LCD320240无控制器16Pin接口输出显示功能 51单片机源程序
eng 发表于 2021-6-11 16:04:29 | 显示全部楼层 |阅读模式
基于51单片机的320240无控制显示屏的显示功能源码
  1. #include <reg52.h>
  2. sbit lcd_CS=P2^2;
  3. sbit lcd_RD=P2^1;
  4. sbit lcd_WR=P2^0;
  5. sbit lcd_A0=P2^3;
  6. sbit lcd_RES=P2^4;
  7. #define lcd_CMD    P0
  8. #define lcd_DATA   P0
  9. extern unsigned char lcd_dataread(void);
  10. extern unsigned char lcd_cmdread(void);
  11. extern void lcd_cmdwrite(char);
  12. extern void lcd_datawrite(char);
  13. extern void lcd_cursorxy(char,char);
  14. extern void delay1ms(unsigned int);
  15. extern void lcd_nop(unsigned char);
  16. extern void lcd_chkbusy(void);
  17. extern void lcd_showbig(unsigned char *text,unsigned int);
  18. extern void lcd_clear(void);
  19. extern void lcd_initial(void);
  20. extern void lcd_graphic_7(void);
  21. extern void lcd_graphic_8(void);
  22. extern void lcd_graphic_9(void);
  23. extern void lcd_text_1(void);
  24. unsigned char code PIC1[];
  25. unsigned int i,temp;
  26.
  27. void delay1ms(unsigned int count)
  28. {
  29.     int i,j;
  30.     for(i=0;i<=count;i++)
  31.       for(j=0;j<=583;j++);
  32. }
  33.
  34. void lcd_initial(void)
  35. {
  36. lcd_RES=0;
  37. delay1ms(10);
  38. lcd_RES=1;
  39. delay1ms(10);
  40. lcd_cmdwrite(0x40);
  41. lcd_datawrite(0x30);
  42. lcd_datawrite(0x87);
  43. lcd_datawrite(0x07);
  44. lcd_datawrite(0x27);
  45. lcd_datawrite(0x2b);
  46. lcd_datawrite(0xef);
  47. lcd_datawrite(0x28);
  48. lcd_datawrite(0x00);
  49. lcd_cmdwrite(0x44);
  50. lcd_datawrite(0x00);
  51. lcd_datawrite(0x00);
  52. lcd_datawrite(0xf0);
  53. lcd_datawrite(0x80);
  54. lcd_datawrite(0x25);
  55. lcd_datawrite(0xf0);
  56. lcd_datawrite(0x00);
  57. lcd_datawrite(0x3a);
  58. lcd_cmdwrite(0x58);
  59. lcd_datawrite(0x54);
  60. lcd_cmdwrite(0x5b);
  61. lcd_datawrite(0x00);
  62. lcd_cmdwrite(0x5c);
  63. lcd_datawrite(0x00);
  64. lcd_datawrite(0x78);
  65. lcd_cmdwrite(0x5d);
  66. lcd_datawrite(0x07);
  67. lcd_datawrite(0x07);
  68. lcd_cmdwrite(0x4c);
  69. lcd_cmdwrite(0x59);
  70. }
  71.
  72. void lcd_cmdwrite(unsigned char cmdx)
  73. {
  74.     lcd_CMD = cmdx;
  75.     lcd_A0 = 1;
  76.     lcd_CS = 0;
  77.                 lcd_RD=1;
  78.     lcd_WR = 0;
  79.     lcd_WR = 1;
  80.     lcd_CS = 1;
  81. }
  82.
  83. void lcd_datawrite(unsigned char datax)
  84. {
  85.    lcd_chkbusy();
  86.     lcd_A0 = 0;
  87.     lcd_DATA = datax;
  88.           lcd_RD=1;
  89.     lcd_CS = 0;
  90.     lcd_WR = 0;
  91.     lcd_WR = 1;
  92.     lcd_CS = 1;
  93.     lcd_A0 = 1;
  94. }
  95.
  96. unsigned char lcd_cmdread(void)
  97. {
  98.     unsigned char address_cmd;
  99.     lcd_DATA=0xff;
  100.
  101.     lcd_A0 = 0;
  102.     lcd_CS = 0;
  103.     lcd_RD = 0;
  104.     address_cmd = lcd_DATA;
  105.     lcd_RD = 1;
  106.     lcd_CS = 1;
  107.     lcd_A0 = 0;
  108.   return(address_cmd);
  109. }
  110.
  111.
  112. void lcd_cursorxy(unsigned char x,unsigned char y)
  113. {
  114.     lcd_cmdwrite(0x46);
  115.     lcd_datawrite(x);
  116.     lcd_datawrite(y);
  117. }
  118.
  119. void lcd_chkbusy(void)
  120. {
  121.      unsigned char busy;
  122.
  123. do
  124. {
  125.     busy =(lcd_cmdread() & 0x40);
  126.
  127. }while(busy);
  128.
  129. }
  130.
  131. void lcd_showbig(unsigned char *text,unsigned int x)
  132. {
  133.     while(*text != '\0')
  134.     {
  135.         lcd_datawrite(*text);
  136.         ++text;
  137.
  138.         delay1ms(x);
  139.     }
  140. }
  141.
  142. void lcd_clear(void)
  143. {
  144.     unsigned int i;
  145.     lcd_cursorxy(0x00,0x00);
  146.     lcd_cmdwrite(0x42);
  147.      for(i=0;i<0x7fff;i++)
  148.        lcd_datawrite(0x00);
  149. }
  150.
  151.
  152. void main(void)
  153. {
  154.    lcd_clear();
  155.    lcd_initial();
  156.
  157. temp =0;
  158.     while(1)
  159.     {
  160.         switch(temp)
  161.         {
  162.             case 0:
  163.                     lcd_graphic_8();
  164.                     delay1ms(1000);
  165.                     lcd_clear();
  166.                  break;
  167.
  168.             case 1:
  169.                     lcd_graphic_9();
  170.                     delay1ms(1000);
  171.                     lcd_clear();
  172.                  break;
  173.
  174.             case 7:
  175.                     lcd_graphic_7();
  176.                     delay1ms(500);
  177.                     lcd_clear();
  178.                  break;
  179.
  180.
  181.
  182.             case 8:
  183.                     lcd_text_1();
  184.                     delay1ms(2000);
  185.                     lcd_clear();
  186.                  break;
  187.
  188.         }
  189.         temp++;
  190.
  191.     }
  192.
  193. }
  194. void lcd_graphic_7(void)
  195. {
  196. lcd_cursorxy(0x80,0x25);
  197.     lcd_cmdwrite(0x42);
  198.     for(i=0;i<9600;i++)
  199.        if (((i/80)%2)==0)
  200.            lcd_datawrite(0xff);
  201.        else
  202.            lcd_datawrite(0x00);
  203.     delay1ms(1500);
  204.    lcd_cursorxy(0x80,0x25);
  205.    lcd_cmdwrite(0x42);
  206.     for(i=0;i<9600;i++)
  207.        if (((i/80)%2)==0)
  208.            lcd_datawrite(0x00);
  209.        else
  210.            lcd_datawrite(0xff);
  211.
  212. }
  213.
  214. void lcd_graphic_8(void)
  215. {
  216.       lcd_cursorxy(0x80,0x25);
  217.    lcd_cmdwrite(0x42);
  218.     for(i=0;i<9600;i++)
  219.      lcd_datawrite(PIC[i]);
  220. }
  221. void lcd_graphic_9(void)
  222. {
  223.       lcd_cursorxy(0x80,0x25);
  224.    lcd_cmdwrite(0x42);
  225.     for(i=0;i<9600;i++)
  226.      lcd_datawrite(PIC1[i]);
  227. }
  228. void lcd_text_1(void)
  229. {
  230.      lcd_cursorxy(0x00,0x00);
  231.     lcd_cmdwrite(0x42);       //MWRITE
  232.     lcd_showbig(
  233.         "!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!"
