STARTER V5.1 SP1 HF2 v5.1.1.2
seasky 发表于 2019-11-18 00:42:07 | 显示全部楼层 |阅读模式
The STARTER is the commissioning tool for all SINAMICS and MICROMASTER drives.The firmware versions of the drive units are an integral part of the STARTER, or are installed via additive SINAMICS Support Packages (abbr. SSP) as an addition to the STARTER.
下载链接:
The following minimum requirements have to be observed in case of STARTER and DCC without existing STEP 7 installation:
•        Microsoft Internet Explorer V6.0 or higher
        64-Bit Operating Systems:
•        Microsoft Windows 7 Professional SP1
•        Microsoft Windows 7 Ultimate SP1
•        Microsoft Windows 7 Enterprise SP1 (Standard Installation)
•        Microsoft Windows 10 Pro, Version 1607
•        Microsoft Windows 10 Enterprise, Version 1607
•        Microsoft Windows 10 Enterprise 2016 LTSB (OS Build 14393)
•        Microsoft Windows Server 2008 R2 SP1
•        Microsoft Windows Server 2016
STARTER V5.1 SP1 HF2 has been released for the following drive units:
New units or firmware versions added by this version are highlighted in bold.
•        MICROMASTER 4. Generation (MM420 V1.30, MM440 V2.20, MM430 V2.20)
•        SINAMICS DCM with firmware V1.1, V1.2, V1.3, V1.4, V1.4.1
•        SINAMICS DCP with firmware V1.1, V1.2
•        SIMATIC ET 200S FC with firmware V1.0.x,  V3.0.x
•        SIMATIC ET 200pro FC with firmware V3.0.x, V3.1.x
•        SIMATIC ET 200pro FC-2 with firmware V4.7.3, V4.7.6 and (with SSP) V4.7.9
•        SINAMICS G110 with firmware V1.0.x, V1.1.x, 1.2.x
•        SINAMICS G110D with firmware V3.3.x,  V3.4.x, V3.6.x, V3.7.x
•        SINAMICS G110M with firmware V4.6, V4.7, V4.7.3, v4.7.6 and (with SSP) V4.7.9
•        SINAMICS G120
o        with firmware V2.0.x, V2.1.x, V3.0.x, V3.1.x, V3.2.x
o        with firmware V4.2, V4.3.0, V4.3.2, V4.4, V4.5, V4.6, V4.7, V4.7.3, V4.7.6
•        SINAMICS G120C
o        with firmware V4.4, V4.5, V4.6, V4.7, V4.7.3, V4.7.6 and (with SSP) V4.7.9
•        SINAMICS G120D
o        with firmware V3.0.x, V3.1.x, V3.2.x, V4.5, V4.6, V4.7, V4.7.3, V4.7.6
•        SINAMICS G120P
•        SINAMICS G120P BT
o        with firmware V4.4.1, V4.6, V4.7, V4.7.3, V4.7.6 and (with SSP) V4.7.9
•        SINAMICS G130
o        with firmware V2.1.x, V2.2.x, V2.3.x, V2.4.x, V2.5.1, V2.6.1 and V2.6.2
o        with firmware V4.3.1, V4.3.2, V4.4, V4.5, V4.6, V4.7, V4.8 and (with SSP) V5.1
•        SINAMICS G150
•        SINAMICS GM150
o        with firmware V2.5.1, V2.6.1, V2.6.2, V4.3.1, V4.4.2, V4.5 (please see SINAMICS MV)
•        SINAMICS GL150
•        SINAMICS S110
o        with firmware V4.1, V4.3.1, V4.3.2, V4.4, V4.4.3
•        SINAMICS S120
o        with firmware V2.1.x, V2.2.x, V2.3.x, V2.4.x, V2.5.1, V2.6.1, V2.6.2
•        SINAMICS S150
•        SINAMICS SL150
o        with firmware V4.3.1, V4.4.2, V4.5 (please see SINAMICS MV)
•        SINAMICS SM120
o        with firmware V4.4.2 (please see SINAMICS MV)
•        SINAMICS MV (GM150/GL150/SL150/SM120)
o        with firmware V4.6, V4.7, V4.7.4, V4.7.5, V4.7.7
GMT+8, 2025-4-2 06:54
