”
  97.                 GetRealTime(&bufTime);  //获取当前时间
  98.                 switch (buf[3])  //由寄存器地址决定要修改的时间位
  99.                 {
  100.                     case 0: bufTime.year = 0x2000 + buf[5]; break;
  101.                     case 1: bufTime.mon  = buf[5]; break;
  102.                     case 2: bufTime.day  = buf[5]; break;
  103.                     case 3: bufTime.hour = buf[5]; break;
  104.                     case 4: bufTime.min  = buf[5]; break;
  105.                     case 5: bufTime.sec  = buf[5]; break;
  106.                     case 6: bufTime.week = buf[5]; break;
  107.                     default: break;
  108.                 }
  109.                 SetRealTime(&bufTime);  //写入新修改后的时间
  110.                 reqRefresh = 1;  //设置显示刷新请求
  111.                 len -= 2;  //长度-2以重新计算CRC并返回原帧
  112.                 break;
  113.             }
  114.             else  //寄存器地址不被支持时,返回错误码
  115.             {
  116.                 buf[1] = 0x86;  //功能码最高位置1
  117.                 buf[2] = 0x02;  //设置异常码为02-无效地址
  118.                 len = 3;
  119.                 break;
  120.             }
  121.         default:  //其它不支持的功能码
  122.             buf[1] |= 0x80;  //功能码最高位置1
  123.             buf[2] = 0x01;   //设置异常码为01-无效功能
  124.             len = 3;
  125.             break;
  126.     }
  127.     crc = GetCRC16(buf, len); //计算返回帧的CRC校验值
  128.     buf[len++] = crc >> 8;    //CRC高字节
  129.     buf[len++] = crc & 0xFF;  //CRC低字节
  130.     UartWrite(buf, len);      //发送返回帧
  131. }
  132. /* 配置并启动T0,ms-T0定时时间 */
  133. void ConfigTimer0(unsigned int ms)
  134. {
  135.     unsigned long tmp;  //临时变量
  136.     tmp = 11059200 / 12;      //定时器计数频率
  137.     tmp = (tmp * ms) / 1000;  //计算所需的计数值
  138.     tmp = 65536 - tmp;        //计算定时器重载值
  139.     tmp = tmp + 33;           //补偿中断响应延时造成的误差
  140.     T0RH = (unsigned char)(tmp>>8);  //定时器重载值拆分为高低字节
  141.     T0RL = (unsigned char)tmp;
  142.     TMOD &= 0xF0;   //清零T0的控制位
  143.     TMOD |= 0x01;   //配置T0为模式1
  144.     TH0 = T0RH;     //加载T0重载值
  145.     TL0 = T0RL;
  146.     ET0 = 1;        //使能T0中断
  147.     TR0 = 1;        //启动T0
  148. }
  149. /* T0中断服务函数,执行按键扫描和200ms定时 */
  150. void InterruptTimer0() interrupt 1
  151. {
  152.     static unsigned char tmr200ms = 0;
  153.     TH0 = T0RH;  //重新加载重载值
  154.     TL0 = T0RL;
  155.     UartRxMonitor(1);  //串口接收监控
  156.     tmr200ms++;
  157.     if (tmr200ms >= 200)  //定时200ms
  158.     {
  159.         tmr200ms = 0;
  160.         flag200ms = 1;
  161.     }
  162. }
MAX485.pdf (438.77 KB)
Modbus通信协议.pdf (156.79 KB)
MODBUS协议中文版.pdf (1.11 MB)
Modbus注意要项.pdf (216.87 KB)
GMT+8, 2026-3-15 01:15