  234.         "AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA"
  235.         "@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@"
  236.         "BBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBBB"
  237.         "########################################"
  238.         "CCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCCC"
  239.         "$$$$$$$$$$"
  240.         "DDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDDD"
  241.         "%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%"
  242.         "EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE"
  243.         "^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^"
  244.     "FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF"
  245.         "&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&&"
  246.         "GGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGGG"
  247.         "****************************************"
  248.         "HHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH"
  249.         "(((((((((((((((((((((((((((((((((((((((("
  250.     "IIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIIII"
  251.         "))))))))))))))))))))))))))))))))))))))))"
  252.         "JJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJJ"
  253.         "----------------------------------------"
  254.         "KKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKKK"
  255.         "========================================"
  256.     "LLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLLL"
  257.         "[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[[["
  258.         "MMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMM"
  259.         "]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]]"
  260.         "NNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNNN"
  261.         "{{{{{{{{{{{{{{{{{{{{{{{{{{{{{{{{{{{{{{{{"
  262.         "OOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOOO"
  263.         "}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}}"
  264.         "PPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP"
  265.         "////////////////////////////////////////"
  266.         "RRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRRR"
  267.         "????????????????????????????????????????"
  268.         "SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS"
  269.         "////////////////////////////////////////"
  270.         "TTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTTT"
  271.         "~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~"
  272.         "QQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQQ",0);
  273.     for(i=0;i<96;i++)
  274.     lcd_datawrite(0x21+i);
  275. delay1ms(1000);
  276.
  277. }
  278. unsigned char code PIC1[]={
  279.         //横向取模
  280. /*--  调入了一幅图像:F:\tupian\320240 演示程序.bmp  --*/
  281. /*--  宽度x高度=320x240  --*/
  282. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  283. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  284. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  285. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  286. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  287. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  288. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  289. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  290. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  291. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  292. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  293. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  294. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  295. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  296. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  297. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  298. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  299. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  300. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  301. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  302. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  303. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  304. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  305. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  306. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  307. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  308. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  309. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  310. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  311. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  312. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  313. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  314. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  315. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  316. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  317. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  318. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  319. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,
  320. 0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  321. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  322. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0x00,
  323. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  324. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xF0,
  325. 0x00,0x00,0x70,0x18,0x01,0x80,0x07,0xE0,0x00,0x00,0x7F,0xFF,0xF0,0x00,0x00,0x00,
  326. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  327. 0xE0,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xF0,0x00,0x00,0x70,0x18,0x01,0x80,0x07,0xE0,
  328. 0x00,0x00,0x7F,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  329. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xF0,
  330. 0x1F,0xFF,0xF8,0x78,0x01,0xF0,0x01,0xE0,0xE0,0x00,0x7F,0xFF,0xF0,0x00,0x00,0x00,
  331. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  332. 0xE0,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xF0,0x1F,0xFF,0xF8,0x78,0x01,0xF0,0x01,0xE0,
  333. 0xE0,0x00,0x7F,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  334. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0xE0,0xF0,0x00,0xE0,
  335. 0x1F,0xFF,0xF8,0xF8,0x00,0xF7,0xFF,0xFF,0xF0,0x00,0x70,0x01,0xE0,0x00,0x00,0x00,
  336. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  337. 0xE0,0x00,0x00,0x00,0xE1,0xFF,0xF0,0xE0,0x01,0x87,0x00,0xF0,0x00,0x77,0xFF,0xFF,
  338. 0xF0,0x00,0x70,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  339. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0xE1,0xFF,0xF0,0xE0,
  340. 0x01,0x87,0x00,0xF0,0x00,0x77,0xFF,0xFF,0xF0,0x00,0x70,0x01,0xE0,0x00,0x00,0x00,
  341. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  342. 0xE0,0x00,0x00,0x00,0xE1,0xFF,0xF0,0xE0,0x01,0x87,0x01,0xE0,0x00,0x77,0x1E,0xF8,
  343. 0x00,0x00,0x7F,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  344. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0xE1,0xFF,0xF0,0xE0,
  345. 0x01,0x87,0x01,0xE0,0x00,0x77,0x1E,0xF8,0x00,0x00,0x7F,0xFF,0xE0,0x00,0x00,0x00,
  346. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  347. 0xE0,0x00,0x00,0x00,0xE7,0xF1,0xE0,0xE0,0x01,0x87,0x07,0x80,0x00,0x0F,0x7E,0xF8,
