Proficy HMI/SCADA - iFIX 5.8+SP1
zhangbing 发表于 2019-8-7 17:35:35 | 显示全部楼层 |阅读模式
下载地址:若需要请回帖索取
SP1补丁: iFIX58_SP1.zip (12.39 MB)
授权 https://www.eleok.com/thread-117556-1-1.html
GE Intelligent Platforms recommends using the latest service packs for Windows operating systems. The minimum iFIX software requirements include:
One of the following operating systems:
Microsoft Windows Vista, Service Pack 2, Business, Enterprise, or Ultimate Edition. Since Windows Vista has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows Server 2008 (32-bit), Service Pack 2, Standard or Enterprise Edition. Since Windows Server 2008 has continuous updates, you should run the Windows update feature to get the latest software.
NOTE: Be aware that the maximum, supported RAM on the Standard Edition for Windows Server 2008 (32-bit) is 4GB, and this may limit the performance. For better performance, it is recommended that you use a 64-bit operating system, or an operating system that supports Physical Address Extension (PAE). PAE is available on the Enterprise version of Windows Server 2008 (32-bit).
Microsoft Windows Server 2008 R2, Service Pack 1, Standard or Enterprise Edition. Since Windows Server 2008 has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows Server 2012, Standard or Enterprise Edition. Since Windows Server 2012 has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows 7 (32-bit or 64-bit), Service Pack 1, Professional, Enterprise or Ultimate Edition. Since Windows 7 has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows 8 (32-bit or 64-bit), Professional or Enterprise Edition. Since Windows 8 has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows Embedded Standard 7, Service Pack 1, with latest Microsoft Windows updates.
NOTE: Only English Windows Embedded, with English regional settings, is supported with English iFIX; other language operating systems or regional settings for Windows Embedded are not supported.
Network interface software for TCP/IP network communication and certain I/O drivers.
If you are using third-party software along with iFIX, make sure that the third party software is also supported for the operating system you are running iFIX on. For instance, if you are running iFIX on Microsoft Windows Vista, your third party software must also be supported on Microsoft Windows Vista.
An I/O driver for SCADA servers. GE Intelligent Platforms supplies I/O drivers for many programmable controllers or you may purchase a driver separately.
IMPORTANT: Be certain that the I/O driver you purchase is compatible with your hardware and operating system. For example, if the driver is not supported on a specific operating system, then you cannot use this driver with iFIX running on that operating system. For more information drivers and supported operating systems, check our support web site at: http://support.ge-ip.com.
If using VisiconX and Proficy Historian, you must install the Historian OLE DB driver.
If using the Plant Applications Dynamos in iFIX pictures, Microsoft Office 2003, 2007, or 2010(32-bit) is required.
One of the following relational database applications, if relational database software is used with iFIX:
Microsoft SQL Server 2008
Microsoft SQL Server 2008 R2
Microsoft SQL Server 2012
Oracle 11g R2
Microsoft Access 2000 (or higher). Microsoft Access is supported for local installs only
sunzhongjian 发表于 2019-11-29 11:20:09 | 显示全部楼层
很好,不容易啊
GMT+8, 2026-4-8 19:35
