Proficy Vision 6.3 sim24
zhangbing 发表于 2019-8-10 11:03:09 | 显示全部楼层 |阅读模式
1. SIM Details
SIM Number :        Proficy_Vision63_24
SIM Date :        July 27, 2018
Platform :        Proficy Vision 6.3
2. Installation Instructions
1. Copy Proficy Vision 6.3 SIM24 package to your Web Server machine and unzip.
2. Open a command prompt as administrator and change directory to the Proficy Vision 6.3 SIM24 unzip folder.
3. Type and run the following command:
        runUpgrade.bat <SQL_Server> <SQL_UserName> <SQL_Password> <DBName>(optional)
   Where <SQL_Host>, <SQL_UserName>, <SQL_Password> and <DBName> are user supplied command line arguments. The command line arguments must be supplied in this order.
   1. <SQL_Server>     Host machine for your SQL server or the SQL Server instance name (Hostname\InstanceName) if you are using a named instance
   2. <SQL_UserName>   Username for privileged SQL account (Administrator)
   3. <SQL_Password>   Password for privileged SQL account (Administrator)
   4. <DBName>         If the Workflow database is not named SOADB, then add the database name as the last parameter.
3. Configuration For Ldap
To configure Proficy Vision for LDAP please reference the guide Configuring Vision For Ldap contained within this upgrade package.
4. Set Task List preferences
Please reference the guide SetTaskListPreferences.pdf contained within this upgrade package.
5. Task List Pages
Please reference the guide Task List Pages.pdf contained within this upgrade package, for details of the page controls added to the Task List.
6. Auto-Logout Due to Inactivity
Please reference the guide  Auto-Logout Due to Inactivity.pdf contained within this upgrade package, for details on the new automatic logout feature.
独立安装方法运行在VisionInstall目录下的文件
下载地址:若需要可以回帖索取
GMT+8, 2026-3-14 08:49