  348. 0x00,0x00,0x7F,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  349. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0xE7,0xF1,0xE0,0xE0,
  350. 0x01,0x87,0x07,0x80,0x00,0x0F,0x7E,0xF8,0x00,0x00,0x7F,0xFF,0xE0,0x00,0x7F,0x00,
  351. 0x07,0xF8,0x00,0x1F,0xC0,0x00,0x00,0x00,0xFF,0x00,0x00,0x1E,0x00,0x1F,0xC0,0x07,
  352. 0xE0,0x00,0x00,0x00,0xE7,0x77,0xE0,0xE0,0x01,0x87,0x0F,0x00,0x0E,0x0E,0x78,0xE1,
  353. 0x80,0x00,0x70,0x01,0xE0,0x01,0xFF,0xC0,0x1F,0xFE,0x00,0x7F,0xF0,0x00,0x00,0x03,
  354. 0xFF,0xC0,0x00,0x3E,0x00,0x7F,0xF0,0x07,0xE0,0x00,0x00,0x00,0xE7,0x77,0xE0,0xE0,
  355. 0x01,0x87,0x0F,0x00,0x0E,0x0E,0x78,0xE1,0x80,0x00,0x70,0x01,0xE0,0x03,0xFF,0xE0,
  356. 0x3F,0xFF,0x00,0xFF,0xF8,0x00,0x00,0x07,0xFF,0xE0,0x00,0x7E,0x00,0xFF,0xF8,0x07,
  357. 0xE0,0x00,0x00,0x00,0xEF,0x7F,0x80,0xE0,0x01,0x87,0x7E,0x1E,0x0F,0x8E,0x79,0xFF,
  358. 0xE0,0x00,0x7F,0xFF,0xE0,0x07,0xFF,0xE0,0x7F,0xFF,0x80,0xFF,0xF8,0x00,0x00,0x0F,
  359. 0xFF,0xF0,0x00,0x7E,0x00,0xFF,0xF8,0x07,0xE0,0x00,0x00,0x00,0xEF,0x7F,0x80,0xE0,
  360. 0x01,0x87,0x7E,0x1E,0x0F,0x8E,0x79,0xFF,0xE0,0x00,0x7F,0xFF,0xE0,0x07,0xC3,0xF0,
  361. 0x7E,0x1F,0x81,0xF8,0xFC,0x00,0x00,0x0F,0xC3,0xF0,0x00,0xFE,0x01,0xF8,0xFC,0x07,
  362. 0xE0,0x00,0x00,0x00,0xEE,0x1F,0x00,0xE0,0x01,0x87,0x78,0x7E,0x07,0xFE,0xF1,0xFF,
  363. 0xE0,0x00,0x7F,0xFF,0xE0,0x0F,0x81,0xF0,0xF8,0x07,0xC1,0xF0,0x7C,0x00,0x00,0x1F,
  364. 0x00,0xF8,0x01,0xFE,0x01,0xF0,0x7C,0x07,0xE0,0x00,0x00,0x00,0xEE,0x1F,0x00,0xE0,
  365. 0x01,0x87,0x78,0x7E,0x07,0xFE,0xF1,0xFF,0xE0,0x00,0x7F,0xFF,0xE0,0x0F,0x00,0xF0,
  366. 0xF0,0x03,0xC1,0xE0,0x3C,0x00,0x00,0x1E,0x00,0x78,0x01,0xFE,0x01,0xE0,0x3C,0x07,
  367. 0xE0,0x00,0x00,0x00,0xE0,0x7F,0x00,0xE0,0x7F,0xFF,0xF8,0x7E,0x01,0xF8,0xF1,0x81,
  368. 0x80,0x00,0x70,0x01,0x80,0x0F,0x00,0xF0,0xF0,0x03,0xC3,0xE0,0x3E,0x7C,0x03,0xDE,
  369. 0x00,0x78,0x03,0xFE,0x03,0xE0,0x3E,0x07,0xE0,0x00,0x00,0x00,0xE0,0x7F,0x00,0xE0,
  370. 0x7F,0xFF,0xF8,0x7E,0x01,0xF8,0xF1,0x81,0x80,0x00,0x70,0x01,0x80,0x00,0x01,0xF0,
  371. 0x00,0x03,0xC3,0xC0,0x1E,0x7C,0x07,0xC0,0x00,0x78,0x07,0xFE,0x03,0xC0,0x1E,0x07,
  372. 0xE0,0x00,0x00,0x00,0xE0,0xFF,0xE0,0xE0,0x7F,0xFF,0xE0,0xF8,0x01,0xF9,0xF7,0xF7,
  373. 0x80,0x18,0x0E,0x00,0x0E,0x00,0x03,0xE0,0x00,0x03,0xC3,0xC0,0x1E,0x3E,0x0F,0x80,
  374. 0x00,0x78,0x07,0xDE,0x03,0xC0,0x1E,0x07,0xE0,0x00,0x00,0x00,0xE7,0xF1,0xFF,0xE0,
  375. 0x01,0x87,0x01,0xE0,0x00,0x1F,0xE7,0xFF,0x80,0x1F,0xFF,0x1F,0xFF,0x00,0x3F,0xE0,
  376. 0x00,0x07,0xC3,0xC0,0x1E,0x1F,0x0F,0x80,0x00,0xF8,0x0F,0x9E,0x03,0xC0,0x1E,0x07,
  377. 0xE0,0x00,0x00,0x00,0xE7,0xF1,0xFF,0xE0,0x01,0x87,0x01,0xE0,0x00,0x1F,0xE7,0xFF,
  378. 0x80,0x1F,0xFF,0x1F,0xFF,0x00,0x3F,0xC0,0x00,0x0F,0x83,0xC0,0x1E,0x1F,0x1F,0x00,
  379. 0x01,0xF0,0x0F,0x9E,0x03,0xC0,0x1E,0x07,0xE0,0x00,0x00,0x00,0xFF,0x9E,0xFF,0xE0,
  380. 0x01,0x87,0x07,0x80,0x00,0x7F,0xEF,0x9F,0x00,0x1F,0xFF,0x1F,0xFF,0x00,0x3F,0xE0,
  381. 0x00,0x0F,0x83,0xC0,0x1E,0x0F,0xBE,0x00,0x01,0xF0,0x1F,0x1E,0x03,0xC0,0x1E,0x07,
  382. 0xE0,0x00,0x00,0x00,0xFF,0x9E,0xFF,0xE0,0x01,0x87,0x07,0x80,0x00,0x7F,0xEF,0x9F,
  383. 0x00,0x1F,0xFF,0x1F,0xFF,0x00,0x3F,0xF0,0x00,0x1F,0x03,0xC0,0x1E,0x07,0xFE,0x00,
  384. 0x03,0xE0,0x3E,0x1E,0x03,0xC0,0x1E,0x07,0xE0,0x00,0x00,0x00,0xFE,0x1F,0x1E,0xE0,
  385. 0x07,0x87,0x1F,0x00,0x00,0x7F,0xFF,0xFF,0x00,0x1E,0x0E,0x18,0x0E,0x00,0x01,0xF0,
  386. 0x00,0x3E,0x03,0xC0,0x1E,0x07,0xFC,0x00,0x07,0xC0,0x3E,0x1E,0x03,0xC0,0x1E,0x07,
  387. 0xE0,0x00,0x00,0x00,0xFE,0x1F,0x1E,0xE0,0x07,0x87,0x1F,0x00,0x00,0x7F,0xFF,0xFF,
  388. 0x00,0x1E,0x0E,0x18,0x0E,0x00,0x00,0xF8,0x00,0x7C,0x03,0xC0,0x1E,0x03,0xF8,0x00,
  389. 0x0F,0x80,0x7C,0x1E,0x03,0xC0,0x1E,0x07,0xE0,0x00,0x00,0x00,0xF0,0x0F,0x00,0xE0,
  390. 0x07,0x87,0x1E,0x0F,0x00,0x7E,0xF8,0xEF,0x00,0x1E,0x0E,0x18,0x0E,0x00,0x00,0x78,
  391. 0x01,0xF8,0x03,0xC0,0x1E,0x01,0xF8,0x00,0x3F,0x00,0xF8,0x1E,0x03,0xC0,0x1E,0x07,
  392. 0xE0,0x00,0x00,0x00,0xF0,0x0F,0x00,0xE0,0x07,0x87,0x1E,0x0F,0x00,0x7E,0xF8,0xEF,
  393. 0x00,0x1E,0x0E,0x18,0x0E,0x00,0x00,0x78,0x03,0xF0,0x03,0xC0,0x1E,0x01,0xF0,0x00,
  394. 0x7E,0x00,0xFF,0xFF,0xC3,0xC0,0x1E,0x07,0xE0,0x00,0x00,0x00,0xE1,0xE7,0x00,0xE0,
  395. 0x07,0x87,0x00,0x1F,0x0F,0xF0,0xE0,0xFE,0x00,0x1F,0xFE,0x1F,0xFE,0x00,0x00,0x78,
  396. 0x07,0xE0,0x03,0xC0,0x1E,0x03,0xF8,0x00,0xFC,0x00,0xFF,0xFF,0xC3,0xC0,0x1E,0x07,
  397. 0xE0,0x00,0x00,0x00,0xE1,0xE7,0x00,0xE0,0x07,0x87,0x00,0x1F,0x0F,0xF0,0xE0,0xFE,
  398. 0x00,0x1F,0xFE,0x1F,0xFE,0x0F,0x00,0x78,0x0F,0xC0,0x03,0xE0,0x3E,0x07,0xFC,0x01,
  399. 0xF8,0x00,0xFF,0xFF,0xC3,0xE0,0x3E,0x07,0xE0,0x00,0x00,0x00,0xE1,0xFF,0x80,0xE0,
  400. 0x07,0x07,0x00,0x7E,0x0F,0xF0,0xE0,0x7E,0x00,0x1F,0xFE,0x1F,0xFE,0x0F,0x00,0xF8,
  401. 0x1F,0x80,0x01,0xE0,0x3C,0x07,0xFC,0x03,0xF0,0x00,0xFF,0xFF,0xC1,0xE0,0x3C,0x07,
  402. 0xE0,0x00,0x00,0x00,0xE1,0xFF,0x80,0xE0,0x07,0x07,0x00,0x7E,0x0F,0xF0,0xE0,0x7E,
  403. 0x00,0x1F,0xFE,0x1F,0xFE,0x0F,0x80,0xF8,0x3F,0x00,0x01,0xF0,0x7C,0x0F,0xBE,0x07,
  404. 0xE0,0x00,0x00,0x1E,0x01,0xF0,0x7C,0x07,0xE0,0x00,0x00,0x00,0xE0,0x7F,0xE0,0xE0,
  405. 0x0F,0x07,0x00,0xF8,0x01,0xE0,0xE0,0x78,0x00,0x1E,0x0E,0x18,0x0E,0x07,0xC3,0xF0,
  406. 0x7C,0x00,0x01,0xF8,0xFC,0x1F,0x9F,0x0F,0x80,0x00,0x00,0x1E,0x01,0xF8,0xFC,0x07,
  407. 0xE0,0x00,0x00,0x00,0xE0,0x7F,0xE0,0xE0,0x0F,0x07,0x00,0xF8,0x01,0xE0,0xE0,0x78,
  408. 0x00,0x1E,0x0E,0x18,0x0E,0x07,0xFF,0xF0,0x7F,0xFF,0xC0,0xFF,0xF8,0x1F,0x1F,0x0F,
  409. 0xFF,0xF8,0x00,0x1E,0x00,0xFF,0xF8,0x07,0xE0,0x00,0x00,0x00,0xE0,0x07,0xE0,0xE0,
  410. 0x0E,0x07,0x01,0xF0,0x00,0xE0,0xE0,0xFF,0x00,0x1E,0x0E,0x18,0x0E,0x03,0xFF,0xE0,
  411. 0xFF,0xFF,0xC0,0xFF,0xF8,0x3E,0x0F,0x9F,0xFF,0xF8,0x00,0x1E,0x00,0xFF,0xF8,0x07,
  412. 0xE0,0x00,0x00,0x00,0xE0,0x00,0xE0,0xE0,0x1E,0x07,0x07,0xE0,0x01,0xE0,0xE1,0xFF,
  413. 0x80,0x1E,0x0E,0x18,0x0E,0x01,0xFF,0xC0,0xFF,0xFF,0xC0,0x7F,0xF0,0x7C,0x07,0xDF,
  414. 0xFF,0xF8,0x00,0x1E,0x00,0x7F,0xF0,0x07,0xE0,0x00,0x00,0x00,0xE0,0x00,0xE0,0xE0,
  415. 0x1E,0x07,0x07,0xE0,0x01,0xE0,0xE1,0xFF,0x80,0x1E,0x0E,0x18,0x0E,0x00,0x7F,0x00,
  416. 0xFF,0xFF,0xC0,0x1F,0xC0,0x7C,0x07,0xDF,0xFF,0xF8,0x00,0x1E,0x00,0x1F,0xC0,0x07,
  417. 0xE0,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xE0,0x78,0x07,0x1F,0x00,0x01,0xE0,0xE7,0xEF,
  418. 0xF8,0x1F,0xFE,0x1F,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  419. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xE0,
  420. 0x78,0x07,0x1F,0x00,0x01,0xE0,0xE7,0xEF,0xF8,0x1F,0xFE,0x1F,0xFE,0x00,0x00,0x00,
  421. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  422. 0xE0,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xE0,0xF0,0x07,0x7E,0x00,0x01,0xE0,0xEF,0x01,
  423. 0xF8,0x1F,0xFE,0x1F,0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  424. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xE0,
  425. 0xF0,0x07,0x7E,0x00,0x01,0xE0,0xEF,0x01,0xF8,0x1F,0xFE,0x1F,0xFE,0x00,0x00,0x00,
  426. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  427. 0xE0,0x00,0x00,0x00,0xE0,0x00,0x00,0xE0,0xE0,0x00,0x70,0x00,0x00,0xE0,0xFE,0x00,
  428. 0xE0,0x1E,0x0E,0x18,0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  429. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0xE0,0x00,0x00,0xE0,
  430. 0xE0,0x00,0x70,0x00,0x00,0xE0,0xFE,0x00,0xE0,0x1E,0x0E,0x18,0x0E,0x00,0x00,0x00,
