PACsAnalyzer 4.0
zhangbing 发表于 2019-8-11 00:05:29 | 显示全部楼层 |阅读模式
4.0 - Build 1:
                Changed the configuration to an XML document
                Fixed buffer overflows defects
                Moved configuration file to public documents
                Digitally signed
                Ability to run as a command line
                  options
                    /cfg="config_file.xml"
                    /ip="nnn.nnn.nnn.nnn"
                    /out="output_file"
                    /silent
                  Commands
                    /get
                    /setclk
                    /help
When running from a command line you can use a configuration file for  multiple "controllers" if you want to perform batch diagnostics!  To obtain the format of a configuration file, run PACSAnalyzer manually, setup up the options you are interested in and then grab the file "C:\Users\Public\Documents\GE Intelligent Platforms\PacsAnalyzer\PACSetup.xml"  as a sample.
下载地址:
https://www.eleok.com/thread-123307-1-1.html
GMT+8, 2026-4-8 13:11
