[CNC] FANUC Program Transfer Tool V16.0 安装文件下载
MULTIPLAS 发表于 2020-1-28 12:17:40 | 显示全部楼层 |阅读模式
FANUC程式传输工具,CNC<->PC程序互传非常方便,0i-B/C/D、16i/18i/21i-A/B、30i/31i/32i-A、PMi-D/H 均可使用(系统需配置以太网接口和功能)
序列号在解压后的SN.txt里
FANUC Program Transfer Tool Edition 16.0安装文件.zip (14.05 MB, 售价: 2 E币)
FANUC Program Transfer Tool 其他版本下载
https://doc.eleok.com/2322.html
[1] Environment
1.1. 支持的操作性系统
    Program Transfer Tool supports the following OS.
      - Windows 10 Pro                (32/64bit OS)
      - Windows 8 Pro                 (32/64bit OS)
      - Windows 7 Professional SP1    (32/64bit OS)
      - Windows Vista Business SP2    (32bit OS)
      - Windows XP Professional SP3   (32bit OS)
    Display : 1024x768 or higher resolution
    Vacant capacity of hard disk : 30Mbytes or more
1.2. Program Transfer Tool 支持以下CNC:
      - Series 30i/31i/32i-MODEL A/B
      - Series 35i-MODEL B
      - Power Motion i-A
      - Series 0i-MODEL B/C/D/F
      - Series 16i/18i/21i-MODEL A/B
      - Series 20i-MODEL B
      - Power Mate i-MODEL D/H
   The Ethernet or Data Server function is required to CNC.
   The PCMCIA LAN card is not supported.
[2] Installation
2.1. Procedure of installation
     - The administrator privilege is required to installing.
     - Silent installation is not supported.
    (1) Set CD-ROM in CD-ROM drive.
    (2) The installer will be started automatically.
    Follow the instructions which are displayed in PC.
2.2 Serial No.
    After the installing, the serial number is required on the setting dialog.
    The serial number paper is included in the CD-ROM case.
2.3 Procedure of update
    - It is possible to update from old specification, A08B-9510-J513 or
      A08B-9510-J514, to the new specification, A08B-9510-J515.
    - The following updating procedure is different:
        (a) Version 1.0 -> Version 2.0
        (b) Version 2.0 -> Version 3.0 or later
      Please refer to the manual for the detail.
[3] Update history
   Version 16.0 (June, 2019)
        - The download speed to the program storage file (FANUCPRG.BIN) stored
          in the memory card of CNC is improved.
        - Even if the Program Folder Screen is displayed on the CNC while
          downloading or uploading multiple text files to or from the CNC
          memory card, the transfer have been supported.
   Version 15.0 (Nov.,2018)
        - Program storage file (named "FANUCPRG.BIN") in the memory card of CNC
          has been supported.
        - The number of path(head) supported by the tool has been expanded to
          15.
   Version 14.0 It is a missing number.
   Version 13.0 (May,2018)
        - Communication may be terminated when operation is not performed for
          a certain period of time after connecting this tool and CNC.
          This phenomenon may occur in Windows Vista or later OS.
          It has improved so that this phenomenon does not occur.
   Version 12.0 (Mar.,2017)
        - Memory card of CNC is supported.
   Version 11.0 It is a missing number.
   Version 10.0 (Nov.,2014)
        - Series 0i-MODEL F has been supported.
        - Windows 10 Pro(32bit/64bit OS) has been supported.
   Version 9.0 (June,2014)
        - License and specification has been changed.
          License
            The single computer license has been changed to the site license.
            Please refer to the "LICENSE AGREEMENT" for details.
          New specification
            A08B-9510-J515
          Old specifications are abolished.
            A08B-9510-J513
            A08B-9510-J514
   Version 8.0 (Aug.,2011)
        - Power Motion i-A has been supported.
        - Windows 8 Pro(32bit/64bit OS) has been supported.
   Version 7.0 (Feb.,2011)
        - Windows 7 Professional(64bit OS) has been supported.
   Version 6.0 (Oct.,2010)
        - Series 30i/31i/32i-MODEL B, Series 35i-MODEL B has been supported.
   Version 5.1 (May,2010)
        - The following error may be occurred at downloading.
            "Retry because the buffer is full."
          This problem is corrected.
   Version 5.0 (Apr.,2010)
        - Windows 7 Professional(32bit OS) has been supported.
   Version 4.0 (Sep.,2008)
        - Transferring tool management data of Series 30i/31i/32i-MODEL A has
          been supported.
   Version 3.0 (May.,2008)
        - Series 0i-MODEL D has been supported.
        - Simplified Chinese has been supported.
   Version 2.0 (Dec.26,2007)
        - Windows Vista Business(32bit OS) has been supported.
        - Upgrade CD is added.
   Version 1.0 (Oct.03,2007)
        - New creation
ttyin_1210 发表于 2022-9-19 19:51:05 | 显示全部楼层
序列号为什么注册不了呢?
lineX 发表于 2022-9-20 11:53:12 | 显示全部楼层
序列号为什么注册不了呢?
这个估计是没找到填写注册码的地方吧,测试了一下好用。
填写注册码的方法,打开windows操作系统的开始菜单找到“会话设定”,点击运行,在出现配置界面的菜单栏点击“序列号”--“管理”,会弹出来输入序列号的界面
还有一种方法,FANUC Program Transfer Tool程序安成后,打开程序安装的目录,例如默认的目录是“C:\Program Files (x86)\FANUC\Program Transfer Tool\Bin”,根据你安装时候实际选择的目录,运行Bin目录下的PttConf.exe,也会弹出来序列号的窗口。输入正确的序列号后,就可以正常的打开主程序了
chenhui1040 发表于 2022-10-28 10:07:57 | 显示全部楼层
支持一下,多多积分 攒币
can5216625377 发表于 2023-5-15 19:19:21 | 显示全部楼层
dddddddd有用 建议顶起来大家用
GMT+8, 2025-12-15 06:00
