[仪表] F805AT DeviceNet I/F SPECIFICATIONS
coolice 发表于 2019-12-22 17:42:20 | 显示全部楼层 |阅读模式
This document describes specifications of the DeviceNet option to link a PLC and F805AT.By using DeviceNet, the F805AT can be controlled directly from the PLC, resulting in substantialreductions in wiring.The supported functions include reading of the present indicated value and status, commands such as D/Z, reading and writing of set values, etc.(* Since set values are read and written by message functions, use a master that supports them.)Parameters such as a slave are to be set at the front of the F805AT. Also, there is no need to set the baud rate of the F805AT since it automatically follows the master.In this document, outputs refer to signals from the master to the slave (F805AT), and inputs refer to signals from the slave (F805AT) to the master.
F805AT DeviceNet I F SPECIFICATIONS_1.02en.pdf (1.58 MB, 售价: 2 E币)
GMT+8, 2025-4-3 10:24
