[工业通信] BOSS Simulator v2.2.15.0
HooK 发表于 2019-8-5 13:10:19 | 显示全部楼层 |阅读模式
:lol:lol:lol EXCLUSIVE RELEASE TO ELEOK :lol:lol:lol
BOSS Simulator v2.2.15.0:
Overview:
Building automation OEMs are constrained by a lack of comprehensive, certified tools to establish BACnet communication within their product offerings.
BACnet application development requires a physical interface with BACnet devices to test applications in real-time. Field-testing is expensive and time consuming. Hence, interoperability and testing often occur only in the BACnet test lab at the time of certification. As a result OEMs Spend a significant amount of time and incur greater expense to correct defects identified at the testing stage.
Solution:
Softtex's BOSS Simulator simulates a network of virtual BACnet devices, properties and service configurations, without the need for physical devices. It provides a comprehensive ability to effectively troubleshoot BACnet functionality and interoperability, without conducting field tests. Its easy-to-use interface allows developers And systems integrators to configure, monitor and issue service commands to accessible physical or virtual devices on the BACnet network.
Using the BACnet Simulator OEMs can test applications virtually and fix any issues noticed, before sending the device for testing.
Key Features of BOSS Simulator:
  • Simulate devices of PR-19
  • Segmentation support
  • BBMD Support
  • Backup and restore support
  • Support for both A-side and B-side services
  • User configurable simulation of PVs
  • Support IBM MS DBCS, ANSI X3.4, ISO 8859-1 character sets
  • Virtual router
  • Device discovery (searching and sorting by device ID, IP)
  • Object browser
  • Set property value of discovered objects
  • Continuously monitor property values ​​of discovered devices
  • Auto command configuration to generate periodic commands over the network
  • BOSS Simulator Vs BOSS Explorer
The below table gives the high-level overview of features, comparison, pricing info about our products- BOSS Simulator and BOSS Explorer.
More Info @  https://www.softdel.com/bacnet-device-simulator/
Software Cost = $1350 :D
相关帖子
GMT+8, 2025-4-11 12:39