  431. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  432. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,
  433. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  434. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  435. 0x00,0x00,0x00,0x00,0x00,0x00,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  436. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  437. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  438. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  439. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  440. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  441. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  442. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  443. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  444. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  445. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  446. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  447. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  448. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  449. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  450. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  451. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  452. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  453. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  454. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  455. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  456. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  457. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  458. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  459. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  460. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  461. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  462. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  463. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  464. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  465. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  466. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  467. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  468. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  469. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  470. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  471. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  472. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  473. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  474. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  475. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  476. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  477. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1C,0x00,0x38,0x00,0x00,0x00,
  478. 0x0E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  479. 0x00,0x00,0x03,0x80,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  480. 0x00,0x00,0x1E,0x00,0x3C,0x00,0x00,0x00,0x0F,0x80,0x00,0x70,0x00,0x00,0x00,0x00,
  481. 0x0E,0x00,0x00,0x38,0x03,0x81,0xC0,0x00,0x00,0xE0,0x03,0xC0,0x00,0x00,0x00,0x07,
  482. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x00,0x3E,0x00,0x00,0x00,
  483. 0x07,0xC0,0x00,0x78,0x00,0x03,0x83,0x9C,0x1F,0x00,0x00,0x3C,0x03,0xC1,0xE0,0x00,
  484. 0x00,0xF0,0x03,0xC0,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,
  485. 0x00,0x00,0x0F,0x00,0x1F,0x00,0x00,0x00,0xE7,0xC0,0x00,0x7C,0x00,0x03,0x87,0xDF,
  486. 0xFF,0x00,0x00,0x1F,0x01,0xE1,0xE0,0x00,0x00,0xF8,0x03,0xC0,0x00,0x00,0x00,0x07,
  487. 0xE0,0x00,0x00,0x00,0x00,0x00,0x1F,0xFE,0x00,0x00,0x0F,0x00,0x1F,0x00,0x00,0x00,
  488. 0xF7,0x80,0x00,0x7C,0x00,0x03,0xFF,0xDF,0xFF,0x00,0x00,0x1F,0x01,0xE1,0xE0,0x00,
  489. 0x00,0x78,0x03,0xC0,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFE,
  490. 0x00,0x00,0x0F,0x00,0x0F,0x80,0x00,0x00,0xF7,0x80,0x00,0x3C,0x00,0x03,0xFF,0xDF,
  491. 0xFE,0x00,0x00,0x1E,0x01,0xC1,0xE0,0x00,0x00,0x78,0x03,0xC0,0x00,0x00,0x00,0x07,
  492. 0xE0,0x00,0x00,0x00,0x03,0xFF,0xFF,0xC0,0x00,0x00,0x0E,0x00,0x0F,0x80,0x00,0x01,
  493. 0xF7,0x80,0x00,0x38,0x00,0x03,0xFF,0x9E,0x1E,0x00,0x00,0x1E,0x01,0xC1,0xC0,0x00,
  494. 0x00,0x70,0x03,0xC0,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x03,0xFF,0xE0,0x00,
  495. 0x00,0x00,0x0E,0x0E,0x07,0x01,0xC0,0x01,0xE7,0x80,0x00,0x38,0x00,0x03,0xC7,0x9E,
  496. 0x1E,0x00,0x00,0x1E,0x01,0xC3,0xDF,0xC0,0x00,0x70,0x03,0xC0,0x00,0x00,0x00,0x07,
  497. 0xE0,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x0E,0x0E,0x07,0x07,0xE0,0x01,
  498. 0xE7,0x87,0x3C,0x38,0x00,0x03,0xC7,0x9E,0x1E,0x00,0x00,0x1E,0x01,0xFF,0xFF,0xE0,
  499. 0x00,0x70,0x03,0xC0,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,
  500. 0x00,0x00,0x0E,0x0E,0x3F,0xFF,0xE0,0x03,0xC7,0xFF,0xBE,0x38,0x00,0x03,0xC7,0x9E,
  501. 0x1E,0x00,0x00,0x1E,0xFF,0xFF,0xFF,0xE0,0x00,0x70,0x03,0xC0,0x00,0x00,0x00,0x07,
  502. 0xE0,0x00,0x00,0x00,0x00,0x00,0xF0,0x00,0x00,0x00,0x0E,0x0F,0xFF,0xFF,0xE0,0x03,
  503. 0xFF,0xFF,0x9E,0x38,0x00,0x03,0xC7,0x9E,0x7E,0x00,0x00,0x1E,0xFF,0xFF,0xC0,0x00,
  504. 0x00,0x70,0x03,0xC0,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0xE0,0x00,
  505. 0x00,0x00,0x0E,0x0F,0xFF,0xF7,0xC0,0x07,0xFF,0xFC,0x1E,0x38,0x00,0x03,0xFF,0x9F,
  506. 0xFE,0x00,0x00,0x1E,0x7F,0xC3,0x80,0x00,0x00,0x70,0x03,0xC1,0xE0,0x00,0x00,0x07,
  507. 0xE0,0x00,0x00,0x00,0x00,0x01,0xE0,0x00,0x00,0x00,0x0F,0xFF,0x80,0x07,0x80,0x07,
  508. 0xFF,0x80,0x1E,0x38,0x00,0x03,0xFF,0xFF,0xFE,0x00,0x00,0x1E,0xE1,0xE7,0xB8,0x00,
  509. 0x00,0x70,0x03,0xFF,0xE0,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x01,0xE0,0x00,
  510. 0x00,0x00,0xFF,0xFE,0x00,0x0F,0x00,0x0F,0x07,0x80,0x1E,0x38,0x00,0x03,0xFF,0xFF,
  511. 0x80,0x00,0x00,0x3F,0xFD,0xE7,0xFC,0x00,0x00,0x70,0xFF,0xFF,0xE0,0x00,0x00,0x07,
  512. 0xE0,0x00,0x00,0x00,0x00,0x01,0xE0,0x01,0xE0,0x07,0xFF,0xFE,0x73,0xCF,0x00,0x0F,
  513. 0x07,0x81,0xDE,0x38,0x00,0x03,0xE0,0xFF,0xE0,0x00,0x0F,0xFF,0xFF,0xFF,0xFC,0x00,
  514. 0x00,0x70,0xFF,0xFF,0xC0,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x01,0xE7,0xFF,
  515. 0xF0,0x07,0xFE,0x3E,0x73,0xEE,0x00,0x1E,0x07,0xFF,0xFE,0x38,0x00,0x03,0xC1,0xFF,
  516. 0xF8,0x00,0x0F,0xFF,0x8F,0xFF,0xFC,0x00,0x00,0x7F,0xFF,0xC3,0xC0,0x00,0x00,0x07,
  517. 0xE0,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFF,0xF0,0x03,0x8E,0x3C,0xF9,0xF8,0x00,0x1C,
  518. 0x7F,0xFF,0xFE,0x38,0x00,0x01,0xC1,0xE0,0xF8,0x00,0x07,0xFE,0x0F,0xFF,0xF8,0x00,
  519. 0x0F,0xFF,0xC3,0xC3,0xC0,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,
  520. 0x80,0x00,0x0E,0x1C,0xF8,0x7C,0x00,0x7F,0xFF,0xFE,0x1E,0x38,0x00,0x00,0x03,0xE0,
  521. 0xFF,0xC0,0x00,0x3E,0x0F,0x80,0x78,0x00,0x1F,0xFF,0xC3,0xC3,0xC0,0x00,0x00,0x07,
  522. 0xE0,0x00,0x00,0x00,0x7F,0xFF,0xFC,0x00,0x00,0x00,0x0E,0x71,0xF0,0x3F,0x00,0x7F,
  523. 0xFF,0x80,0x1E,0x38,0x00,0x00,0x07,0xFF,0xFF,0xE0,0x00,0x7F,0x8F,0x1F,0xF8,0x00,
  524. 0x1F,0xF0,0x03,0x83,0xC0,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x3F,0x83,0xDE,0x00,
  525. 0x00,0x00,0x0F,0xF3,0xE0,0x1F,0x80,0x3F,0x07,0x80,0x1E,0x38,0x00,0x3F,0xFF,0xFF,
  526. 0xFF,0xE0,0x00,0x7F,0xCF,0xFF,0xF8,0x00,0x00,0x70,0x03,0x83,0xC0,0x00,0x00,0x07,
  527. 0xE0,0x00,0x00,0x00,0x00,0x03,0xDE,0x00,0x00,0x00,0x0F,0xE7,0xC0,0x0F,0x80,0x07,
  528. 0x07,0x87,0x1E,0x38,0x00,0x3F,0xFF,0xFF,0x00,0x00,0x00,0x7F,0xEF,0xFF,0xF8,0x00,
