[工业通信] SST Profibus Backplane Products Installation v3.1
seasky 发表于 2020-11-19 17:10:04 | 显示全部楼层 |阅读模式
安装文件下载:仅提供个人在家学习用途,此程序文件来源于网络可靠性稳定性完整性皆无法验证,禁止用于其他用途,否则后果自负。
PB3_Backplane_Install_V3_1_0.zip (78.17 MB, 售价: 25 E币)
SST Profibus Backplane Products Installation v3.1.x.0 Content
What is New :
- Support for the SST-PB3-PCIe-H (Master/Slave), SST-PB3M-PCie-H (Master Only)
- Updated firmware pfb3-2.ss3 vv3.1.0.0
- New Slave GSD file for SST-PB3-PCIe-H
Supported Operating Systems
- Microsoft Windows XP Professional   32-Bit
- Microsoft Windows Server 2003        32-Bit
- Microsoft Windows Vista                32-Bit and 64-Bit
- Microsoft Windows Server 2008        32-Bit
- Microsoft Windows 7                32-Bit and 64-Bit
- Microsoft Windows Server 2008 R2        64-Bit
- Microsoft Windows Server 2012 64-Bit
- Microsoft Windows 8                32-Bit and 64-Bit
- Microsoft Windows 8.1                32-Bit and 64-Bit
Notice
- If you are using Windows XP and the Firewall is enabled, configure an exception to be able to use the SST Profibus Configuration Tool to browse using Ethernet/IP Driver.
Known Issues
For SST-PB3-REM, SST-PB3-REM-R Profibus Masters
- when upload config with BIT definition the bit definition is then lost
- Recommended RPI should start at 3ms for SST-PB3-REM and SST-PB3-REM-R (Currently 2ms under the Master properties on the Parameters tab)
For the SST-PB3-CPX Master
- Cannot connect to CompactLogix PLCs using a Local 1769 Bus Adapter VA1769/A (older CPX PLCs like L35E, L32E, L23E)
- Config tool is not saving the RSlinx connection type under COM Channel dialog under Master properties
SST-PB3-CLX firmware , Backplane module version 8.8.2, Profibus module version 7.29
- Get "Error: 0x2000060B. DPV1 already initialized" when do network browse in CommDTM with PB3-CLX
- Cannot resend DPV1 CIP messages when FDL errors occur
- Cannot detect all modules from slave (with more than 32 modules) when the master goes to browse for it on the network using DPView (Part of SST-Profibus Configuration Tool)
CommDTM v1.3.0.0 for SST-PB3-CLX
- the CommDTM and SST Profibus configuration Tool cannot access to the SST-PFB-CLX simultaneously.
- two CommDTM cannot access to the same SST-PFB-CLX.
- errors can occur when connecting simultaneously the CommDTM to a SST-PFB-CLX via a local path and a
SST-PFB-CLX via an Extended Path in a same ControlLogix. It is then recommended to use either local path(s), either extended path(s).
SST-PB3-REM firmware v1.1.8.0, SST-PB3-REM-R firmware v1.1.3.0
-At 10Mb H/F packets dropped.10 Mb H/F not supported
- EO (Connection accepted when Data IO size defined in the SST Profibus Configuration Tool is higher than the IO assembly size).
SST-PB3-CPX firmware v1.1.0.0
- SST-PB3-CPX module does not appear in RSlinx until a backplane connection is made to module
- Some Diagnostic counters still continue to increment when profibus cable is disconnected from Module
- Configuration Mismatch occurs when CFG tool reconnects to module that has just started up
- the option "Major Fault on Controller if connection fails While in Run mode" must not be enabled in I/O connection
- PB3-CPX module does not go CLEAR mode when CPX processor is removed from PLC
GMT+8, 2026-3-14 08:29
