[工业机器人] FANUC PC Developer's Kit Version V9.30 (Rev A)
seasky 发表于 2020-11-17 01:17:46 | 显示全部楼层 |阅读模式
FANUC ROBOGUIDE 机器人软件C#、VB、VB.net开发包。
安装文件下载:(没有破解补丁)仅提供个人在家学习用途,此程序文件来源于网络可靠性稳定性完整性皆无法验证,禁止用于其他用途,否则后果自负。
若安装提示如下错误,选择忽略即可,这是个bug,9.3版本已经把pcdk.pdf这个文件放到了Documentation目录下,而不是被打包在cab文件里了。
Visual Basic, VB.NET or C# and PC Developer's Kit are all you need to write Windows 10 applications that interact with the R-J3, R-J3iB, R-30iA, R-30iA Mate, R-30iB and R-30iB Mate,R-30iB Plus, R-30iB Plus Mate and R-30iB Plus Compact controllers.
PCDK's high performance, object oriented interface is so easy to use that you can have your first application up and running soon after you finish reading this.
1. New features included in this setup package
V9.30 builds on the firm foundation of V9.10. The differences are listed below.
This version is required when communicating to robots with controller versions V8.00.  It is also fully compatible with controller versions V5.11, V5.20, V5.22, V5.30, V6.11, V6.20, V6.21, V6.22, V6.23, V6.24,V6.31, V6.40, V6.43, V7.20, V7.30, V7.40, V7.50, V7.60, V7.63, V7.70,V8.10, V8.13, V8.20, V8.30, V9.10 and V9.30.
Included in V9.30 (Rev.A)
  Robot Controller version V9.30 is supported.
  The V9.30 controller includes a number of enhancements that required changes to the Robot Server to handle them.
flyingchj 发表于 2021-8-15 18:21:07 | 显示全部楼层
楼主,最近想学习一下用这个develper kit 与机器人做数据交互,谢谢!
Wanderer 发表于 2023-3-27 16:46:32 | 显示全部楼层
楼主这个与模拟软件交互位置数据能达到4ms吗?
louzhunihao 发表于 2024-1-10 15:03:04 | 显示全部楼层
楼主网盘链接确认可以用吗?
 楼主| seasky 发表于 2024-1-10 23:57:53 | 显示全部楼层
楼主网盘链接确认可以用吗?
链接有效的,如果万一失效,可以回帖反馈
GMT+8, 2025-4-2 01:13
