[PLC编程] Omron CX-One Ver.4.51 多语言版本
MULTIPLAS 发表于 2020-5-12 10:52:04 | 显示全部楼层 |阅读模式
CX-one 4.51版本增加对CP2E的支持。
Omron CX-One Ver.4.61 多语言版本含简体中文
https://www.eleok.com/thread-123557-1-1.html
Modification notice of version upgrade (Ver.4.51) of
[Changes]
Before the change
After the change
[CX-One Version]
Ver.4.50
[CX-One Version]
Ver.4.51
[Changes]
Before the change
After the change
The functions on the right were not provided.
CX-Programmer Ver.9.73
[Support of New Type]
*Supported the following new models.
CP2E-E[][]DR-A, CP2E-S[][]D[]-[], CP2E-N[][]D[]-[]
[Improved functions]
*Changed the default PLC.
When CX-One is installed: CJ1M-CPU11 => CJ2M-CPU11
When CX-One Lite is installed: CP1L-M => CP2E-S
* Solved the problem that CX-Programmer terminated abnormally or became inoperable when a project with a long project name or a long PLC name was loaded.
* Solved the problem that a fatal error occurred on the PLC after the project was downloaded, becauseDR0+,IR00 that was specified for instruction’s parameter was not detected in error check.
* Solved the problem that timer/counter numbers were determined incorrectly as duplicated with CIO address when the CIO address was specified as automatic allocation area.
* Solved the problem that an error might not be detected in program check even though input condition of the FB instance was not correct.
* Solved the problem that CX-Programmer might terminate abnormally, when a program that included FB instance was uploaded from the PLC.
*Solved the problem that the UM size displayed in the FB Memory view of CP1 might be incorrect when there is an FB definition and no FB instance.
*Solved the problem that an error occurs in the program check for a program with the maximum display capacity in the Memory view, when interrupt tasks and FB definitions are used simultaneously in a PLC with an area for FB only.
*Solved the problem that program errors cannot be detected if an array of variable type index is specified in the DIFU/DIFD instruction operands in the FB ladder.
*Solved the problem that a fatal error might occur in the PLC if a structure BOOL type member is used for the IF statement condition for the FBST program in CJ2H/CJ2M.
*Solved the problem that transferring CP1E programs to CX-Simulator might fail when the programs include interruption tasks.
*Solved the problem that no error is detected in program check even when an array variable without address assignment is used in a ST program/ST action/ST transition.
*Solved the problem in Ver.9.72 that arithmetic expressions cannot be used as the index of array variables in the ST program.
*Solved the problem that data could not be transferred to the comment memory immediately after clearing all memory.
CX-Simulator Ver.2.01
[Changes]
Before the change
After the change
CX-Integrator Ver.2.67
CP2E-N[][]D[]-[]
*Solved the problem that CX-Integrator might terminate abnormally when device parameters of the EJ1N-HFUB-DRT are copied.
CX-DriveVer.3.00
*Supported the new inverter 3G3RX2-series
CX-Protocol Ver.2.01
* Solved the problem that memory leak might occur when the project file could not be loaded.
CX-Thermo Ver.4.69
* Supports E5DC Push-In type.
Network Configurator Ver.3.68
*Supported the K6PM series Control Panel Monitoring Device.
*Supported the FHV7 series Smart Camera.
*Supported the V430-F series Auto Focus Multi Code Reader.
CX-ConfiguratorFDT Ver.2.53
*Supported the E2E-NEXT (IO-Link embedded) series proximity sensors.
NX-IO Configurator Ver.1.21
*Supported the simple setting function for IO-Link master (NX-ILM400).
* Supported NXーseries Temperature Control Unit (NX-TC) Ver1.2.
[Changes]
Before the change
After the change
Switch Box Utility Ver.1.70
CP2E-E[][]DR-A, CP2E-S[][]D[]-[], CP2E-N[][]D[]-[].
Common Components of CX-One and Sysmac Studio
* It is now possible to install IODD files (standard profile of IO-Link device) of Omron’s IO-Link devices.
* It is now possible to install IODD files of Intelligent tap (accessory for F3SG-SR/PG series Safety Light Curtain)
* It is now possible to install IODD files of Proximity sensors (E2EW series)
[PLC Tools]
* Improved to prevent memory leak when the I/O table component terminates.
[Product Lineup]
Product Name
Model
Specifications
FA Integrated Tool Package CX-One Ver.4.51
CXONE-AL00D-V4
DVD Media only
CXONE-AL01D-V4
DVD Media, 1 license
CXONE-AL01D-V4-UP
DVD Media, 1 license (The upgrade versions)
CXONE-AL03D-V4
DVD Media, 3 licenses
CXONE-AL03D-V4-UP
DVD Media, 3 licenses (The upgrade versions)
CXONE-AL10D-V4
DVD Media, 10 licenses
CXONE-AL10D-V4-UP
DVD Media, 10 licenses (The upgrade versions)
CXONE-AL30D-V4
DVD Media, 30 licenses
CXONE-AL30D-V4-UP
DVD Media, 30 licenses (The upgrade versions)
CXONE-AL50D-V4
DVD Media, 50 licenses
CXONE-AL50D-V4-UP
DVD Media, 50 licenses (The upgrade versions)
CXONE-ALXXD-V4
DVD Media, Site license
CXONE-ALXXD-V4-UP
DVD Media, Site license (The upgrade versions)
FA Integrated Tool Package CX-One Lite Ver.4.51
CXONE-LT01D-V4
CXONE-LT01D-V4-UP
* CX-One Lite is a subset of the complete CX-One package that provides only the Support Software required for micro PLC applications.
Specifications in this product news are as of the issue date and are subject to change without notice.
Only main changes in specifications are described in this document. Please be sure to read the relevant catalogs, datasheets, product specifications, instructions, and manuals for precautions and necessary information when using products.
GMT+8, 2026-9-29 09:07
