电力系统故障录波数据管理系统分析仪vc++源码
山海致远 发表于 2020-5-2 00:51:53 | 显示全部楼层 |阅读模式
电力系统故障录波数据管理系统分析仪vc 源码.rar (8.36 MB, 售价: 1 E币)
  1. DDCJ.cpp  implementation file
  2. #include stdafx.h
  3. #include wgl_32.h
  4. #include DDCJ.h
  5. #ifdef _DEBUG
  6. #define new DEBUG_NEW
  7. #undef THIS_FILE
  8. static char THIS_FILE[] = __FILE__;
  9. #endif
  10. CDDCJ dialog
  11. CDDCJCDDCJ(CWnd pParent =NULL)
  12.          CDialog(CDDCJIDD, pParent)
  13. {
  14.         {{AFX_DATA_INIT(CDDCJ)
  15.                  NOTE the ClassWizard will add member initialization here
  16.         }}AFX_DATA_INIT
  17. }
  18. void CDDCJDoDataExchange(CDataExchange pDX)
  19. {
  20.         CDialogDoDataExchange(pDX);
  21.         {{AFX_DATA_MAP(CDDCJ)
  22.                  NOTE the ClassWizard will add DDX and DDV calls here
  23.         }}AFX_DATA_MAP
  24. }
  25. BEGIN_MESSAGE_MAP(CDDCJ, CDialog)
  26.         {{AFX_MSG_MAP(CDDCJ)
  27.         ON_WM_PAINT()
  28.         }}AFX_MSG_MAP
  29. END_MESSAGE_MAP()
  30. CDDCJ message handlers
  31. BOOL CDDCJOnInitDialog()
  32. {
  33.         CDialogOnInitDialog();
  34.         GetDlgItem(IDC_RESULT)-GetWindowRect(&m_ResultRect);
  35.         ScreenToClient(&m_ResultRect);
  36.         return TRUE;   return TRUE unless you set the focus to a control
  37.                        EXCEPTION OCX Property Pages should return FALSE
  38. }
  39. void CDDCJOnPaint()
  40. {
  41.         CPaintDC dc(this);  device context for painting
  42.
  43.         char temp[20];
  44.         dc.SetBkMode(TRANSPARENT);
  45.         if(fFaultJL == -1)
  46.                 dc.TextOut(m_ResultRect.left+20, m_ResultRect.top+40, 故障距离未知!);
  47.         else
  48.         {
  49.                 sprintf(temp, 故障距离=%-.2fKM, fFaultJL);
  50.         dc.TextOut(m_ResultRect.left+20, m_ResultRect.top+40, temp);
  51.         }
  52.
  53. }
  54. 详细完整源码见附件
GMT+8, 2026-4-8 09:34
