Proficy Process Systems 3.50.0.3874
zhangbing 发表于 2019-8-21 00:15:25 | 显示全部楼层 |阅读模式
Take Control – Based on open standards, Proficy Process Systems puts you in control. You have freedom from the constraints of traditional DCS systems and the freedom to configure your system to meet your needs.
Design the strategy that meets your needs – Proficy Process Systems includes a standard library of function blocks and the ability to create your own. With our industry-leading HMI visualization technologies (CIMPLICITY and iFIX), you can create whatever screens and displays you need to enable your operators to run your operations at top efficiency.
Build with the best – The latest versions combine the best of DCS and PLC control with GE’s latest hardware and software to give you the most current operating environment.
Simplify development and maintenance – With its robust function block library, you can reuse objects with your system allowing you flexibility in your control strategy development.
下载地址:若需要可以回帖索取
GMT+8, 2025-4-20 21:57
