FANUC Process IO 板接口信号
loop 发表于 2019-10-11 13:47:56 | 显示全部楼层 |阅读模式
机器人品牌
厂商: FANUC
There are 18 exclusive data inputs (DI) and 20 exclusive data outputs (DO) for a process I/O board.
These signals are allocated to the process I/O board connected first when two or more printed boards are combined. (General signals SDI/SDO are allocated to the second and the following process I/O boards.)The common voltage of the DI signals input to pins 1 to 4 of connector
CRM2A is clamped +24 V (common) in each process I/O board.Table 4.3 shows signals of a process I/O board.
附件是英文版
FANUC Process IO 板接口信号.pdf (22.3 KB, 售价: 1 E币)
GMT+8, 2026-9-20 16:30
