Proficy HMI/SCADA - iFIX 5.1
zhangbing 发表于 2019-8-7 16:45:55 | 显示全部楼层 |阅读模式
下载地址:若需要请回帖索取
Software Requirements
GE Intelligent Platforms recommends using the latest service packs for Windows operating systems. The minimum iFIX software requirements include:
One of the following operating systems:
Microsoft Windows XP Professional, Service Pack 3 or greater. Since Windows XP has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows Server 2003, Service Pack 2 or greater (Standard or Enterprise Edition). Since Windows Server 2003 has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows Vista™, Service Pack 2, Business, Enterprise, or Ultimate Edition. Since Windows Vista has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows Server 2008 (32-bit only), Service Pack 2, Standard or Enterprise Edition. Since Windows Server 2008 has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows Vista™ Ultimate Edition Service Pack 2 running on a Tablet PC, iClient Only.
NOTE: Proficy Historian 3.5 is available for use in Windows Vista. Proficy Historian 3.1 currently does not support Windows Vista.
Microsoft Windows XP Tablet Edition, iClient Only.
Network interface software for network communication and certain I/O drivers.
If you are using third party software along with iFIX, make sure that the third party software is also supported for the operating system you are running iFIX on. For instance, if you are running iFIX on Microsoft Windows Vista, your third party software must also be supported on Microsoft Windows Vista.
An I/O driver for SCADA servers. GE Intelligent Platforms supplies I/O drivers for many programmable controllers or you may purchase a driver separately.
IMPORTANT: Be certain that the I/O driver you purchase is compatible with your hardware and operating system. For more information on drivers, contact your GE Intelligent Platforms Sales Representative or visit the support web site at http://www.ge-ip.com/support.
Microsoft Windows Internet Explorer 7 or 8. For iFIX Webspace sessions, in addition to Microsoft Internet Explorer 7 and 8, Mozilla Firefox 3.0, 3.1.x, or 3.5 is also supported.
If using the Historian Excel Add-In, Microsoft Office XP, Office 2003, or Office 2007 SP1 is required.
One of the following relational database applications, if relational database software is used with iFIX:
Microsoft SQL Server 2005 (SP2 and higher).
Microsoft SQL Server 2008.
Oracle 10g.
Oracle 11g.
Microsoft Access 2000 (or higher). Microsoft Access is supported for local installs only.
GMT+8, 2025-3-31 06:56