  529. 0x00,0x70,0x03,0x83,0x80,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x07,0x9E,0x00,
  530. 0x00,0x00,0x1F,0x8F,0x80,0x07,0x80,0x07,0x87,0x9F,0xDE,0x38,0x00,0x1F,0xFF,0x07,
  531. 0x80,0x00,0x00,0xFF,0xEF,0xC0,0x78,0x00,0x00,0x70,0x07,0x87,0x9E,0x00,0x00,0x07,
  532. 0xE0,0x00,0x00,0x00,0x00,0x07,0x9E,0x00,0x00,0x00,0x7F,0x1F,0x00,0x07,0x80,0x07,
  533. 0xBF,0xFF,0xDE,0x38,0x00,0x00,0x3E,0x03,0xC0,0x00,0x00,0xFE,0xEF,0x07,0xF8,0x00,
  534. 0x00,0x70,0x07,0xFF,0xFF,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x07,0x9E,0x00,
  535. 0x00,0x00,0xFE,0x3C,0x00,0x03,0x80,0x07,0xFF,0xFF,0x9E,0x38,0x00,0x00,0x7C,0x01,
  536. 0xF0,0x00,0x01,0xFE,0xEF,0xFF,0xFC,0x00,0x00,0x77,0xFF,0xFF,0xFF,0x00,0x00,0x07,
  537. 0xE0,0x00,0x00,0x00,0x00,0x0F,0x1E,0x00,0x00,0x03,0xFE,0x38,0x01,0xFC,0x00,0x03,
  538. 0xFF,0xC7,0x9E,0x38,0x00,0x00,0xF8,0x00,0xF8,0x00,0x01,0xFE,0x0F,0xFF,0xFC,0x00,
  539. 0x00,0xF7,0xFF,0xFF,0xF0,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x0F,0x1E,0x00,
  540. 0x00,0x0F,0xEE,0x01,0xFF,0xFE,0x00,0x03,0xC7,0x8F,0x3E,0x38,0x00,0x01,0xF0,0x00,
  541. 0x7C,0x00,0x03,0xDE,0x0F,0xFC,0x00,0x00,0x00,0xF3,0xFF,0xF0,0x00,0x00,0x00,0x07,
  542. 0xE0,0x00,0x00,0x00,0x00,0x1F,0x1E,0x00,0x00,0x0F,0xCE,0x1F,0xFF,0xFE,0x00,0x03,
  543. 0x87,0x8F,0x3E,0x38,0x00,0x03,0xE3,0x9C,0x3E,0x00,0x03,0xDE,0x07,0x3C,0x00,0x00,
  544. 0x00,0xF3,0xCF,0x70,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x1E,0x1E,0x00,
  545. 0x00,0x07,0x8E,0x1F,0xFE,0x00,0x00,0x03,0x87,0x8F,0x1E,0x38,0x00,0x0F,0xC7,0xDF,
  546. 0xFF,0x80,0x07,0x9E,0x00,0x3C,0x3F,0xC0,0x00,0xFF,0xCF,0x78,0x00,0x00,0x00,0x07,
  547. 0xE0,0x00,0x00,0x00,0x00,0x3E,0x1E,0x00,0x00,0x00,0x0E,0x07,0x1E,0x00,0x00,0x03,
  548. 0x87,0x8F,0x1E,0x38,0x00,0x1F,0xFF,0xDF,0xFF,0xF0,0x0F,0x9E,0x00,0x3F,0xFF,0xE0,
  549. 0x00,0xFF,0x0F,0x3C,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x3C,0x1C,0x00,
  550. 0x70,0x00,0x0E,0x00,0x1E,0x00,0x00,0x03,0x87,0x8F,0x00,0x38,0x00,0x3F,0xFF,0xDF,
  551. 0xFF,0xFE,0x0F,0x1F,0xFF,0xFF,0xFF,0xE0,0x01,0xFC,0x1E,0x3C,0x00,0x00,0x00,0x07,
  552. 0xE0,0x00,0x00,0x00,0x00,0x7C,0x1C,0x00,0x70,0x00,0x0E,0x00,0x1E,0x00,0x00,0x03,
  553. 0x87,0xFF,0x00,0x38,0x00,0xFF,0xFF,0x9E,0x1F,0xFE,0x1E,0x1F,0xFF,0xFF,0x00,0x00,
  554. 0x07,0xF0,0x1E,0x1E,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0xF8,0x1C,0x00,
  555. 0x70,0x00,0x0E,0x00,0x1E,0x00,0x00,0x07,0x87,0xFF,0x00,0x38,0x03,0xF3,0xC3,0x9E,
  556. 0x1E,0x00,0x1C,0x1E,0xFF,0xFF,0x00,0x00,0x3F,0xC0,0x3C,0x0F,0x00,0x00,0x00,0x07,
  557. 0xE0,0x00,0x00,0x00,0x00,0xF0,0x1C,0x00,0x70,0x00,0x0E,0x00,0x1E,0x00,0x00,0x07,
  558. 0x87,0xFE,0x00,0x38,0x03,0xC3,0xC3,0x9E,0x1C,0x00,0x00,0x1E,0x00,0xF7,0x80,0x00,
  559. 0x7F,0x00,0x7C,0x0F,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x01,0xE0,0x1C,0x00,
  560. 0x78,0x00,0x0E,0x00,0x1E,0x00,0x00,0x07,0x87,0xBE,0x00,0x38,0x00,0x03,0xC7,0x9E,
  561. 0x3C,0x00,0x00,0x1E,0x01,0xF3,0xC0,0x00,0x7E,0x00,0x78,0x07,0x80,0x00,0x00,0x07,
  562. 0xE0,0x00,0x00,0x00,0x03,0xE0,0x1C,0x00,0x78,0x03,0x8E,0x00,0x1E,0x00,0x00,0x03,
  563. 0x87,0x9E,0x00,0x38,0x00,0x03,0xC7,0x9E,0x3C,0x00,0x00,0x1E,0x03,0xE3,0xE0,0x00,
  564. 0x38,0x00,0xF0,0x07,0xC0,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x07,0xC0,0x1C,0x00,
  565. 0x78,0x03,0xCE,0x00,0x1E,0x01,0xC0,0x03,0x87,0x8E,0x0F,0x38,0x00,0x03,0xC7,0x9E,
  566. 0x3C,0x00,0x00,0x1E,0x07,0xC1,0xF0,0x00,0x00,0x01,0xF0,0x03,0xC0,0x00,0x00,0x07,
  567. 0xE0,0x00,0x00,0x00,0x0F,0x80,0x1E,0x00,0x78,0x01,0xFE,0x00,0x1F,0xFF,0xE0,0x00,
  568. 0x07,0x80,0x0F,0xB8,0x00,0x03,0xFF,0x9F,0xFE,0x00,0x00,0x1E,0x0F,0x80,0xF8,0x00,
  569. 0x00,0x03,0xE0,0x03,0xE0,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x1F,0x00,0x1E,0x00,
  570. 0x7C,0x00,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x07,0x80,0x07,0xF8,0x00,0x03,0xFF,0x9F,
  571. 0xFE,0x00,0x00,0x1E,0x1F,0x00,0x7C,0x00,0x00,0x07,0xC0,0x01,0xF0,0x00,0x00,0x07,
  572. 0xE0,0x00,0x00,0x00,0x3E,0x00,0x1F,0xFF,0xFC,0x00,0x7F,0xFF,0xFF,0xFC,0x00,0x00,
  573. 0x0F,0x80,0x03,0xF8,0x00,0x03,0xFF,0x9F,0xE0,0x00,0x00,0x1E,0x3E,0x00,0x3F,0x00,
  574. 0x00,0x0F,0x80,0x01,0xFF,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0xF8,0x00,0x0F,0xFF,
  575. 0xFC,0x00,0x7E,0x7F,0xC0,0x00,0x00,0x00,0x0F,0x80,0x01,0xF8,0x00,0x03,0xC0,0x1E,
  576. 0x00,0x00,0x00,0x1E,0xFC,0x00,0x3F,0xF0,0x00,0x1F,0x00,0x00,0xFF,0x00,0x00,0x07,
  577. 0xE0,0x00,0x00,0x01,0xF0,0x00,0x07,0xFF,0xE0,0x00,0x3E,0x00,0x00,0x00,0x00,0x00,
  578. 0x07,0x80,0x00,0xF8,0x00,0x01,0xC0,0x1E,0x00,0x00,0x00,0x1F,0xF0,0x00,0x1F,0xF0,
  579. 0x00,0x3E,0x00,0x00,0xF8,0x00,0x00,0x07,0xE0,0x00,0x00,0x01,0xC0,0x00,0x00,0x00,
  580. 0x00,0x00,0x1E,0x00,0x00,0x00,0x00,0x00,0x07,0x80,0x00,0x78,0x00,0x01,0xC0,0x00,
  581. 0x00,0x00,0x00,0x0F,0xE0,0x00,0x00,0x00,0x00,0x78,0x00,0x00,0x00,0x00,0x00,0x07,
  582. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  583. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0x80,0x00,0x00,0x00,
  584. 0x00,0x70,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  585. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  586. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  587. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  588. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  589. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  590. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  591. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  592. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  593. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  594. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  595. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  596. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  597. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  598. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  599. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  600. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  601. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  602. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  603. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  604. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  605. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  606. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  607. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  608. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  609. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  610. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  611. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  612. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  613. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  614. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  615. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  616. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  617. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  618. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  619. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  620. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  621. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  622. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  623. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  624. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  625. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  626. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  627. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  628. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  629. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  630. 0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0xFF,
