[工业通信] PlarSoft BACnet Quick Test v7.06
HooK 发表于 2019-8-9 12:16:40 | 显示全部楼层 |阅读模式
PlarSoft BACnet Quick Test (BQT) v7.06:
BACnet Device and Object Explorer
If you're an end-user, installer or product developer who needs to quickly check out and analyze multi-vendor BACnet systems, chances are you're struggling to make your system work properly and inter-operate across vendors. A lot of times Systems are not documented properly, or you just don't know "what's out there" at a given site, and you probably don't have the time to search out missing documents and call competitors for information. You need fast and reliable tools to Help you find out about the BACnet devices you have and focus on solving your application problems. You need helpful, flexible tools that really work, at a price that won't blow your budget. You need BACnet Quick TestTM (BQTTM).
BQT is an easy-to-use all-purpose BACnet device discovery, analysis and testing tool for Windows. BQT runs under Windows 7/8/10, Server 2008/2012 and XP, and provides a simple set of client features tailored to the Needs of end-users, installers and product developers who just want to run some quick tests.
After choosing a LAN media type (Ethernet 8802-3, BACnet/IP, BACnet/IPv6 or MS/TP), BQT immediately tries to discover the available BACnet devices on that LAN and display them in an intuitive "tree" structure similar to Windows Explorer.
The tree branches identify not only the device instance and MAC address for each device, but also the vendor and device name.
Opening a specific device branch shows the list of BACnet objects for the device and shows their name. You can click one of the objects to see a list of its specific properties and their values.
You can make detailed examination of single properties with a single click. This tool allows you to do reading and writing of individual properties for quick check-out and testing. Most properties are edited "in-place" or with helpful popup dialogs showing options. Commandable properties show convenient radio buttons for selecting priority instead of the usual click-scroll-click on other explorers.
BQT even displays the most complex property values ​​with helpful colorizing and structure. Yes, you can even modify those values!
If you need to have a tool for rapid simple tests of BACnet systems in the field, BQT is that must-have tool .
Super Easy Installation
BQT uses a unique installation technology that is very easy to setup. When you run BQT, it automatically tests for the type of operating system and LANs you have available and lets you choose the one you want!
Specifications:
Operating System: Microsoft Windows 7/8/10, Server 2008/2012 (x32 and x64)
Network Interface: Any NDIS-compliant Ethernet NIC, standard serial COM port or USB and EIA-485 converter
LANs:  BACnet/IP, BACnet/IPv6, MS/TP, Ethernet 8802-3
GMT+8, 2026-6-24 11:09
