[HMI/SCADA] GE DataDesigner 5.10
zhangbing 发表于 2019-5-2 17:23:10 | 显示全部楼层 |阅读模式
DataDesigner Configuration Software Version 5.2.0
https://www.eleok.com/thread-123655-1-1.html
安装方法下载附件,解压缩后,运行disk1目录下setup.exe
DataDesigner software is a Windows-based program that provides a graphical user interface, drop-down menus, toolbar buttons, and other features to perform the configuration of Datapanels. You can use DataDesigner to configure multiple Datapanels of the same type. DataDesigner can be used to configure the following Datapanel models:
30/35
50/55
40/45
60/65 and 80/85
150, 160, and 240E
DataDesigner is used to build a project, which contains tag definitions, page layouts, messages and function key definitions.  DataDesigner compresses the project into a single database, which is transferred along with the communications protocol to the Datapanel via the PC download port.
This online help assumes a working knowledge of the Windows environment. For more information about menus, toolbars, etc., consult your Windows documentation.
DataDesigner requires a PC-compatible computer running Windows 95/98/NT or Windows 2000.
GMT+8, 2025-4-20 21:53
