创建RUNTIME APPLICATION MER文件失败
hfwang2860270 发表于 2019-7-26 11:36:31 | 显示全部楼层 |阅读模式
工程做完了,在Creat runtime application时出现问题,提示如下:*** Start FactoryTalk Linx Conversion Messages ***
ERROR: Unsupported driver detected. Driver name = "RSLinx Server". Description: Only the Ethernet driver and Serial DF1 drivers are supported by PanelView Plus 7 Standard Machine Edition applications. Only the Ethernet, Serial DF1 and Serial DH485 drivers are supported by Compact Machine Edition applications.
ERROR: Unsupported driver detected. Driver name = "1784-PKTCS ControlNet Scanner". Description: Only the Ethernet driver and Serial DF1 drivers are supported by PanelView Plus 7 Standard Machine Edition applications. Only the Ethernet, Serial DF1 and Serial DH485 drivers are supported by Compact Machine Edition applications.
*** End FactoryTalk Linx Conversion Messages ***
WARNING: When running the MER,the display can be closed using the Close button in the title bar without any authentication.Please refer to the online help for more detail on this warning.
Validation completed with errors. The runtime application has NOT been created.
请大家帮我想想办法,在RSlinx Enterprise 里面我已经删除了1784-pktcs 的驱动,还是出现这个提示。
梦醒都是空 发表于 2022-9-27 09:23:02 | 显示全部楼层
您好,您这个问题解决了吗?可以跟我分享一下时如何解决的
GMT+8, 2026-10-5 22:07
