[仪表] HFG2.0 Gas Fuel Metering Valve User Manual 英文手册
q33665987@sohu. 发表于 2021-2-22 17:44:45 | 显示全部楼层 |阅读模式
完整文档下载
dianzifa001.pdf (2.03 MB, 售价: 1 E币)
This manual provides installation, maintenance, and operating instructions for the HFG2.0Gas Fuel Metering Valve.Every attempt has been made to provide sufficient information in this manual for theproper operation and preventive maintenance of the valve. Read this manual in itsentirety to fully understand the system.Operating the HFG2.0 Gas Fuel Metering Valve in accordance with instructions hereinensures long term and reliable operation.
Purpose of This Guide..............................................................................................................................iii
Product Identification................................................................................................................................iii
What the User Should Know....................................................................................................................iv
Related Publications.................................................................................................................................iv
1 INSTALLING THE HFG2.0......................................................................................................................1
1.1 Before Beginning...............................................................................................................................1
1.2 General Specification Summary........................................................................................................3
1.3 Mechanical Installation ......................................................................................................................4
1.4 Electrical Connections .......................................................................................................................15
2 UNDERSTANDING THE HFG2.0 ...........................................................................................................26
2.1 System Description............................................................................................................................26
2.2 Electrical Description .........................................................................................................................27
2.3 Mechanical Description......................................................................................................................31
2.4 Identification Plate..............................................................................................................................37
3 OPERATING THE HFG2.0......................................................................................................................40
3.1 Powering Up......................................................................................................................................40
3.2 Finding Home Position.......................................................................................................................40
3.3 Holding Motor Current State..............................................................................................................41
3.4 Moving to Stop Position.....................................................................................................................43
3.5 Controlling Motion..............................................................................................................................43
3.6 Resetting the Actuator.......................................................................................................................45
3.7 Monitoring System Health..................................................................................................................46
3.8 Changing Set-Up Parameters ...........................................................................................................51
4 MAINTAINING THE HFG2.0 ...................................................................................................................54
4.1 Refurbishment ...................................................................................................................................54
5 TROUBLESHOOTING.............................................................................................................................56
5.1 FAULT File ........................................................................................................................................60
APPENDIX A: DECOMMISSIONING & DISPOSAL.....................................................................................62
APPENDIX B: GLOSSARY...........................................................................................................................64
Figure 1-1. Typical HFG2.0 Gas Fuel System Installation...............................................5
Figure 1-2. Alternate HFG2.0 Gas Fuel System Installation ............................................5
Figure 1-3. HFG2.0 Dimensions, 3-Piece Housing..........................................................9
Figure 1-4. HFG2.0 Dimensions, 1-Piece Housing........................................................10
Figure 1-5. HFG2.0 Mounting Orientations....................................................................11
Figure 1-6. HFG2.0 Mounting Provisions, 3-Piece Housing (Standard Mounting).........12
Figure 1-7. HFG2.0 Mounting Provisions, 1-Piece Housing (Standard Mounting).........13
Figure 1-8. HFG2.0 Mounting Provisions, 1-Piece Housing (Reversed Mounting)........14
Figure 1-9: HFG2.0 System Power Wiring Diagram......................................................16
Figure 1-10. Typical Power Connection With Power Supply..........................................16
Figure 1-11. Typical Power Connection With Battery ....................................................16
Figure 1-12: HFG2.0 System Signal Wiring Diagram ...................................................20
Figure 1-13. Typical Analog Input Connection...............................................................21
Figure 1-14. Typical Analog Output Connection............................................................21
Figure 1-15. Typical Discrete Input Command Connection ...........................................21
Figure 1-16. Typical Discrete Output Alarm Connections..............................................22
Figure 1-17. Typical RS232 Serial Interface Connection...............................................22
Figure 2-1. HFG2.0 Electronics System Block Diagram................................................29
Figure 2-2. HFG2.0 Cut-Away View – Actuator Main Housing Assembly......................35
Figure 2-3. HFG2.0 Cut-Away View (Partial).................................................................36
Figure 2-4. Typical Identification Plate ...........................................................................37
Figure 2-5. Typical Refurbishment Plate........................................................................38
Figure 3-1. HFG2.0 Basic Operation Flow Chart...........................................................42
Figure 3-2. HFG2.0 Actuator Position vs. DEMAND......................................................44
Figure 3-3. Dead Band of Actuator, Position vs. DEMAND Curve.................................45
Table 1-1. Wire List for HFG2.0 Power Harness............................................................16
Table 1-2. Power Supply Requirements........................................................................17
Table 1-3. Wire Size for HFG2.0 Power Harness..........................................................18
Table 1-4. Wire List for HFG2.0 System Signal Harness...............................................19
Table 1-5. Computer COM Port Pin Outs......................................................................23
Table 1-6. Wire Size for HFG2.0 Signal Harness ..........................................................24
Table 3-1. Default Configuration For FAULT Alarm ...............................................48
Table 3-2. Default Configuration For OVERTEMP Alarm ......................................48
Table 3-3. Fault Configuration For FAULT Alarm ........................................49
Table 3-4. Fault Configuration For OVERTEMP Alarm ...............................50
Table 3-5. Typical HFG2.0 Setup Parameters With Default Values ..............................52
Table 5-1. Initial Installation Troubleshooting Chart .......................................................58
Table 5-2. HFG2.0 In-Service Troubleshooting Chart....................................................58
Table 5-3. HFG2.0 Electrical Continuity Troubleshooting Chart ....................................59
部分内容截图
GMT+8, 2025-3-31 16:22