  631. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  632. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  633. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,
  634. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  635. 0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF1,0xFF,
  636. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  637. 0xFF,0xFF,0xFF,0xFF,0xFF,0x8F,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  638. 0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0x00,0xF1,0xFF,0xFF,0xE7,0xFF,0xFF,0xFF,0xFF,0xF0,
  639. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x8F,0xFF,0xFF,
  640. 0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0x00,0xF1,
  641. 0xFF,0xFF,0xE7,0xFF,0xFF,0xFF,0xFF,0xF0,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  642. 0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  643. 0xFF,0xFE,0x0F,0xFF,0xFF,0xF0,0x00,0x70,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xF0,
  644. 0xFF,0xFF,0xEF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0xFF,
  645. 0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x0F,0xFF,0xFF,0xF0,0x00,0x70,
  646. 0x00,0x00,0x01,0xFF,0xFF,0xFF,0xFF,0xF0,0xFF,0xFF,0xEF,0xFF,0xFF,0xFF,0xFF,0xFF,
  647. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0xFF,0x9F,0xFF,0x1F,0xFF,0x7F,0xFF,0xE0,0x00,0x00,
  648. 0x00,0x00,0x07,0xFF,0xFE,0x00,0x7F,0xF8,0xFF,0xFF,0xE1,0xFF,0xFE,0xFF,0xFF,0xF8,
  649. 0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0xFF,0x9F,
  650. 0xFF,0x1F,0xFF,0x7F,0xFF,0xE0,0x00,0x00,0x00,0x00,0x07,0xFF,0xFE,0x00,0x7F,0xF8,
  651. 0xFF,0xFF,0xE1,0xFF,0xFE,0xFF,0xFF,0xF8,0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0xFF,0xFF,
  652. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0x9F,0xFF,0x7F,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,
  653. 0xFF,0xFF,0xFF,0xFF,0xE0,0xF8,0xFF,0xF8,0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,
  654. 0xFF,0xFF,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0x9F,
  655. 0xFF,0x7F,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0xF8,0xFF,0xF8,
  656. 0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0x01,0xFF,0xFF,0xFF,0xFF,0xFF,
  657. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0x80,0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,
  658. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xF8,0xFF,0xFF,0xE7,0xFF,0xFE,0x00,0x00,0x00,
  659. 0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0x80,
  660. 0x00,0x00,0x00,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xF8,
  661. 0xFF,0xFF,0xE7,0xFF,0xFE,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  662. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x7F,0x1F,0xFF,0xFF,0xF8,0x1F,0xFF,0xFF,0xFF,0xFF,
  663. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xF8,0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,
  664. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x7F,0x1F,
  665. 0xFF,0xFF,0xF8,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xF8,
  666. 0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  667. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x7F,0x1F,0xFF,0xFF,0xF9,0xFF,0xFF,0xFF,0xFF,0xFF,
  668. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xF8,0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,
  669. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x7F,0x1F,
  670. 0xFF,0xFF,0xF9,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xF8,
  671. 0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  672. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,
  673. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xF8,0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,
  674. 0xFF,0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,
  675. 0xFF,0xFF,0x97,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xF8,
  676. 0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,0xFF,0xF0,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
  677. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0xFF,0xFF,0x97,0xFF,0xFF,0xFF,0xFF,0xFF,
  678. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xF8,0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,
  679. 0xFF,0xF0,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE8,0x7F,
  680. 0xFF,0xFF,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xF8,
  681. 0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
  682. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE8,0x7F,0xFF,0xFF,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,
  683. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xF8,0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0x00,0x00,
  684. 0x00,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF7,0xFF,0xE0,0xFF,
  685. 0xFF,0xFE,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xF8,0xF8,
  686. 0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,0xFF,0xE0,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,
  687. 0xFF,0xFF,0xFF,0xFF,0xF7,0xFF,0xE0,0xFF,0xFF,0xFE,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,
  688. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xF8,0xF8,0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,
  689. 0xFF,0xE0,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0x9F,0xE0,
  690. 0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,0xF8,0xF0,0x78,
  691. 0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,0xFF,0x81,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  692. 0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0x9F,0xE0,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,
  693. 0xFF,0xFF,0xFE,0xFF,0xFF,0xF8,0xF0,0x78,0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0xFF,
  694. 0xFF,0x81,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0x9F,0xFF,
  695. 0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0x80,0x00,0x00,0x18,
  696. 0x00,0x00,0x07,0xFF,0xFE,0x1F,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  697. 0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0x9F,0xFF,0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  698. 0xFF,0xFF,0xF8,0x7F,0x80,0x00,0x00,0x18,0x00,0x00,0x07,0xFF,0xFE,0x1F,0xFF,0xFF,
  699. 0xFE,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x1F,0x9F,0xFF,
  700. 0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x1F,0xFF,0xF0,0xFF,0xF0,
  701. 0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0x07,0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  702. 0xFF,0xFF,0xFF,0xFF,0xFE,0x1F,0x9F,0xFF,0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  703. 0xFF,0xFF,0xF0,0x1F,0xFF,0xF0,0xFF,0xF0,0xFF,0xFF,0xE7,0xFF,0xFE,0x1F,0xFF,0x07,
  704. 0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0x9F,0xFF,
  705. 0xF8,0x7F,0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xF0,0xFF,0xF0,
