ITU-T G.984.4 ONU管理和控制接口规范(OMCI).pdf 英文版
Leonarad 发表于 2021-3-25 01:54:17 | 显示全部楼层 |阅读模式
Summary:Recommendation ITU-T G.984.4 provides the optical network termination (ONT) management and control interface (OMCI) specification for gigabit-capable passive optical network (G-PON) systems as defined in Recommendations ITU-T G.984.2 and G.984.3.
Firstly, it specifies the managed entities of a protocol-independent management information base (MIB) that models the exchange of information between the optical line termination (OLT) and the optical network termination (ONT). In addition, it covers the ONT management and control channel,
protocol and detailed messages. This revised version incorporates the material from Amendment 1 (2005), Amendment 2 (2006), and Amendment 3 (2006).
In addition to the purely editorial collection work, this revision endeavours to remove all references to the optional ATM transport capabilities of G-PON, since all modern systems do not support it.
T-REC-G.984.4-200802-I!!PDF-E.pdf (3.19 MB, 售价: 5 E币)
CONTENTS
Page
1 Scope ............................................................................................................................ 1
2 References..................................................................................................................... 1
3 Definitions .................................................................................................................... 4
4 Abbreviations and acronyms ........................................................................................ 4
5 Conventions .................................................................................................................. 9
6 Reference model and terms .......................................................................................... 10
6.1 OMCI in Recommendation ITU-T G.984.1................................................... 10
6.2 ONT functions................................................................................................ 10
6.3 Encapsulation in GEM frame ......................................................................... 11
6.4 Support of multicast connection..................................................................... 11
6.5 Voice over IP management ............................................................................ 11
7 Requirements of the management interface specification............................................ 12
7.1 Configuration management ............................................................................ 12
7.2 Fault management .......................................................................................... 13
7.3 Performance management .............................................................................. 13
7.4 Security management ..................................................................................... 13
8 Protocol-independent MIB for the OMCI .................................................................... 13
8.1 Managed entities............................................................................................. 14
8.2 Managed entity relation diagrams .................................................................. 21
9 MIB description............................................................................................................ 46
9.1 Equipment management ................................................................................. 49
9.2 ANI management............................................................................................ 75
9.3 Layer 2 data services ...................................................................................... 91
9.4 Layer 3 data services ...................................................................................... 146
9.5 Ethernet services............................................................................................. 163
9.6 802.11 services ............................................................................................... 171
9.7 xDSL services................................................................................................. 185
9.8 TDM services ................................................................................................. 243
9.9 Voice services................................................................................................. 264
9.10 MoCA............................................................................................................. 294
9.11 Traffic management........................................................................................ 300
9.12 General purpose MEs ..................................................................................... 303
9.13 Miscellaneous services ................................................................................... 314
10 ONT management and control channel (OMCC)......................................................... 329
11 ONT management and control protocol ....................................................................... 330
11.1 ONT management and control protocol packet format.................................. 330
11.2 Message flow control and error recovery....................................................... 340
11.3 OMCI handling within the ONT .................................................................... 342
Appendix I – OMCI common mechanisms and services......................................................... 344
I.1 Common mechanisms .................................................................................... 344
I.2 Common services ........................................................................................... 355
Appendix II – OMCI message set............................................................................................ 371
II.1 General remarks.............................................................................................. 371
II.2 Message layout ............................................................................................... 373
Appendix III – Traffic management options............................................................................ 408
III.1 Priority queue configuration........................................................................... 408
III.2 Explicit traffic scheduler configuration.......................................................... 408
III.3 Traffic descriptor configuration ..................................................................... 409
Appendix IV – Video return path ............................................................................................ 410
IV.1 Network overview .......................................................................................... 410
IV.2 Mode 1 STB-ONT interface........................................................................... 411
IV.3 Mode 1 ONT-network interface ..................................................................... 412
IV.4 Mode 2 STB-ONT interface........................................................................... 413
IV.5 Mode 2 ONT-network interface ..................................................................... 413
Bibliography............................................................................................................................. 420
GMT+8, 2025-3-31 15:28
