Proficy HMI/SCADA - iFIX 5.1 64-bit WoW
zhangbing 发表于 2019-8-7 16:13:25 | 显示全部楼层 |阅读模式
下载地址:若需要可以回帖索取
Software Requirements
GE Intelligent Platforms recommends using the latest service packs for Windows operating systems. The minimum iFIX software requirements include:
One of the following operating systems:
Microsoft Windows XP Professional, Service Pack 3. Since Windows XP has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows Server 2003, Service Pack 2, Standard or Enterprise Edition. Since Windows Server 2003 has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows Vista™, Service Pack 2, Business, Enterprise, or Ultimate Edition. Since Windows Vista has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows Server 2008 (32-bit), Service Pack 2, Standard or Enterprise Edition. Since Windows Server 2008 has continuous updates, you should run the Windows update feature to get the latest software.
Microsoft Windows Server 2008 R2 (64-bit), Standard or Enterprise Edition. Since Windows Server 2008 has continuous updates, you should run the Windows update feature to get the latest software.
NOTES:
If you want to use Proficy Historian with iFIX on Windows Server 2008 R2 (64-bit), you must use Proficy Historian 4.0 or greater.
The iFIX WebSpace Server and Client are not supported on Windows Server 2008 R2 (64-bit).
Microsoft Windows 7 (32-bit or 64-bit), Professional or Ultimate Edition. Since Windows 7 has continuous updates, you should run the Windows update feature to get the latest software.
NOTES:
If you want to use Proficy Historian with iFIX on Windows 7, you must use Proficy Historian 4.0 or greater. Support for Windows 7 (32-bit and 64-bit) is not available in versions of Proficy Historian before 4.0.
The iFIX WebSpace Server is not supported on Windows 7 (32-bit or 64-bit). iFIX WebSpace browser sessions can be run on Windows 7, 32-bit only, on the supported versions of Internet Explorer and Mozilla Firefox.
Microsoft Windows Vista™ Ultimate Edition Service Pack 2 running on a Tablet PC, iClient Only.
Microsoft Windows XP Tablet Edition, iClient Only.
Network interface software for network communication and certain I/O drivers.
If you are using third party software along with iFIX, make sure that the third party software is also supported for the operating system you are running iFIX on. For instance, if you are running iFIX on Microsoft Windows Vista, your third party software must also be supported on Microsoft Windows Vista.
An I/O driver for SCADA servers. GE Intelligent Platforms supplies I/O drivers for many programmable controllers or you may purchase a driver separately.
IMPORTANT: Be certain that the I/O driver you purchase is compatible with your hardware and operating system. For more information on drivers, contact your GE Intelligent Platforms Sales Representative or visit the support web site at http://www.ge-ip.com/support.
Microsoft Windows Internet Explorer 7 or 8. For iFIX Webspace sessions, in addition to Microsoft Internet Explorer 7 and 8, Mozilla Firefox 3.0, 3.1.x, or 3.5 is also supported.
If using the Historian Excel Add-In, Microsoft Office XP, Office 2003, Office 2007 SP1, or Office 2010 is required.
One of the following relational database applications, if relational database software is used with iFIX:
Microsoft SQL Server 2005 (SP2 and higher).
NOTE: If you plan to use SQL Server in Windows Vista, you must use Microsoft® SQL Server 2005. Microsoft Windows Vista does not support SQL Server 2000.
Microsoft SQL Server 2008.
Oracle 10g.
Oracle 11g.
Microsoft Access 2000 (or higher). Microsoft Access is supported for local installs only.
GMT+8, 2025-3-31 06:55
