[PLC] 三菱α Simple Application Controller手册 阿尔法简易控制器
xunlu 发表于 2020-10-16 15:47:04 | 显示全部楼层 |阅读模式
M-α Series controller.pdf (1.42 MB, 售价: 10 E币)
The simple, friendly α Series has been designed for use around your home, office, factory.... anywhere thatrequires a flexible supervisory control function. Every module allows you to read signals and set outputsaccording to particular conditions or time settings defined by you, the user. Plus the built-in programmabledisplay allows you to check the status of your system anytime.Special features of the α Series system are:• Direct (on-device) programming capability• High current output capability• Small size• Easy access programming port• EEPROM cassette program storage capability• Built-in Real Time Clock as standard• Windows based programming package, AL-PCS/WIN-E• Plus a full range of support documentation and Training packagesThe α Series is designed to be used in the following automatic applications: lighting, air conditioning,irrigation, doors, gates, simple security systems, greenhouses, air fans, etc. The Real Time Clock can beused as a power saving device to automatically turn the equipment On/Off at scheduled times.Debug programs carefully before installing in automated equipment. The α Series is not designed to be usedin life critical or fail safe applications.Contact your dealer for more information.
Table of Contents
Guideline...................................................................................................................................ii
1. Introduction............................................................................................................ 1
2. Hardware Specification......................................................................................... 3
2.1 Available Models.......................................................................................................... 3
2.2 Power Supply Specification ......................................................................................... 4
2.3 Input Specification........................................................................................................ 6
2.4 Output Specification..................................................................................................... 8
2.5 General Specification................................................................................................... 9
3. Installation............................................................................................................ 11
3.1 DIN RAIL Mounting .................................................................................................... 11
3.2 Termination at Screw Terminals ................................................................................ 11
3.3 Installation Mounting Notes........................................................................................ 12
ENG
iv
4. Wiring ................................................................................................................... 15
4.1 Installation Wiring Notes ............................................................................................ 15
4.2 Wire Size and Specifications ..................................................................................... 15
4.3 Power Supply............................................................................................................. 16
4.4 Recommended Power Input Wiring Diagram............................................................. 16
4.5 AC Input Wiring.......................................................................................................... 17
4.5.1 AC Input Wiring Diagram..................................................................................... 17
4.6 Wiring Diagrams for the Sink/Source Terminals ........................................................ 18
4.6.1 Source (“+” Common) Input Wiring Diagram....................................................... 18
4.6.2 Sink ("-" Common) Input Wiring Diagram ............................................................ 18
4.7 Output Relay and Transistor Wiring........................................................................... 19
4.7.1 Relay Output Wiring Diagram (AC and/or DC).................................................... 19
4.7.2 Transistor Output (Source or “+” Common Only) Wiring Diagram ...................... 20
5. α Series Terminal Layout.................................................................................... 21
6. How to Use α Series Controllers - Getting Started........................................... 23
6.1 Connecting Two Blocks ............................................................................................. 23
6.2 Accessing Blocks ...................................................................................................... 24
6.3 Setting Function Block Parameters............................................................................ 25
6.4 Exiting, Running, and Stopping the Program............................................................. 25
GMT+8, 2025-3-31 16:25
