[PLC编程] Proficy Machine Edition v8.6 安装文件下载
zhangbing 发表于 2019-5-13 17:07:35 | 显示全部楼层 |阅读模式
32-bit or 64-bit variations of the following: Windows 7 Ultimate, Windows 7 Enterprise, or Windows 7 Professional.
Important: For cautions and limitations when using Machine Edition on Windows 7, select Machine Edition in the Product field above, and click the Release Notes tab.
32-bit or 64-bit variations of the following: Windows 8 Professional, Windows 8 Enterprise, Windows 8.1 Professional, Windows 8.1 Enterprise
Important: Windows 8 and Windows 8.1 does not support View Runtime or Control runtime
View and Logic Developer PC are not supported when running without elevated access. When using View or Logic Developer PC targets you can lower your User Account Control settings and/or set up Proficy Machine Edition to always "Run As Administrator".
安装文件下载:
liuying_1992 发表于 2024-5-10 11:34:11 | 显示全部楼层
支持wind 10系统吗?
 楼主| zhangbing 发表于 2024-5-13 18:25:30 | 显示全部楼层
v8.6不支持windows10. 如果要在windows10上运行选择较新版本吧
GMT+8, 2025-4-2 00:31
