VBA脚本获取计算机IP
coolice 发表于 2020-4-27 11:44:27 | 显示全部楼层 |阅读模式
Public Sub SaveActionLog(ByVal sActNo As String, ByVal sActtype As String, ByVal sActDesc As String)
Dim Database_Cnn As ADODB.Connection
Dim RS As ADODB.Recordset
Dim Cmd As ADODB.Command
Dim Param As ADODB.Parameter
Dim nValue As Long
On Error GoTo e
Set Cmd = New ADODB.Command
Set Param = New ADODB.Parameter
Set Database_Cnn = New ADODB.Connection
Database_Cnn.ConnectionString = "File Name=" & "C:\TY_Integration\UserControl\DB.udl"
Database_Cnn.Open
Cmd.CommandText = "Proc_SaveActionLog"
Cmd.CommandType = adCmdStoredProc
Cmd.ActiveConnection = Database_Cnn
Param.Name = "RetVal"
Param.Type = adInteger
Param.Direction = adParamReturnValue
Cmd.Parameters.Append Param
Param.Name = "@vchActNo"
Param.Type = adVarChar
Param.Size = 32
Param.Direction = adParamInput
Param.Value = sActNo
Param.Name = "@vchActType"
Param.Size = 32
Param.Value = sActtype
Param.Name = "@vchActDesc"
Param.Size = 128
Param.Value = sActDesc
Cmd.Execute
nValue = Cmd.Parameters("RetVal").Value
Exit Sub
e:
'MsgBox Err.Description
End Sub
Public Function GetIPAddress() As String
   Dim sHostName    As String * 256
   Dim lpHost    As Long
   Dim HOST      As HOSTENT
   Dim dwIPAddr  As Long
   Dim tmpIPAddr() As Byte
   Dim i         As Integer
   Dim sIPAddr  As String
   If Not SocketsInitialize() Then
      GetIPAddress = ""
      Exit Function
   End If
   MAX_WSADescription = 256
   MAX_WSASYSStatus = 128
   ERROR_SUCCESS = 0
   WS_VERSION_REQD = &H101
   WS_VERSION_MAJOR = WS_VERSION_REQD \ &H100 And &HFF&
   WS_VERSION_MINOR = WS_VERSION_REQD And &HFF&
   MIN_SOCKETS_REQD = 1
   SOCKET_ERROR = -1
   If gethostname(sHostName, 256) = SOCKET_ERROR Then
      GetIPAddress = ""
      MsgBox "Windows Sockets error " & str$(WSAGetLastError()) & _
              " has occurred. Unable to successfully get Host Name."
      SocketsCleanup
      Exit Function
   End If
   sHostName = Trim$(sHostName)
   lpHost = gethostbyname(sHostName)
   If lpHost = 0 Then
      GetIPAddress = ""
      MsgBox "Windows Sockets are not responding. " & _
              "Unable to successfully get Host Name."
      SocketsCleanup
      Exit Function
   End If
   CopyMemory HOST, lpHost, Len(HOST)
   CopyMemory dwIPAddr, HOST.hAddrList, 4
   ReDim tmpIPAddr(1 To HOST.hLen)
   CopyMemory tmpIPAddr(1), dwIPAddr, HOST.hLen
   For i = 1 To HOST.hLen
      sIPAddr = sIPAddr & tmpIPAddr(i) & "."
   Next
   GetIPAddress = Mid$(sIPAddr, 1, Len(sIPAddr) - 1)
   SocketsCleanup
End Function
Public Function GetIPHostName() As String
   ERROR_SUCCESS = 0
   SOCKET_ERROR = -1
        GetIPHostName = ""
        Exit Function
    End If
        GetIPHostName = ""
        SocketsCleanup
        Exit Function
    End If
    GetIPHostName = Left$(sHostName, InStr(sHostName, Chr(0)) - 1)
    SocketsCleanup
End Function
Public Function HiByte(ByVal wParam As Integer) As Byte
  'note: VB4-32 users should declare this function As Integer
   HiByte = (wParam And &HFF00&) \ (&H100)
End Function
Public Function LoByte(ByVal wParam As Integer) As Byte
   LoByte = wParam And &HFF&
End Function
Public Sub SocketsCleanup()
    If WSACleanup() <> ERROR_SUCCESS Then
        MsgBox "Socket error occurred in Cleanup."
    End If
End Sub
Public Function SocketsInitialize() As Boolean
   Dim WSAD As WSADATA
   Dim sLoByte As String
   Dim sHiByte As String
   ERROR_SUCCESS = 0
   SOCKET_ERROR = -1
   If WSAStartup(WS_VERSION_REQD, WSAD) <> ERROR_SUCCESS Then
      MsgBox "The 32-bit Windows Socket is not responding."
      SocketsInitialize = False
      Exit Function
   End If
   If WSAD.wMaxSockets < MIN_SOCKETS_REQD Then
        MsgBox "This application requires a minimum of " & _
                CStr(MIN_SOCKETS_REQD) & " supported sockets."
        Exit Function
    End If
   If LoByte(WSAD.wVersion) < WS_VERSION_MAJOR Or _
     (LoByte(WSAD.wVersion) = WS_VERSION_MAJOR And _
      HiByte(WSAD.wVersion) < WS_VERSION_MINOR) Then
      sHiByte = CStr(HiByte(WSAD.wVersion))
      sLoByte = CStr(LoByte(WSAD.wVersion))
      MsgBox "Sockets version " & sLoByte & "." & sHiByte & _
             " is not supported by 32-bit Windows Sockets."
      Exit Function
   End If
   SocketsInitialize = True
End Function
GMT+8, 2026-3-13 01:42
