[HMI/SCADA] Catapult DNP3 Driver v9.5.70.11
zhangbing 发表于 2019-5-13 23:12:21 | 显示全部楼层 |阅读模式
下载地址:若需要可以回帖索取
The Catapult DNP3 driver supports DNP 3.0 master communications for up to 1,000 DNP 3.0 slave devices, across 200 serial and/or IP channels.  The driver operates as an OPC server for any control system that supports OPC.
In addition to being an OPC server, the driver is also a native GE Intelligent Platforms Proficy iFIX or Cimplicity version 7.x driver, using a native interface to Proficy iFIX or Cimplicity systems.
General
Supports DNP 3.0 to Level 3 for both Requests and Responses
Sequence of Events (DNP Level 3 only)
Report by exception (DNP Level 3 only)
Slave supported DNP levels 1, 2, 3
Internet Protocol - both UDP and TCP
Serial (300-57600 baud)
Radio support includes Flow control; Push To Talk control; Pre & Post-transmission delay setting; configurable retries and timeouts
DCOM is not currently supported,  the driver must run on the SCADA server
DNP3.0 for Proficy iFIX
Database addressing supports both NIO and OPC interfaces
The Driver can be started as a standard iFIX driver through the SCU, or configured to run as a windows background service.
DNP3.0 for Proficy Cimplicity
The Driver can be started as a standard Cimplicity driver.
Devices & Channels
Separate configuration of devices and channels
Each device can be connected to one or more channels
Each channel can be connected to one or more devices
Prioritization and automatic fail over when multiple channels are available
The maximum number of channels and devices is limited by system resources. The driver has been tested up to 1,000 devices and 200 channels.
Sequence of Events (SOE)
SOE Level 3 time mode, supporting Local and UTC time
Each and every SOE detected and written to the SOE log file, time stamped to 1msec using time captured by the I/O device
Includes time synchronization
Full support for SOE event display in iPower SCADA
Momentary Change Detect
Momentary changes (e.g. closed>open>closed) can be captured and passed on to the SCADA system, regardless of master polling cycle speed.
Each momentary change is time stamped as it was captured by the I/O device, providing an accurate record of the change.
Configuration
”On the fly” configuration without requiring system restart
Logging
Communications monitoring in configuration window and to file
Logging of raw binary data (data link) and decrypted data (application layer)
Comprehensive statistics for both devices and channels
Separate SOE log file
All statistics are available to SCADA
GMT+8, 2025-4-20 21:50