  706. 0xFF,0xFF,0xEF,0xFF,0xFE,0x1F,0xFF,0xE0,0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  707. 0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0x9F,0xFF,0xF8,0x7F,0xFF,0xFF,0xF0,0x00,0x00,0x00,
  708. 0x00,0x00,0x00,0x0F,0xFF,0xF0,0xFF,0xF0,0xFF,0xFF,0xEF,0xFF,0xFE,0x1F,0xFF,0xE0,
  709. 0xF1,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0x7F,0x7F,
  710. 0xF8,0x7F,0xF1,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,0xF0,0xFF,0xF1,
  711. 0xFF,0xFF,0xFF,0xFF,0xFE,0x1F,0xFF,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  712. 0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0x7F,0x0F,0xF8,0x7F,0xE0,0xFF,0xFF,0xFF,0xFF,0xF8,
  713. 0x7F,0xFF,0xFF,0xFF,0xFF,0xE0,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x1F,0xFF,0xF8,
  714. 0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0x7F,0x0F,
  715. 0xF8,0x7F,0xE0,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,0xE0,0x7F,0xFF,
  716. 0xFF,0xFF,0xFF,0xFF,0xFE,0x1F,0xFF,0xF8,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  717. 0xFF,0xFF,0xFF,0xFF,0xFF,0x8F,0x7F,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xEF,0xF8,
  718. 0x7F,0xFF,0xFF,0xFF,0xFF,0xE0,0x8F,0xFF,0xFF,0xFF,0xF1,0xFF,0xFE,0x1F,0xFF,0xFE,
  719. 0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x8F,0x7F,0x00,
  720. 0x00,0x00,0x00,0xFF,0xFF,0xFF,0xEF,0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,0xE0,0x8F,0xFF,
  721. 0xFF,0xFF,0xF1,0xFF,0xFE,0x1F,0xFF,0xFE,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  722. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x7F,0x0F,0xF8,0x7F,0xE1,0xFF,0xFF,0xFF,0xE7,0xF8,
  723. 0x7F,0xFF,0xFF,0xFF,0xFF,0xE0,0xE7,0x80,0x00,0x00,0x00,0xFF,0xFE,0x1F,0xFF,0xFF,
  724. 0x0F,0xFF,0xE7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0x7F,0x0F,
  725. 0xF8,0x7F,0xE1,0xFF,0xFF,0xFF,0xE7,0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,0xE0,0xE7,0x80,
  726. 0x00,0x00,0x00,0xFF,0xFE,0x1F,0xFF,0xFF,0x0F,0xFF,0xE7,0xFF,0xFF,0xFF,0xFF,0xFF,
  727. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0x0F,0xF8,0x7F,0xE1,0xFF,0xFF,0xFF,0xE0,0xF8,
  728. 0x7F,0x7F,0xFF,0xFF,0xFF,0x80,0xE0,0xE7,0xFE,0x1F,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,
  729. 0x1F,0xFF,0x81,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0x0F,
  730. 0xF8,0x7F,0xE1,0xFF,0xFF,0xFF,0xE0,0xF8,0x7F,0x7F,0xFF,0xFF,0xFF,0x80,0xE0,0xE7,
  731. 0xFE,0x1F,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0x1F,0xFF,0x81,0xFF,0xFF,0xFF,0xFF,0xFF,
  732. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0x0F,0xF8,0x7F,0xE1,0xFF,0xFF,0xFF,0x81,0xF8,
  733. 0x7F,0x9F,0xFF,0xFF,0xFF,0x88,0xF0,0xFF,0xFE,0x1F,0xFF,0xFF,0xFE,0x18,0x00,0x00,
  734. 0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0x0F,
  735. 0xF8,0x7F,0xE1,0xFF,0xFF,0xFF,0x81,0xF8,0x7F,0x9F,0xFF,0xFF,0xFF,0x88,0xF0,0xFF,
  736. 0xFE,0x1F,0xFF,0xFF,0xFE,0x18,0x00,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,0xFF,0xFF,
  737. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0x0F,0xF8,0x7F,0xE1,0xFF,0xFF,0xFF,0x87,0xF8,
  738. 0x7F,0xEF,0xFF,0xFF,0xFF,0x88,0xF8,0x7F,0xFE,0x1F,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,
  739. 0x1F,0xFF,0x80,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0x0F,
  740. 0xF8,0x7F,0xE1,0xFF,0xFF,0xFF,0x87,0xF8,0x7F,0xEF,0xFF,0xFF,0xFF,0x88,0xF8,0x7F,
  741. 0xFE,0x1F,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0x1F,0xFF,0x80,0x7F,0xFF,0xFF,0xFF,0xFF,
  742. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0x0F,0xF8,0x7F,0xE1,0xFF,0xFF,0xFF,0x0F,0xF8,
  743. 0x7F,0xF1,0xFF,0xFF,0xFF,0x08,0xF8,0xFF,0xFE,0x1F,0xFF,0xFF,0xFE,0x7F,0xFF,0xFF,
  744. 0x1F,0xFF,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0x0F,
  745. 0xF8,0x7F,0xE1,0xFF,0xFF,0xFF,0x0F,0xF8,0x7F,0xF1,0xFF,0xFF,0xFF,0x08,0xF8,0xFF,
  746. 0xFE,0x1F,0xFF,0xFF,0xFE,0x7F,0xFF,0xFF,0x1F,0xFF,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,
  747. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF9,0xFF,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFE,0x0F,0xF8,
  748. 0x7F,0xF0,0xFF,0xFF,0xFF,0x18,0xFE,0xFF,0xFE,0x1F,0xFF,0xFF,0xFE,0x7F,0xFF,0xFF,
  749. 0x1F,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF1,0xFF,0x0F,
  750. 0xF8,0x7F,0xE1,0xFF,0xFF,0xFE,0x1F,0xF8,0x7F,0xF8,0x7F,0xFF,0xFF,0x18,0xFF,0xFF,
  751. 0xFE,0x1F,0xFF,0xFF,0xFE,0x7F,0xFF,0xFF,0x1F,0xFE,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
  752. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF1,0xFF,0x0F,0xF8,0x7F,0xE1,0xFF,0xFF,0xFE,0x1F,0xF8,
  753. 0x7F,0xF8,0x7F,0xFF,0xFF,0x18,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0xFE,0x7F,0xFF,0xFF,
  754. 0x1F,0xFE,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF1,0xFF,0x0F,
  755. 0xF8,0x7F,0xE1,0xFF,0xFF,0xF8,0x7F,0xF8,0x7F,0xFE,0x1F,0xFF,0xFE,0x78,0xFF,0xFF,
  756. 0xFE,0x1F,0xFF,0xFF,0xFE,0x7F,0xFF,0xFF,0x1F,0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  757. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF1,0xFF,0x0F,0xF8,0x7F,0xE1,0xFF,0xFF,0xF8,0x7F,0xF8,
  758. 0x7F,0xFE,0x1F,0xFF,0xFE,0x78,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0xFE,0x7F,0xFF,0xFF,
  759. 0x1F,0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0x0F,
  760. 0xF8,0x7F,0xE1,0xFF,0xFF,0xF8,0xFF,0xF8,0x7F,0xFF,0x0F,0xFF,0xFE,0xF8,0xFF,0xFF,
  761. 0xFE,0x1F,0xE7,0xFF,0xFE,0x7F,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  762. 0xFF,0xFF,0xFF,0xFF,0xFF,0xE1,0xFF,0x0F,0xF8,0x7F,0xE1,0xFF,0xFF,0xF8,0xFF,0xF8,
  763. 0x7F,0xFF,0x0F,0xFF,0xFE,0xF8,0xFF,0xFF,0xFE,0x1F,0xE7,0xFF,0xFE,0x7F,0xFF,0xFF,
  764. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x01,0xFF,0x0F,
  765. 0xF8,0x7F,0xE1,0xFF,0xFF,0xF0,0xFF,0xF8,0x7F,0xFF,0x87,0xFF,0xF8,0xF8,0xFF,0xE0,
  766. 0x00,0x00,0x01,0xFF,0xF8,0x7F,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  767. 0xFF,0xFF,0xFF,0xFF,0xF0,0x01,0xFF,0x0F,0xF8,0x7F,0xE1,0xFF,0xFF,0xF0,0xFF,0xF8,
  768. 0x7F,0xFF,0x87,0xFF,0xF8,0xF8,0xFF,0xE0,0x00,0x00,0x01,0xFF,0xF8,0x7F,0xFF,0xFF,
  769. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0xFF,0x0F,
  770. 0xF8,0x7F,0xE1,0xFF,0xFF,0xE1,0xFF,0xF8,0x7F,0xFF,0x81,0xFF,0xF9,0xF8,0xFF,0xF1,
  771. 0xFE,0x1F,0xFF,0xFF,0xF8,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  772. 0xFF,0xFF,0xFF,0xFF,0xFF,0x07,0xFF,0x0F,0xF8,0x7F,0xE1,0xFF,0xFF,0xE1,0xFF,0xF8,
  773. 0x7F,0xFF,0x81,0xFF,0xF9,0xF8,0xFF,0xF1,0xFE,0x1F,0xFF,0xFF,0xF8,0xFF,0xFF,0xFF,
  774. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0x00,
  775. 0x00,0x00,0x01,0xFF,0xFF,0x87,0xFF,0xF8,0x7F,0xFF,0xE0,0xFF,0xF1,0xF8,0xFF,0xFF,
  776. 0xFE,0x1F,0xFF,0xFF,0xF8,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  777. 0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0x00,0x00,0x00,0x01,0xFF,0xFF,0x87,0xFF,0xF8,
  778. 0x7F,0xFF,0xE0,0xFF,0xF1,0xF8,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0xF8,0xFF,0xFF,0xFF,
  779. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0x0F,
  780. 0xFF,0xFF,0xE1,0xFF,0xFF,0x8F,0xFF,0xF8,0x7F,0xFF,0xF0,0xFF,0xE7,0xF8,0xFF,0xFF,
  781. 0xFE,0x1F,0xFF,0xFF,0xF8,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  782. 0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0x0F,0xFF,0xFF,0xE1,0xFF,0xFF,0x8F,0xFF,0xF8,
  783. 0x7F,0xFF,0xF0,0xFF,0xE7,0xF8,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0xF8,0xFF,0xFF,0xFF,
  784. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0x1F,
  785. 0xFF,0xFF,0xEF,0xFF,0xFF,0x1F,0xFF,0xF8,0x7F,0xFF,0xF0,0xFF,0xEF,0xF8,0xFF,0xFF,
  786. 0xFE,0x1F,0xFF,0xFF,0xF1,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  787. 0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xFF,0x0F,0xE7,0xFF,0xFF,0xFE,0xFF,0xFF,0xF8,
  788. 0x7F,0xFF,0xF8,0xFF,0x9F,0xF8,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0xF1,0xFF,0xFF,0xFF,
  789. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xFF,
  790. 0x0F,0xE7,0xFF,0xFF,0xFE,0xFF,0xFF,0xF8,0x7F,0xFF,0xF8,0xFF,0x9F,0xF8,0xFF,0xFF,
  791. 0xFE,0x1F,0xFF,0xFF,0xF1,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  792. 0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xF8,0x07,0xF0,0x7F,0xFF,0xF9,0xFF,0xFF,0xF8,
  793. 0x7F,0xFF,0xF8,0xFF,0xFF,0xF8,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0xF7,0xFF,0xFF,0xFF,
  794. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xF8,
  795. 0x07,0xF0,0x7F,0xFF,0xF9,0xFF,0xFF,0xF8,0x7F,0xFF,0xF8,0xFF,0xFF,0xF8,0xFF,0xFF,
  796. 0xFE,0x1F,0xFF,0xFF,0xF7,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  797. 0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xF0,0x1F,0xFE,0x0F,0xFF,0xF7,0xFF,0xFF,0xF8,
  798. 0x7F,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,0xFE,0x1F,0xFF,0xFF,0xE7,0xFF,0xFF,0xFF,
  799. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xF0,
  800. 0x1F,0xFE,0x0F,0xFF,0xF7,0xFF,0xFF,0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,
  801. 0xFE,0x1F,0xFF,0xFF,0xE7,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  802. 0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xE0,0xFF,0xFF,0x01,0xFF,0xFF,0xFF,0xFF,0xF8,
  803. 0x7F,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,0xFE,0x1F,0xF8,0xFF,0xEF,0xFF,0xFF,0xFF,
  804. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xE0,
  805. 0xFF,0xFF,0x01,0xFF,0xFF,0xFF,0xFF,0xF8,0x7F,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,
  806. 0xFE,0x1F,0xF8,0xFF,0xEF,0xFF,0xFF,0xFF,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  807. 0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0x07,0xFF,0xFF,0xE0,0xFF,0xFF,0xFF,0xF0,0x00,
  808. 0x7F,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,0xFE,0x1F,0xF0,0x7F,0x9F,0xFF,0xFE,0x00,
  809. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0x07,
  810. 0xFF,0xFF,0xE0,0xFF,0xFF,0xFF,0xF0,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,
  811. 0xFE,0x1F,0xF0,0x7F,0x9F,0xFF,0xFE,0x00,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  812. 0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFE,0x1F,0xFF,0xFF,0xF0,0x7F,0xFF,0xFF,0xFF,0x00,
  813. 0x7F,0xFF,0xFF,0xFF,0xFF,0xF8,0xFE,0x00,0x00,0x00,0x00,0x1F,0x9F,0xFF,0xFF,0xE0,
  814. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFE,0x1F,
  815. 0xFF,0xFF,0xF0,0x7F,0xFF,0xFF,0xFF,0x00,0x7F,0xFF,0xFF,0xFF,0xFF,0xF8,0xFE,0x00,
  816. 0x00,0x00,0x00,0x1F,0x9F,0xFF,0xFF,0xE0,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  817. 0xFF,0xFF,0xFF,0xFF,0xFF,0xE7,0xF0,0xFF,0xFF,0xFF,0xF8,0x7F,0xFF,0xFF,0xFF,0x80,
  818. 0x7F,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xF0,
  819. 0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE7,0xF0,0xFF,
  820. 0xFF,0xFF,0xF8,0x7F,0xFF,0xFF,0xFF,0x80,0x7F,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,
  821. 0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xF0,0x1F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  822. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x87,0xFF,0xFF,0xFF,0xFE,0x7F,0xFF,0xFF,0xFF,0xE0,
  823. 0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,
  824. 0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  825. 0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xF7,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  826. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  827. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0xFF,0xFF,0xFF,0xF7,
  828. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,
  829. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  830. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  831. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  832. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  833. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  834. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  835. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  836. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  837. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  838. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  839. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  840. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  841. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  842. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  843. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  844. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  845. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  846. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  847. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  848. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  849. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  850. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  851. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  852. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  853. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  854. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  855. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  856. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  857. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  858. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  859. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  860. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  861. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  862. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  863. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  864. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  865. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  866. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  867. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  868. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  869. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  870. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  871. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,
  872. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  873. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  874. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  875. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  876. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  877. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  878. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  879. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  880. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  881. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  882. };//演示测试程序
GMT+8, 2026-9-22 22:59
